| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #2776 (permalink) | ||||
| BHPian Join Date: May 2007 Location: Bangalore
| Welcome to the forum . All your questions are already covered in this thread multiple times.Quote:
Yellow ones are better for visibility. White ones are more for the bling factor Quote:
Generally, no. Each headlamp reflector is designed for a specific bulb, hence if you change to another brand, some times minor adjustments may be required. If you are replacing bulbs with same wattage, No. Quote:
Option 1: Bulbs with same wattage but providing more lumens [Ex: +50% Osram Silverstars, +50% Philips Vision Plus, +80% Osram Nightbreakers, + 80% Philips ???] - Does not need a relay. Should fit in your budget. Higher the %, the lower the life of the bulb. Option 2: Bulbs with higher wattage [Ex: Phillips 90/100W Rallye]. Needs a relay + Bakelite holders. Can damage the headlamp assembly in the long run in some cars. Life is generally lower than stock bulbs Option 3: Bulbs with a little higher wattage than stock [Ex: Osram Hyper bulbs 65/70]. Not sure if these are available in India. These are supposed to provide the same lumens as 90/100 but with the life of stock bulbs. Last edited by Lord Lucan : 12th April 2009 at 20:42. | ||||
| | #2777 (permalink) | |
| BHPian Join Date: May 2006 Location: CHENNAI
| Quote:
Folks, any alternatives ? Pls advise as I found it extremely uncomfortable with the stock lighting on the i-10 even in the ten minute drive.
__________________ get in....sit down....Hold On....SHUT UP !!! | |
| | #2778 (permalink) | |
| BHPian | Quote:
| | #2779 (permalink) |
| i'm ok with 100/90's as well as I'd been using these for about 6 years on my previous car. Anyone foresee a problem with this setup on the i-10 ? Also pls advise if there is a Hella model that would fit into the fog lamp slot of the i-10 ?
| | #2780 (permalink) | |
| BHPian | Quote:
Headlight dome looks big enough to take that. I used 90/100 for 6 months and 100/130 for rest in last 3 years in my Santro and no issues with it. With 100/130 , have done many long night drives. | |
| | #2781 (permalink) | |
| Quote:
Request i-10 owners to give their opinion and suggestions. Also pls advise on hella's to fit into the fog lamp slot of the i-10 and the purchase price of these
| | #2782 (permalink) | |
| BHPian | Quote:
@slipstream - I have been using 100/130 lamps in my WagonR for 3 years now and i have had no issues with the reflector fading/fogging at all. I know of a few friends who have used 100/130 lamps in a Santro without any problems too. I don't know about the i10 but I have a feeling you can safely upgrade to 100/130 lamps for the i10. Your signature shows that you sold a 1986 model Maruti 1000, are you sure it was a 1986 model? Coz IIRC the maruti 1000 was launched only in 1990. Correct me if i am wrong!Cheers
__________________ "WINNERS DON'T DO DIFFERENT THINGS, THEY DO THINGS DIFFERENTLY!" Last edited by prince85 : 13th April 2009 at 09:46. | |
| | #2783 (permalink) |
| BHPian Join Date: Aug 2008 Location: Bangalore
| hey Guys ! If any one hadnt yet tried these Flosser bulbs (silver Blue) i think you can go for it ! I have used Flosser H7 70 Watts (SilverBlue) in my palio. I just returned from Ooty, and the trip has about 8 hours of night drive .. continuous night driving for abt 5 hours! Wonderful lights. I never had a problem with visibility, and didnt even use my high beam (Phillips rally 100 watts) anywhere except for dip during overtaking. The visibility is great with these flosser bulbs and its just 70 watts so doesnt heat up much. Ii dont think the opposite traffic (on the single and double lane after mysore) had much glare, because no one was trying to behave wierd by using high beam . Its a good buy and I would recommend these if you are looking for bulbs with power/visibility more than stock and not heat up much !! PS: My colleague says Flosser bulbs are used on audi and other popular european cars he he he .... |
| | #2784 (permalink) | |
| Senior - BHPian Join Date: Aug 2008 Location: Bangalore
| Quote:
The heat generated from the 130s is enough to melt the plastic lens and internal reflector of the headlight of the i10Cheers, gpa | |
| | #2785 (permalink) |
| [quote=prince85;1257364 Your signature shows that you sold a 1986 model Maruti 1000, are you sure it was a 1986 model? Coz IIRC the maruti 1000 was launched only in 1990. Correct me if i am wrong!Cheers[/quote] i picked up a prototype ![]() thnx for pointing that out...signature now stands corrected
| | #2786 (permalink) | |||
| BHPian | Quote:
3003 is the newer model offcourse,so you would hope to lay your hands on newer technology. Welded bull bar is a must and do definitely get the stone guards as well as the clear lens guards with the lights. Price quoted to you is pretty neat,but are they grey price? Quote:
1)Nope. In order to get a yellow light in the first place,you need a yellow filter or even a yellow color coated bulb.You always get less transmitted light.So visibility is never improved with yellow lights.Its a misconception that yellow light has greater penetrating power,and thats why fog lights nowadays have stopped being yellow. 2)Yellow ones are very rarely found as headlights or main driving lights.White lights are the best bet in terms of visibility and penetration in almost all climatic conditions.Infact,the blue light bulbs used as headlights like the Philips Diamond vision etc and any HID above 6000K are only for the "bling" factor. 3)Headlight reflectors are static objects and you cant just make any adjustments to them however minor they may seem.So-called adjustments are made in the angle a bulb is fitted in the holder and that is usually done by putting the headlight beam against a wall and then adjusting the bulb angle. Quote:
by convention the figures are written as 130/100, 100/90, 60/55 W. The first figure denotes high beam,the latter one low beam.Its never the other way round.
__________________ Ice,Ice....My Baby !! [Pearl silver Zen Estilo Lxi,May 2008] [Moonbeam silver M 800,March 2003 -Sold] | |||
| | #2787 (permalink) | ||
| Quote:
. By yellow light, I meant Stock bulbs. By white light I meant, bulbs with say blue color filters. I think this matches with the context of the orginal poster. ![]() Quote:
"So-called adjustments are made in the angle a bulb is fitted in the holder and that is usually done by putting the headlight beam against a wall and then adjusting the bulb angle." Agreed The focal points of bulbs of the same type (say H7) will be a little different based on the manufacturer. So headlight alignment may be required after one changes the bulbs. My alignment was all messed up after replacing the stock blubs with Philips vision plus. | ||
| | #2788 (permalink) |
| BHPian Join Date: Mar 2008 Location: Pune
| Hi, I had upgraded the stock HL's of my alto with phillips rally 100/90 bulbs.. A few months back one of the bulb's high beam conked off so promptly replaces it with a rally 100/90 bulb. A few weeks back, even the other bulb's high beam went kaput, when getting a replacement the dealer gave me Essential Power 100/90 with rally written in small letters. Now my question is, what is the difference between these two products Rally and Essential Power. Specwise and appeareance wise both are identical. |
| | #2790 (permalink) | ||||
| BHPian | Quote:
![]() Quote:
__________________ Ice,Ice....My Baby !! [Pearl silver Zen Estilo Lxi,May 2008] [Moonbeam silver M 800,March 2003 -Sold] | ||||
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
