| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #2146 (permalink) | |
| BHPian Join Date: May 2007 Location: kanpur
| Quote:
please anybody has a reply to my query?? ![]() | |
| | #2147 (permalink) |
| BHPian Join Date: Jul 2007 Location: New Delhi
| I had the same issue as well, but I was told that you dont usually get Philips VisionPlus for the fogs (H8s) and really actually wouldnt be worth the cost, think I was quoted about a 1k, if I remember clearly. Why not go in for xenons again? Thats what I'm doing - would get a uniform lighting pattern as well, at least colour wise. |
| | #2148 (permalink) |
| BHPian Join Date: Sep 2008 Location: NOIDA / Gurgaon
| Folks, since the time i discovered this forum i have been hooked onto it like anything! When it comes to views, reviews, expert tips & suggestions, comparison & narration of cars I will gladly proclaim this is the best place - at least for us - the Indian car savvy fraternity. However, i found this long thread an exception (appalling actually) much unlike the range and depth of expertise in all other areas on this site. Anyway, to cut a long story short, I have done significant analysis into car lighting and here are few upfront facts distilled out of my learnings and experiences (but please read this in conjunction with at least a few pages of opinions and suggestions in this thread to complete the picture). In this part i will cover incandescent halogen headlamp bulbs. Will do the HIDs later: 1. Most of the car headlamps in India house H4 P43t base bulbs. These have two filaments one for the high beam and the other for the low beam. Normally, these are 60W/55W (one is the high beam the other is the low) 12V. These are filled with inert gases mostly xenon that is why they are also called xenons or xenon halogens. But these are NOT High Intensity Discharge (HID) bulbs which are also referred to as xenons these days. 2. Headlamp assemblies where there are two separate headlamp reflectors and bulbs normally have a dedicated high beam and a dedicated low beam (both 55W, normally H1 or H7 type). These bulbs are marginal improvements over H4 as the filament could be heated to slightly higher temperature than is feasibly achievable in H4 due to its bigger volume. 3. Higher temperature also wears out the life of the tungsten filament of bulbs. Therefore, H1 or H7 normally have shorter lifespan than same watt H4. 4. With increase of wattage the life of a bulb deteriorates further. A 60W/55W H4 will normally have twice as much lighting life as 100W/90W H4 and even longer compared to 110W/100W or 130W/100W H4. Therefore, if you replace your stock H4 60W/55W with a higher wattage expect faster burn outs of your car's headlamps. 5. The heat produced by halogen lamps is much more intense than non-halogen incandescent bulbs (and therefore, brighter as the filament could be heated to even higher temperature). Normally, headlamp assemblies including the reflector, bulb holder, the rubber linings & wires are designed to handle stock capacities. If you upgrade with relay (relay is a protecting or 'insulating' device which protects sensitive power generating and transmitting devices and conductors from the surge of heavier currents by simulating an artificial high resistance whilst powering a low resistance device that drains more current, & therefore, power) and thicker wires you'd be fine in most cases. However, the long term effect of more heat on the headlamp reflectors will start showing. Smaller reflectors are more vulnerable to losing their shine faster due to high heat. 6. There are several halogen headlamp bulbs available in the market for more specialised use. However, bear in mind the stock bulbs that came with your brand new car in the last 3-4 years are almost as good as you can probably buy from the market paying a much higher premium. I have tried at different points in time arguably the (then available) brightest and most light producing (will explain in the next point) bulbs like Osram Silverstar (Osram Silverstar has two sets one for the US which has much relaxed automobile lighting rules and the other for Europe with stringent regulations), Philips Extreme and the latest Osram Night Breaker. I also tried Phoenix lamps' Halonix +60. I can safely say the overall improvement in illumination in normal city and outskirts driving was marginal. And all of them seemed to do a job as good as the other, except the Osram Night Breaker which due to large proportion of glass area covered by bluish tint gives 'whiter' light. 7. Any bulb coated with colours (blue or yellow or golden) will effectively shine less light on the road as the tint will absorb a portion of the light emanated from the filament. Simple optics helps us understand that due to this absorption of a certain part (wavelength or frequency) of the light, the light appears 'coloured' - either more 'whitish' or bluish or yellowish. However, whiter or bluish light improve apparent illumination (but not visibility) at night time at the cost of reduced 'amount' of light. They are better for lower beams and wider horizontal spread. 8. Several experiments have been conducted to find if yellow or golden light actually improves visibility during fog and rains. The findings are inconclusive - some tend to suggest yes and others no. Therefore, you can be happy with whatever you have cheers: 9. Big question now: you would have probably seen bulbs from the most reputed auto bulb makers including Osram & Philips raving about +50, +80, +90 range of bulbs. Does that mean these bulbs produce that % of more light output? The answer is no. Then what do they do will be your next obvious question! They increase illumination at a distance (usually between 50 to 75 metres) by that % by doing changes in their bulb's filament design and getting the light spectral pattern to focus more at longer range. Which in effect will mean you will be able to 'see' more at a distance without actually increasing the overall light output! This will be apparent to you when you drive in long stretches of unending darkness and not in city and city outskirts lighting conditions. 10. In the Scandinavian countries including Denmark it is mandatory to drive with headlights on even during the daytime. For such specialised uses there are separate sets of halogen bulbs available commonly called daytime running lights. The filaments of these bulbs are engineered to burn at a relatively lesser temperature thereby increasing the longevity significantly, albeit at the cost of slightly less whiter light (the higher the temperature of filament the whiter is the light; lower the temperature yellowish is the light for clear lens bulbs). Now that i have given you guys 10 points, here's my piece of advice just in case anyone needs it: if you plan to do off-roading and depend on your auxiliary high power lamps to light your way please carry a spare set of bulbs as they burn out much quickly. In fact, in some european (again!) countries including Spain, Czech Rep it is mandatory to carry spare bulbs in the car. Finally, to answer one of the questions about having both the beams (filaments) of H4 headlamp bulb on and its effect on bulb longevity: In a lot of cars with H4 headlamp bulbs the dipper switch when dipped partially (high beam is turned on) it lights up the high beam. If you are driving at night on low beam this will mean that till the time the dipper is partially dipped both the beams are lightened up (until you pull or push the dipper completely when it switches over to the high beam or let the dipper go which turns off the high beam). During this time when both the beams are on a lot of heat is produced which is not a normal condition based on which bulbs are designed. This severe heat affects the bulb's filament life. Consequently, faster burn outs. In fact a lot of bulbs turn grey to black due to bad engineering and high heat which evaporates the tungsten filament into minute particles and deposit them on the bulb glass. ![]() Ciao tonight! Rest later.. - Abu |
| | #2149 (permalink) | |
| Senior - BHPian | Quote:
Another thing, if you want uniformity you need to get 4300k from the same bulb manufacturer... cos colour temps vary from company to company.
