| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #2176 (permalink) |
| BHPian Join Date: Aug 2008 Location: Hyderabad
| Hi All, I have a Ford IKON 1.6 and would like to change the head lamps to HID for better visibility and more light on the road. The OEM setup has a single bulg with 2 filaments. I have the following questions. Is there a way that I can put in a HID bulb with projector setup in the same headlamp assembly? Is there a non OEM full assembly available which has the full functionality of double beam headlight, parking light and turn indicator which will fit in the car without any body work? My wishlist is to have a full headlamp assemblt with angel eyes and LED turn indicators that can be a plug and play in the IKON. Let me know your thoughts on this. Thanks in advance. |
| | #2177 (permalink) |
| Newbie Join Date: Jun 2008 Location: Pune
| Hi All, I wanna put Phiips Xtreme Power or Essential Vision in my Getz. Can you please suggest which one is better? Xtreme Power is 55/60w ,on the other hand Essential Vision is 90/100w. Which one has a better area coverage and brightness and also suitable for rain? Please let me know fast coz m going to GOA by car on Friday!!!!!!! ![]() |
| | #2178 (permalink) |
| Senior - BHPian Join Date: Aug 2008 Location: Bangalore
| Hi All, I wanna put Phiips Xtreme Power or Essential Vision in my Getz. Can you please suggest which one is better? Xtreme Power is 55/60w ,on the other hand Essential Vision is 90/100w. Which one has a better area coverage and brightness and also suitable for rain? Please let me know fast coz m going to GOA by car on Friday!!!!!!! ![]() Hi ankushmulay, If you are looking for a bulb upgrade without adding in an extra relay, then I suggest you go in to the Xtreme Power bulbs from Philips. If you do want to cut your wiring and ad in an extra relay then you could updgrade to the Essential Vision 90/100 W bulbs. In my opinion, for driving in the rains, the Xtreme Power bulbs from Philips do an excellent job! I have written a detailed review on the Philips Xtreme Power bulbs and you can read it at this link - http://www.team-bhp.com/forum/access...-h4-bulbs.html Cheers, Pritish |
| | #2182 (permalink) |
| BHPian Join Date: Jul 2007 Location: New Delhi
| Yea, bought a set of the same type of bulbs in Bangkok and MAN were they horrible. They probably lit up the bumper of my car more than anything else!!
__________________ 2007 SX4 - 90/130w Ring Bulbs, Hella Comet 500s, 55w Stock fog lights, 205/55 R16 Yoko A Drive R1 |
| | #2183 (permalink) |
| BHPian Join Date: Apr 2004 Location: Vikhroli - (Mumbai)
| Guys i have been using Narvas 100/90 on my Santro Xing and noticed a very strange problem. A: Scenario 1 1: Changed the Relay to Bosch 2: Fitted Narvas 100/90 3: 1 Bulb Blew exactly after 1 month Scenario 2 1: Fitted another set of Narvas 2: 1 Month Later = Bulb Blew Scenario 3 1: Fitted Narvas again as i wanted pure bright white light. 2: 1 Month Later = Bulb Blew So finally got 100/90 Type R's which by now am damn sure are purely cosmetic, but still running fine from past 1 year. What could be the problem in this case. As both bulbs are 100/90. I am so confused.
__________________ NISSAN: "We don't defy physics with the GT-R, we apply it properly."....! |
| | #2184 (permalink) |
| BHPian Join Date: Jun 2006 Location: Banagalore
| Hello All, I searched in this thread but could not find any similar posts, if it is already there please feel free to delete this. I have a pair of Hella 550 Fog Lamps in front and one Hella 550 reverse (Clear Glass) light at rear. When i bought the Jeep, all of those caps/covers were melted and shape less - Thanks to the lousy switches on dash. Now i shifted the switches to another location and changed to pull/push type switch. I want to replace all those caps/covers. From where can i get it? Is is available separately? its available thru Amazon but they will not ship it to India. If its available from where i can get it in Bangalore? Thanks --Sree--
__________________ Get Going, Go Jeepin... |
| | #2185 (permalink) | |
| Senior - BHPian | Quote:
Go to a garage with a good electrician and ask them to use proper quality of wires. If the relay is some local make than get one that will support 100/90 (roots).
__________________ No fate but what we make! | |
| | #2186 (permalink) | |
| BHPian Join Date: Sep 2008 Location: NOIDA / Gurgaon
| Quote:
Bear in mind 100/90W bulbs have significantly lesser lifetime than to 60/55W. Potentially one can blow them up over a usage of 75-100 hours or a little less depending on bulb type (extra bright or long life) & bulb manufacturer Outside the inherent properties of the bulb the other most significant factor is the terminal voltage supplied to the bulb. If they are higher than rated it can blow the bulb off at any time much earlier than the rated lifetime of the filament. In this case, if they were blown out on average of less than 50 hours of total usage then i suspect the relay could be the culprit - delivering current to the bulbs at much higher voltage ![]() | |
| | #2187 (permalink) | |
| BHPian | Quote:
(a)I fully agree with your statement above in italics. (b)But the next line is not correct as per my experience abk.I have used Philips Rally H4 12V 130/100 W P43t-38 bulb in my previous car for more than 3 and 1/2 years without any problem whatsoever.Even there was no signs of burnt reflectors,etc as claimed by quite a few here.I had installed bakelite holders and good quality wiring with separate relays and it lasted till I sold the car in late April 2008.I bought my current car in 1st week of May 2008,and have installed the same Philips Rally 130/100W ( obviously more powerful than the 100/90Ws,and also with a reported heat generation in excess of 200 degrees C !). No issues till date.Quite a few T-Bhpians have seen my lighting while riding with me and have been astonished by the amount of illumination I get.High beams are plain and simple murder for oncoming traffic ! I would strongly suggest use of bakelite holders,extremely high quality wiring harness and use of 2 separate relays for the bulbs.One can check 'view my garage' to see what I have done. Till date no problems even in torrential rains.Just 2 things I want to point out here: The bulbs generate enormous heat,so use it judiciously like turning it off at traffic signals (this would definitely help in preserving longevity). Secondly,there is a warning on the stock boxes these bulbs are sold in -->'Not approved for public roads' !! ![]() @s0uljah I agree with you completely mate.I think that the culprit is the wiring. @nikibusa Get the entire set-up checked and replace necessary parts by an experienced person.
__________________ Ice,Ice....My Baby !! [Pearl silver Zen Estilo Lxi,May 2008] [Moonbeam silver M 800,March 2003 -Sold] Last edited by ultimatechamp : 12th October 2008 at 11:32. | |
| | #2188 (permalink) |
| Thanks a ton guys for your help. I will certainly do the needful soon and then get a better set of lights soon.
| | #2189 (permalink) |
| BHPian | @nikibusa - As pointed out in a lot of posts, 100/90 do have a shorter span than normal 55/60 bulbs. I think the Type R bulbs are not real 100/90 bulbs, thus are lasting till now (their time will come too ).Above all this, bulbs blowing in 1 month's time is not the way it should be. I see your initial post says you changed the relay to Bosch, but no wiring change?? The culprit has been detected! EDIT: Just realised, I hope the Narvas you bought are not fake are they? Check with another set of bulbs.
__________________ • åĐïğŧėđ Tŏ Ÿoů... Last edited by ankitahuja : 12th October 2008 at 14:50. |
| | #2190 (permalink) |
| BHPian | for people using osram nightbreaker, can you guys comment upon the life on this bulb? do they last only for a few months? i know i might sound stupid but just wanted to know how short the life of a +90 bulb is?
__________________ rain and my swift....thats all i'll ever need!!!!!!!! |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
