Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 24th April 2009, 14:54   #2806 (permalink)
Have a LS Magnum Diesel and want to upgrade the headlight bulbs. But without changing the wiring or installing any relays. Need it for a City + Highway combination. Can you suggest and if possible a place to buy in Gurgaon or South Delhi.
kewlferrari is offline   Reply With Quote
Old 25th April 2009, 10:46   #2807 (permalink)
ashthedivx's Avatar
Try sourcing Philips Xtreme Power. They are 55/60 with 80% more lighting i.e. you'll need not to change any wiring or relay. New Optra Headlights are H4 i think.
Originally Posted by Zahir View Post
Dude I totally agree with you on this. I've got the exact same setup and the highbeams actually fall shorter. High beams are a joke in my car...
Whats the wattage on the diamond vision? will it melt the angel eyes?
I'm basically looking for an option that will make the high beams comparable to the HIDs without causing any damage to the setup. I'm currently on osram nightbreakers. I think they are 55w
Diamond vision are 55/60 and will not melt angel eyes anyways. Diamond vision is the only effective option to give HID like effect, but beware light throw of diamond vision ain't that good. It is more or less same as regular 55/60 wattage bulbs.
__________________
Ashish K
"Ninety percent of the politicians give the other ten percent a bad reputation."
Old 25th April 2009, 10:48   #2808 (permalink)
Smile
Hi How much did you pay for the lights.
I recently had the lights changed , but am not very happy with the high beam throw. I own honda city. any suggestion to improve the high beam throw?
Originally Posted by ferrari_driver View Post
I have installed the HID Conversion Kit of Philips (Made in Germany) yesterday only. However, the alignment of the two lights was improper which I am trying to get fixed from a GM workshop (hope they agree to do it for my optra given its not originial equipment)
The dealer informed me that there is no warranty given by Philips but he has given me a 1 year warranty (in writing on a proper bill which I got after paying 12.5% VAT) excluding the bulbs.
Would anyone have an idea as to :
a) How much would the bulbs cost in case they fuse?
b) In case GM refuses to align the lights, will the dealer (from whom I have bought it) be able to do it properly?
Also, is there a remote chance of the reflector (not the coupler) melting due to intense heat?
dhir_d is offline   Reply With Quote
Old 26th April 2009, 04:18   #2809 (permalink)
Zahir's Avatar
Again, any one know a bulb better than Osram Night Breakers? Is vision plus better? Also is Vision Plus yellow light?
__________________
Suzuki Swift DDiS(White) 2009
Mahindra Renault Logan DLS(Sahara Gold) 2008
Fiat Palio 1.2 ELXPS
2002
Zahir is offline   Reply With Quote
Old 27th April 2009, 17:39   #2810 (permalink)
Vision Plus is yellow light. Recently upgraded to Vision Plus after using Crystal Vision for almost an year. They are great lights but I feel they are more directed towards the ground even on High beam. Maybe I need to get the headlights adjusted properly. Regarding if they are better than Night Breakers, maybe not, somebody else may like to comment.
dhondusaxena is offline   Reply With Quote
Old 3rd May 2009, 03:27   #2811 (permalink)
I had Osram night breaker headlights. Today i noticed that left side low beam stopped working.
Does this mean that I have buy a new one? Or something wrong with wiring?
I bought it only in Aug 2008. I would say very low lifespan.
If I need to buy new one, planning to put 90/100 headlights on my Accent CRDi.
Do I have to put in extra relays? Would the current wiring be able to handle it?
anToNIcHeN is offline   Reply With Quote
Old 3rd May 2009, 09:43   #2812 (permalink)
phamilyman's Avatar
What about halonix 90/100 in swift after installing relays? I am getting quotes of about 2k - which i know is high.
anyone got it done in gaon? prices?
Also what is the lifetime of reflector - i was warned that it may melt reflectors by Apra staff.
Old 3rd May 2009, 12:35   #2813 (permalink)
Hashim's Avatar
Both things are possible, check the bulb first, there are three wires connected to bulb, black one is of ground and then the other two are for low and high beam. Yellow is for low and blue is for high beam (may be different in some vehicle). Attach a multimeter (or a blub) to black and yellow and turn on the headlight on low beam, if multimeter show 12v (or bulb lights up) then wiring is ok.
