Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 15th September 2008, 22:07   #2116 (permalink)
Path_Finder's Avatar
Originally Posted by ethanhunt123 View Post
Whats the life of Phillips X-treme power ? with normal usage ? I dont want to get stuck in the middle of nowhere with fused headlamps.
I would guess that life is marginaly lower than regular, but not very low. We will have to wait for sometime for actual use experience. The Philips website gives the following ratings on X-treme Power bulbs
Lifespan
Performance
Practicality
Styling
Path_Finder is offline   Reply With Quote
Old 17th September 2008, 21:06   #2117 (permalink)
amit_mechengg's Avatar
finally i have got a 100/90 philips rally H4 for my alto old model headlights.
i have put a PMP relay kit.
its a marginal upgrade as the high beam is very powerful , but the low beam spread could have been better.
cost of each bulb is 150rs and kit costed 500 rs , fittment 50 rs.
i am totally satisfied. thanks to happy wheels
__________________
" I dont Drive Fast , I Fly Slowly "
Old 18th September 2008, 16:28   #2118 (permalink)
rakowli's Avatar
Try setting the headlamp assembly a bit on upper side. It must be having a screw to adjust the settings. That will give you a better low beam spread.
rakowli is offline   Reply With Quote
Old 18th September 2008, 17:49   #2119 (permalink)
...i am totally satisfied. ...
way to go amit!
Glad to be of help!
HappyWheels is offline   Reply With Quote
Old 18th September 2008, 18:00   #2120 (permalink)
tsk1979's Avatar
Lifespan
Performance
Practicality
Styling
Life of +80% and +80% bulbs is usually less than half than that of normal bulbs. esp with frequent high/low beam switching.
__________________
Reclaimed, wrung dry and recycled....!
Old 18th September 2008, 21:52   #2121 (permalink)
Default Hella Rallye 4000
I'm planning to install a pair of Hella Rallye 4000 with 100W H1 bulbs on my Indica Lxi. What are the precautions/steps i need to take during installation. Planning to install a seperate switch to control them. What are the addons i need to purchase to install the Rallye 4000?
underground1419 is offline   Reply With Quote
Old 19th September 2008, 10:55   #2122 (permalink)
I also have doubts about the 80% of normal life claimed on a bulb which will 80% more light! I have put it on my CEIDA - so let me see over time. These bulbs are new in the market and will know after some time only.
Apart from the cutting and relays need, the problem I find with higher wattage bulbs is that they kind of balcken a bit over time and you will not see the initial advantage after some time.
Old 21st September 2008, 00:18   #2123 (permalink)
ethanhunt123's Avatar
Where and which bulb did you get for your CEDIA Pathfinder ?
ethanhunt123 is offline   Reply With Quote
Old 21st September 2008, 11:41   #2124 (permalink)
badboyscad's Avatar
Urgent advice needed:
what type of headlamp bulb does the scorpio has (h4 or h7 or etc)??
Will Phillips Xtreme bulbs fit in my 2003 scorpio?
If not, then what is the brightest bulb available for the scorpio?
Please reply ASAP guys, im gonna go shopping now.
TIA
__________________
Im not the Best but im not like the rest
badboyscad is offline   Reply With Quote
Old 21st September 2008, 11:48   #2125 (permalink)
I picked it up from JC Road after some search. Check out my post http://www.team-bhp.com/forum/test-d...tml#post978507 (Belle Beast! It had to be different & it had to be CEDIA Sports Yellow) - I have included the shop address and some direction there
Old 22nd September 2008, 15:08   #2126 (permalink)
kumar_ranjan's Avatar
I have Angle eye in the swift, the problem is that some of the LED's are not working and when I took it to some electronics shop for repair, he told me that some of the resistance were broken and he was not able to find the correct values of it. Can anyone have an idea if I can get the complete kit of LEDs with the wire so that I can replace the existing one.
__________________
No GOD no PEACE, know GOD know PEACE
kumar_ranjan is offline   Reply With Quote
Old 22nd September 2008, 20:00   #2127 (permalink)
manojgautham's Avatar
Need urgent help, I am planning to put in H4 HID in my car.
Has anyone here bought a 4300k or a 6000K bixenon. If so what brand and how much does it cost.
I've been quoted Rs8500 for the Philips kit, it comes only in 6000k, I was more keen on 4300k. Will there be a large difference between 4300k & 6000k. I would anyday prefer a Philips kit to a Chinese kit. Kindly advice me on the modification.
thanks in advance,
Manoj
manojgautham is offline   Reply With Quote
Old 22nd September 2008, 20:32   #2128 (permalink)
ImmortalZ's Avatar
6000k = lots of show, no light advantage from halogens, worse than stock in fog/rain.
4300k = reason you should be using HIDs.
Old 22nd September 2008, 21:06   #2129 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
not really. they are much better than halogens though not as good as 4300k. and not as irritating as 8000k and 10000k. 6000k is the best compromise between show of and utility.
akshay1234 is offline   Reply With Quote
Old 22nd September 2008, 22:46   #2130 (permalink)
ImmortalZ's Avatar
I disagree, but I don't want to argue
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
