| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #211 (permalink) | |
| BHPian Join Date: Jan 2007 Location: Mumbai
| Quote:
Hi TSK, Are you saying that Philips do not manufacture HIDs? Because ive spoken to the Philips guys and they claim they do, but do not have high/low beams. They just have one single beam. I presume the 8000K is the blueist colour? Do you not suggest i fit HIDs on my vehicle? Your post seems to be discouraging me to do so. If so, kindly let me know a suitable alternative. Epic
__________________ ___________________________ If everything is coming your way, you're in the wrong lane!!!!! | |
| | #212 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
If you can source a philips box packed HID, nothing like it, but its not available in India. Look at : Philips Xenon HID Lighting Technology From the web page: NOTE : Xenon HID bulbs can only be used in vehicles that have HID lighting systems. They cannot be used as an upgrade in conventional headlights. Philips does not make kits for fitting into your conventional reflector. You can go for a HID kit in your swift, but the problem will be that you will blind oncoming drivers a lot because the reflector is desihned for halogen and not HID arc Moreover their kit is only for either high or low beam not H4 fitment. So only if your car came with HID fitment, i.e. HID projector fitment, you can plug in the philips HID kit. For really good lighting I suggest you source Philips X-treme Power: Brightest halogen bulb available I have seen two HID setups till in conventional lights. 1 toyota corolla and one swift. The light was very bright and is very blinding, but if you see actual light on road, the benefit is not as apparent. Its there, but the blinding factor is manifold. If you really want HID, get a HID fitment in fog lamp enclosure and get high performance halogens in your ordinary H4 headlight enclosure. I would also suggest you read this Daniel Stern Lighting Consultancy and Supply If you are really serious about HID consider going through the HID lighting forums, the knowledge you have there is far more than this thread, as that entire forum is dedicated to HIDs. HiDPlanet.com :: Index
__________________ Reclaiming.....! | |
| | #213 (permalink) | |
| Newbie Join Date: Feb 2007 Location: Bangalore
| Quote:
Im a new member with Team-BHP, i also have faced the same problem with light focus on my Ikon, i had changed it to Phillips 100/130 first, it was good but it was not good when it come to the focus,i changed it to excess heating and changed it to Phillips Bluvision but still has the problem with the focus.
__________________ Never ride faster than your guardian angel can fly............ | |
| | #214 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| for iKON use a regular spanner, its tricky to put hands in but it works, size 10 if i remember correct
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #215 (permalink) | |
| BHPian Join Date: Jul 2006 Location: Delhi
| Quote:
Thanks tsk1979, that addresses lots of questions. But, why would HID blind oncoming drivers if the setup has been made for low beam. I understand the issue of reflector, but if the HID is setup only for low beam, there would be no blinding for oncoming traffic.I have seen certain setups made that way. The examples you referred about might have used high beam for HIDs. Isn't it?
__________________ The only lines that matter are the ones you make | |
| | #216 (permalink) | |
| Quote:
Thank you for the detailed explanation and the websites. The Daniel Stern site made alot of sense and so, yeah, ive understood that i am not supposed to fit HIDs in a halogen setup but however can fit HIDs n a projector setup. I guess i will take your suggestion and just install HIDs for the fog lamps. By the way, are the Phillips X-treme Power bule in colour or just normal? Any idea what is the power of the bulb, if they are available in Mumbai and where and approximate cost? Epic
| | #217 (permalink) | ||
Daniel stern link will explain the reasons Quote:
quote around 25 Pounds/pair, but I don't know how reliable they are. If you can find a reliable online seller who ships worldwide you can order them online. The bulb is 60/55W and does not require any relay/wiring change. The color of light is white and not blue, I guess it will be around 3800-4000K
__________________ Reclaiming.....! | ||
| | #218 (permalink) | |
| Quote:
Hi TSK, Thanks once again. But since we don't know about the reliability of the bulbs and they are not available here, i don't want to take a chance. Could you recommend something that is easily available here in Mumbai? Epic
| | #220 (permalink) | |
| Quote:
__________________ The only lines that matter are the ones you make Last edited by scorp 1 : 23rd February 2007 at 10:36. | |
| | #221 (permalink) | |
| Senior - BHPian | Quote:
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson | |
| | #223 (permalink) | |
| Quote:
Hi TSK, What about Osram Cool Blue? Are they better then the Silverstar? Cool Blues are available for fog lamps too so im considering that but only on your recommendation. Do let me know. Epic
| | #224 (permalink) |
| Team-BHP Moderator ![]() | Can't say much about that. Osram Cool blue and Osram Silverstars are supposed to have similar light output, with only difference being the color of light, but the best way to test would be to put one in each headlight and see the difference yourself. This is the best way to compare any halogens. If you like white light, Osram cool blue are among the best, but be aware that since the bulb has a blue tint, you will lose some light, though it may not be so much to be noticeable. So fit in both, and choose the one you like.
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 31 | 18th August 2008 15:48 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Bullet Upgrade - The Lighting Effect | madbullram | Motorbikes | 6 | 19th July 2007 12:42 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391
or not, but where can i get the screwdriver for the Ikon's headlight beam adjustment screws, because I don't want to spoil the screws by using just a plain Philips screwdriver? I tried in Mahavir Autos, Madras but they did not have it. Please I do need it! Already Ford's adjustment is pathetic.
