| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #2731 (permalink) | |
| BHPian | Quote:
__________________ U get to the end of the rainbow n u find the leprechauns booby trapped it! Hyundai Verna VGT CRDI SX ABS 14/10/08 | |
| | #2732 (permalink) | |
| BHPian | Quote:
For sourcing them - got in touch with Philips India through their website; got a mail promptly with their Surat distributor's details; called him up and got the reference to a local dealer who stocks them. So I am sure I have the genuine stuff. Made sure the packing was as it should be.
__________________ "I do have a brain...God just forgot to wire it!" Maruti 800 (Japanese model, restored!) Chevrolet Aveo U-VA LS | |
| | #2733 (permalink) | |
| Senior - BHPian Join Date: Dec 2007 Location: Bengaluru
| Quote:
I tried them on my Alto, but found the 100/90 more effective. But yes, this is the way to go if the A.S.S jumps about for the warranty issue with regard to the wiring. | |
| | #2734 (permalink) | |
| BHPian | Quote:
2) No, not possible in the stock headlamps. 3) The 100/90W bulbs do not last long compared to their 60/55W counterparts. 4) The stock bulbs in the fog lamps are H27. It would be difficult to source these bulbs. You can try out HID's. | |
| | #2735 (permalink) |
| BHPian | ShyamSCRDI told me that his getz headlamps were getting fogged up after installing his 100/90s. I think his headlamp casing is plastic. Is this the same case with the verna? Does this fogging issue persist for all brands of light? I think his is hella.
| | #2736 (permalink) |
| Senior - BHPian Join Date: Jan 2009 Location: New Delhi
| That's a problem with all Hyundai cars across the range, I think. Seen it in multiple cars, and even HMP asks not to change over to 100/90W lamps because of high chances of reflector damage due to the extra heat.
__________________ “Medicine, the only profession that labors incessantly to destroy the reason for its existence” ~ James Bryce |
| | #2737 (permalink) | |
| Quote:
So, the Getz definitely has some other issue if fogging is there. EDIT: Infact, because it was plastic I was limited to using 100/90; wanted to use 130/110, but that would have been disastrous. Last edited by HappyWheels : 27th March 2009 at 20:59. | |
| | #2738 (permalink) | |
| BHPian Join Date: Jul 2008 Location: Trivandrum
| Quote:
| | #2739 (permalink) | |
| Senior - BHPian | Quote:
1. it is the little thing above the main projector unit. next to the leds. 2. h4 will not fit in high or low beam since i think the bulb sizes will be h1 or h7. (not quite sure of the sizes but h4 wont fit) 3. from your normal headlamp stalk. when you turn on the parking lights the leds and the halo rings will come on. and for low beam the projectors and high beam the reflectors. just the way you use your present headlamps. 4. its a matter of personal choice IMO the black ones will look much better. my suggestion is to get 4300k or 6000k hids for the low beam. you should get a decent set for around rs 6k. use any 55/60 or 90/100w bulbs for the high beam, in white if you want them to match. | |
| | #2740 (permalink) |
| Thank you Akshay for clarifying the doubts that I had. But is it really necessary to go for a HID for the low beam. Does the Low Beam work only with HID? Since I dont have another 6K to spare at this moment, can I use some other Halogen(H1) which would cost under 1000Rs? If so which one do you suggest for the Low Beam and High Beam? |
| | #2741 (permalink) |
| BHPian | raj84, you may want to check this thread for more details. http://www.team-bhp.com/forum/modifi...ws-needed.html (Swift Aftermarket Projector Headlamps : Reviews needed)
__________________ The best car safety device is a rear-view mirror with a cop in it. |
| | #2742 (permalink) |
| BHPian Join Date: Mar 2009 Location: Chandigarh
| Hi guys Needed your help regarding Palio headlights , was planning to move to more powerful set of bulbs , will not change the low beams . Will only change the high beam bulbs to more powerful ones . So whats brands do u suggest ?? Any views from one who is using them . What all is to be done while moving to more powerful bulbs ... ? etc etc Thanks |
| | #2743 (permalink) | |
__________________ Tyres will screech & Engines will roar - WOM | |
| | #2744 (permalink) | |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