__________________ No fate but what we make! | |
| | #2151 (permalink) |
| BHPian | Thanks Abu for the long message. I agree with that higher wattage bulbs fade the HL assembly and so does their relative advantage over time. And they burn faster. But tell me in layman terms as to why better illumination will not give better visibility (of course with right wavelength and projection)? The relation has to be direct if not linear. |
| | #2152 (permalink) |
| Team-BHP Support ![]() | 100/90W bulbs have lower life than 60/55W normal bulbs, but the +80%, +90% bulbs have the lowest life. And a brighter bulb will give better illumination when focussed again. Filament position is variable from sample to sample, therefore its advisable to get refocusing done after every bulb change.
__________________ Reclaimed, wrung dry and recycled....! |
| | #2153 (permalink) |
| Senior - BHPian | Is it allowed to use xenon's on high beam.
__________________ vRs(q)® | ECLIPSE CD7200 MKII | Illusion Carbon ND-6 | Harman/Kardon CA470 | Harman/Kardon CA1500M | Stereo Integrity MAG D2 V4 Last edited by aah78 : 26th September 2008 at 03:43. Reason: Post moved to correct thread. |
| | #2154 (permalink) |
| Senior - BHPian Join Date: May 2004 Location: Bombay
| Yes it is allowed...most xenons that come on luxury cars here are bi-xenons which means the high beam is also xenon. I dont see a reason why it would not be allowed.
__________________ ______________ __________ ______ __ Last edited by aah78 : 26th September 2008 at 03:42. Reason: Post edited and moved to correct thread. |
| | #2155 (permalink) |
| Team-BHP Support ![]() | It's allowed, as Sahil mentions, but the beam will blind oncoming traffic, the same as your regular halogen beams do, so please use your high beams wisely.
__________________ Keep your clothes and your boots, I'll just take the motorcycle. Last edited by aah78 : 26th September 2008 at 03:42. Reason: Post moved to correct thread. |
| | #2157 (permalink) | |
| Quote:
| | #2158 (permalink) |
| @Path_Finder Sorry i made a mistake. Instead of reading it as "However, whiter or bluish light improve apparent illumination (but not visibility) at night time at the cost of reduced 'amount' of light." please read it the other way around. That is, whiter or bluish light improve visibility without change in illumination. This is due to the sensitivity curve of human retina. In a nutshell, for the same amount of light, say one is yellow and the other white, our eyes will 'see' more in white than in yellow. Consequently, some bulbs come with coating which although absorbs a part of the light (so less amount of light on the road) yet the road appears better in terms of visibility. That is why latest Philips x-treme & Osram Night Breaker come with a mild bluish tint (Night Breaker has more area covered with the tint but the intensity of tint is more in x-treme) to emit whiter light. One needs to bear in mind that there is a trade-off between the thickness of the coating and the wavelength of the light. A heavier coating can reduce the effective visibility by blocking proportionately more light. Thanks Path Finder for pointing this out! @shyamhegde Unfortunately, I will take a while to post the HID stuff. On the fogs even am boggled myself. I think the halogen fogs are less useful and more for the looks of the car They do help a little in fogs and rains but the help rendered is governed so much by the beam pattern. Retrofitting normal fog lamps with HIDs is almost a waste of money unless the reflector focusses the beam effectively (which is difficult to achieve given the difference in the filament beam pattern as opposed to gas discharge beam pattern). Personally my advise is not to spend a fortune on fog lamps, unless it is for the looks and not the purpose. For adverse light driving conditions, auxiliary lampsets (Hella is the best) with HIDs are the best but costs quite a lot, besides having legal wrangles. In my OHC i had a chinese pair of fogs with two H3s in each. This gave me the flexibility to mix & match (2 light blue & 2 golden coated bulbs) but wasn't too effective in the dense fogs. This arrangement is also very heavy on the battery (additional 4 x 55W) and alternator. |
| | #2159 (permalink) | |
| Quote:
| | #2160 (permalink) |
| Folks, any clue how many headlamps Indica Vista has? Is it single H4 or twin reflectors (maybe H1 & H7)? Sorry to be asking such a trivial question but from the pictures that i have seen so far it is not much apparent Wish i could see the car in real life ![]() Thanks! |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
