| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #243 (permalink) |
| Senior - BHPian | I had converted to the Philips Rallye 100/90W in December with proper relay, wiring and holders. Recently the high beam of the right headlight blew off. I have heard the bulbs are pretty reliable. What would have made them blow so fast? What do I need to check?
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* |
| | #245 (permalink) |
| BHPian Join Date: Dec 2006 Location: Bangalore
| I am running on 100W/130W philip rally bulbs with the proper ceramic holders and wiring kit for the past three years without a single change on my Alto Lxi with no probelms what so ever... maybe you should suspect the authenticity of the bulbs that you got ... I have even added the same setup to my New Verna CRdi ! and no problems till now , got the installation done from Trivadrum , shop called Car Palace. |
| | #246 (permalink) |
| Senior - BHPian | I was just going through the Philips Crystal Vision Review and TSK clearly mentioned there that getting 100/90W with relay u have to be careful. As they will blow easily. So its better to stick to 60/50W...
__________________ tinypic.com/player.php?v=35mo01l&s=4 |
| | #247 (permalink) |
| Senior - BHPian | We upgraded stock Osram 55/60W H1 and H7 bulbs to 100W H1 and 80W H7 on Determinus' GTX. The dealer said that we do not require a relay since it works well without it. I would like you guys to suggest if we should still insist on a relay?
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) |
| | #249 (permalink) | |
| Senior - BHPian | Quote:
2. How do I verify if the bulb is original? 3. Is this really a bulb issue or something to do with the electrical setup?
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* | |
| | #250 (permalink) |
| Team-BHP Support ![]() | High power bulbs blow due to these reasons 1. Fake Bulbs : This affects philips since its the most common bulb, so buy from a reliable shop. 2. High low together : Many cars let you use high low beams together, by pulling the stalk towards you when on low beam. For 60/55W it is okay, for 100/90W you can blow a bulb. 3. Alternator fault : Is your alternator giving over voltage. Check at the headlamp terminals. Disconnect the bulb, switch on and then put a voltmeter, should not go above 12.5 or so, but this is usually not the cause, happens in extreme cases as most bulbs have slight overvoltage tolerance built in, if they are of good quality
__________________ Reclaiming.....! |
| | #251 (permalink) |
| BHPian Join Date: Nov 2006 Location: Banglaore
| That is really an eye opener to me. I never knew that by pulling the liver towards us will glow low and high beam together. Actually I dont do myself. I allways toggle. But this friend of mine does that often. |
| | #252 (permalink) |
| Senior - BHPian | I guess for a very short period of say a couple of seconds this will not be an issue? And some cars like the Palio have separate High and Low bulbs and this won't affect them. Problem is when the high & low are in the same unit?
__________________ Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison |
| | #253 (permalink) | ||
Need to check this at my service center. But isn't the relay supposed to be doing its job?
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* | ||
| | #255 (permalink) | |
| BHPian Join Date: Oct 2006 Location: Trivandrum
| Quote:
I'm also planning for headlight upgrade, where is this Car Palace located? | |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 37 | 22nd September 2008 11:03 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 6 | 6th September 2008 10:46 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