Regarding Accent, yes you will need to attach relays to handle higher wattage bulb.
__________________
Maruti 1000 | Yamaha Gladiator
Hashim is offline   Reply With Quote
Old 3rd May 2009, 14:53   #2814 (permalink)
ankitahuja's Avatar
It's a damn good option to upgrade to that. I prefer Philips Rally over the Halonix +60 but then it depends on what you like.
Both bulbs will increase the light intensity, Rally is much brighter but then you compromise a bit on the throw, and vice versa for the Halonix.
Bulbs and kit will cost you not more than 1.1k with Philips Rally and .9k for Halonix.
There is a ROOTS kits for sale in the classifieds
Oh and yes, the reflectors will NOT melt. There are too many people here running a 100/90 set up on the swift.
__________________
åĐïğŧėđ Tŏ Ÿoů...
Old 3rd May 2009, 15:36   #2815 (permalink)
phamilyman's Avatar
wokay. thanks.
I will go for the bulb that has the maximum throw - even now, its throw which is why I'm considering upgrading - not brightness.
And thanks for the heads up, but i'll see. If you're running 100/90 without the kit, umm why would a swift need it?
Old 3rd May 2009, 15:43   #2816 (permalink)
Eddy's Avatar
Don't forget telling me BEFORE you do the upgrade. I am in two minds whether to do it or not. Might just tag along.
__________________
Car is no longer a luxury; parking space is.
Swift VDI(ABS) Sep 07 - 53K Kms
Ford Ikon Flair Sep 04 - 70K Kms
Eddy is offline   Reply With Quote
Old 3rd May 2009, 16:06   #2817 (permalink)
ankitahuja's Avatar
wokay. thanks.
Try both bulbs to see how the Swift's reflectors respond.
I'm not running 100/90 without the kit. I already have a ROOTS wiring kit that used to come with bakelite holders. I bought this other kit only because it had ceramic holders and I wanted to upgrade to 100/130w. Was not sure if the bakelite holders would cope up with the heat (but now I believe they do).
Keeping in mind that my HL assemblies are brand new, I decided against 100/130 bulbs to avoid blackening them out right now. Will probably upgrade further after some more time.
__________________
åĐïğŧėđ Tŏ Ÿoů...
Old 3rd May 2009, 19:31   #2818 (permalink)
Epic's Avatar
Originally Posted by Epic View Post
Hi Friends,
I had fitted a HID kit for the headlamps of my Swift. I was advised to go in for the P4 HID kits of 6000K. These were fitted in November 2008 and also LEDs for my parking lamps. However, the LED bulbs fused after a month and so did ballast of the left headlamp. As the HID kit was under warranty, i had the same replaced free of cost and changed the LED to ones of a better quality. After a little more than a month, the LEDs fused again and just yesterday the left headlamp failed. This time the bulb had fused. I had the bulb changed again under warranty.
The HID kit has not even completed 6 months but has failed twice already. The LED parking bulbs always seem to fuse but i never have an issue with regular white bulbs. Again, why does only the left ballast or bulb fuse? Ive asked the distributor the same and he claims that sometimes they have encountered multiple complaints with certain cars only, but otherwise the kits have worked perfectly. He however does not claim the kits to be faulty nor does he claim an issue with the electricals of the car.
Can anyone please help me with this issue? I am also planning to fit HIDs in my fogs but reconsidering due to these reliability issues.
Epic
Hey guys,
I need some help with the above.
Epic is offline   Reply With Quote
Old 3rd May 2009, 20:24   #2819 (permalink)
Thanks for the info. I shall check this up.
The reason why I asked. sometime back, I had gone to a car accessory shop looking for upgrade. The person over there told me that, "you dont require extra relays and wires for Accent. Stock wiring in them could already handle the extra wattage". Hence I asked. So, you are saying that I MUST go for relays. right?
Old 3rd May 2009, 20:35   #2820 (permalink)
Hashim's Avatar
In that case check the existing headlight relay, there is only one relay to control both headlamps and there should be wattage mentioned on the relay. The realy should be atleast 200W to handle 90/100 bulbs.
These accesories shop people often don't have much technical knowledge, even a lower wattage relay will work but in long run it will melt and headlight will fail to work.
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
