| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #196 (permalink) |
| Senior - BHPian | You could give the 100/90 + cutout to your authorised SS and they could install it for you at the next service (Did this with my santro)
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson |
| | #198 (permalink) |
| BHPian Join Date: Dec 2004 Location: Bangalore
| Hello BHPians, I plan to upgrade my Corolla's headlights, the car is now 2+ years old. I haven't made any changes to the stock headlight setup, haven't even replaced a bulb till now. Corolla stock setup was actually quite powerful so never felt the need to upgrade, but they have become very weak these days. My requirement is very simple, need good lighting for night highway drives. I have couple of questions, 1) Is it enough if I just replace existing bulbs with more powerful ones, if yes which one(make and model) should I opt for? 2) Is it advisable to go for Xenons? Any significant advantage in doing so? How much it would cost? 3) Any specific Car Accessory shop in Bangalore? My budget is somewhat limited at about Rs.10K, I have already spent huge amounts of money on ICE and leather upholstery. So can't afford any expensive upgrades. Guide me ![]() |
| | #199 (permalink) |
| Team-BHP Support ![]() | novice, corolla indeed has good lights. you can go for higher wattage, but as you mentioned that the lights have gone dim recently, its like curing the symptom and not the disease. I would suggest that before you take the plunge of brighter headlights get your headlight assembly cleaned. After that if you still feel light is inadequate you can go for higher wattage bulbs like Vision+, Silverstar, Philips extreme power+, Philips 150 etc., Xenon's will cost around 4-5K if you upgrade just one of the beams, but it will blind the oncoming cars quite a bit, even in the low beam. So you can out xenon's for high beam and use high beam only when you need it.
__________________ Reclaiming.....! |
| | #200 (permalink) |
| Thanks tsk1979 for the suggestion. Do I need to make any alterations to the headlight assembly to fit Xenon bulbs or just replace the existing bulbs with Xenons? I really don't know anything about AutoLighting, so some my queries may seem silly. Please let me know if there is any "tutorial" thread on this topic on TBHP or on the web. |
| | #203 (permalink) |
| Newbie Join Date: Dec 2005 Location: new delhi
| How about for Optra Royale? Any suggestions for that? I donot want to go for high Wattage but definitely bit more than what it has in the company fitted. Any suggestions? I've been scared by the statement that an extra wattage might melt the wires. Provide some input of what shall I go for? Thanks |
| | #205 (permalink) |
| BHPian Join Date: Jan 2007 Location: Mumbai
| Hi guys, Ive gone through this thread and have submitted a couple of posts too. As mentioned before i own a Swift Vxi. I would like to upgrade my headlamps as well as my fog lamps to HID kits. Now i am totally confused as there have been many discussions on HIDs fitted without the projection setup are illegal and then there have been contradictions by others and by the guys at the accessory shops as well. I am also not sure as to what model of HIDs i should fit, i.e. 6500K, 8000K, 10000K and so on. Ive checked out the coulour of beams on the net and have found the 8000K to be absolutely blue and the brightest. They seem brighter than the 10000K too. So guys, i need your help in advising me as to what i should go in for. The investment is huge so dont want to mess it up. Do suggest good brands of HIDs available in Mumbai too. I would like the ones with the high and low beams. I believe the Phillips HID kits only come with a high beam. Epic
__________________ ___________________________ If everything is coming your way, you're in the wrong lane!!!!! |
| | #206 (permalink) | |
| Quote:
Hi Jeetu, Where did you put your lights from? What is the make or brand of the equipment and how much did it cost you for the headlamps and fogs? I need them for my Swift. Epic
__________________ ___________________________ If everything is coming your way, you're in the wrong lane!!!!! | |
| | #207 (permalink) | |
| Team-BHP Support ![]() | Quote:
The Kelvin temperature just tells the light color, if a kit tells you brightness by "K" they are fraud, run away. Light output is measured in Lumens, not Kelvins As for Philips HID Kits, there is no such thing as a philips HID kit. If a seller is offering to sell you philips HID kit he is a fraud and please stay away from such sellers.
__________________ Reclaiming.....! | |
| | #208 (permalink) | |
| Senior - BHPian | Guys any comment on this request of mine:: Quote:
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) | |
| | #209 (permalink) |
| Team-BHP Support ![]() | You can go for a 60/55W halogen if your electrical system can handle such load. Go for Vision+ as it is among the brightest in the 60/55W range. If you can only use the 30W halogen, the options are very limited.
| | #210 (permalink) | |
| BHPian Join Date: Feb 2006 Location: Bangalore
| Quote:
« Front windscreen sunfilm?
Is It necessary to add new plug wire,ignition coil if adding new NGK Iridium Plug »
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 37 | 22nd September 2008 11:03 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 6 | 6th September 2008 10:46 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
