Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 17th May 2009, 02:36   #2881 (permalink)
Ravveendrra's Avatar
Default Not blue - just less yellow.
Originally Posted by Ravveendrra View Post
I need to change the bulbs in my GTX, (H1 & H7). Any idea where I can get Philips Extreme Power or Osram Nightbreakers in Hyderabad or Secunderabad.
I am a little apprehensive about the Nightbreakers as they have a blue tint. I would prefer plain (uncoated) bulbs giving out the white-yellow light.
I might be tempted to go in for xenons if I can get them in the <4200K light spectrum. Does anyone have an idea of a reliable source for xenons in this town.
Cheers and thanks in advance,
Originally Posted by jraj View Post
Spot on.I switched to Nightbreakers in my Petra and was very happy with the decision until monsoon arrived in Chennai.
They are pathetic in the rains.Have to change again before this monsoon
After having checked around, I was not able to get 'Extreme Power' as most guys stocked only some blue coloured bulbs from Philips that screamed "4300K" on their packing. I was however able to get night-breakers and on checking them out, found that they were not blue or anything just less yellow.
I have fitted them (a pair of H1s for the high beam and a pair of H7s for the low beam) and the light has improved. I got the bulbs at Sproket on Dharam Karan Rd. Ameerpet. All 4 bulbs set me back by about Rs.3K.
I am keeping my fingers crossed about their performance in the rains.
Cheers,
__________________
Live to drive!
(For commuting - take a bus)
Ravveendrra is offline   Reply With Quote
Old 17th May 2009, 14:00   #2882 (permalink)
Cheers,
you can purchase pair of extreme power bulbs from
PowerBulbs - Car Bulbs, Headlight Bulbs, Xenon Bulbs from Philips and Osram, including Philips Xtreme Power and Osram NightBreaker globes.
i have used their services before and they deliver in india
they even have sale running on on their website..
devenashani is offline   Reply With Quote
Old 17th May 2009, 17:01   #2883 (permalink)
white_vdi's Avatar
powerbulbs in on ebay uk as well and its much cheaper there. i source my bulbs from them only.
__________________
rain and my swift....thats all i'll ever need!!!!!!!!
white_vdi is offline   Reply With Quote
Old 18th May 2009, 03:11   #2884 (permalink)
CDM
Hi everyone,
I am sharing some information and need some guidance regarding Innova headlights.
As someone who drives extensively on the highways, i wanted to upgrade the headlights of my Innova. Not that the original headlights were bad but just wanted to make them better.
I have made two changes. First, I have added fog lights (my Innova G4 came without them). The fog lights that I have added are (supposedly Taiwan made) ones sold under the name Coozo, etc. Even Galaxy Toyota in Delhi sells them. I bought mine from Lajpat Nagar for Rs. 2500. They came as a complete kit with relay, wiring, switch, all of which fitted perfectly in the Innova without any wire cutting at all. The main connections were made to the battery and the switch was also connected to the cigarette lighter for the led inside the switch. Frankly, even though the fog lights look asthetically very good, I am disappointed with their performance and would not recommend them to anyone. The light beam extends for no more than 15-20 feet and is not particularly bright. Need to wait for some fog to see if they really work in the fog!
The second change that I have made is that I have replaced the standard headlamps for Philips X-treme Power H4 60/55W lamps. The lamps cost me Rs. 850 for a pair and are German made. The increase in the light is quite good and easily discernable. I was told by the shopkeeper that since there is no increase in the wattage of the lamps no change in the wiring or holders would be required.
My query is whether the shopkeeper is right? I feel that the extra light must be drawing some extra power and the bulbs must be generating more heat and therefore, do I need to change the holders or wiring? I don't want to end up with melted holders or a burnt wiring. Also, what about the headlight itself, does this need to be changed in case bulbs are changed. I mean can the plastic / synthetic headlight take the extra heat, if any.
Any guidance would be helpful. Thanks in advance.
CDM
CDM is offline   Reply With Quote
Old 18th May 2009, 08:11   #2885 (permalink)
greenhorn's Avatar
CDM, foglamps dont throw a longer beam, but a wider beam. try comparing the beam with the fogs that came OE with an innova
nope , you dont need extra wiring with those lamps. the catch with them is that they will have shorter lives than regular bulbs
__________________
'07 Indica DLG - Almost a DLX
Old 18th May 2009, 10:20   #2886 (permalink)
white_vdi's Avatar
+1
no harm will be done to the headlamp with xtreme power. and shorter life doesnot mean a couple of months. they will last for quite some time. dont worry!
__________________
Old 18th May 2009, 16:56   #2887 (permalink)
products they sell on ebay uk are some time refubrished/used, moreover the packing is also not original, may be I was the one who received this, they have specifically mentioned on their ebay store terms, that the products are "return or overstock product"
since then I have been using their website, and receive the fresh goods. anyway this is just for info.
Old 18th May 2009, 17:08   #2888 (permalink)
CDM
Thanks Greenhorn and White_vdi. That gives me some peace. Will try to compare the fog light beam with the OE.
Old 18th May 2009, 22:39   #2889 (permalink)
white_vdi's Avatar
devenashani i have ordered 3 sets through powerbulbs on ebay and all looks brand new and unused. it might depend on the seller as well.
__________________
Old 18th May 2009, 22:48   #2890 (permalink)
pras.oct25's Avatar
I switched over from the philips power xtreme, to the philips 100/90w bulbs with roots wiring kit. Seems like I should have done this a long time back after I found the experiment with the power xtreme proved fruitless.
My only worry is that they place the wires on either side under the bolts and fasten them down, and theres a connection to the battery as well. Is this an issue when I give the car in for service? Will they raise any unneccesary questions regarding warranty, and what if the technician removes one of the wires (un)knowingly during service - this will affect the headlights right?
__________________
U get to the end of the rainbow n u find the leprechauns booby trapped it!
Hyundai Verna VGT CRDI SX ABS 14/10/08
pras.oct25 is offline   Reply With Quote
Old 18th May 2009, 23:36   #2891 (permalink)
Don't worry! At least one in five cars that come in for service would have a relay and the associated harness for headlight upgrades, they are well aware of it and also they wouldn't crib about it for warranty - unless something goes wrong _specifically_due_ to the extra headlight wiring and relay that you installed !
techn0l0gist is offline   Reply With Quote
Old 19th May 2009, 10:45   #2892 (permalink)
knp
friends, I am planning to place the order at powerbulbs.com for Santro.
I am looking for Philips X-treme power..
so, do I need to go for H1, H4 or H7? I am looking for replacing my high beam bulbs?
pls suggest me.
knp is online now   Reply With Quote
Old 19th May 2009, 11:36   #2893 (permalink)
Default 130/100 headlight on the highway
Originally Posted by yatinchoubal View Post
Hey guys,
I have installed a Philips Rally 130/100 W, with relay. It also has ceramic holders. I m planning for a long tour. But Im worried, now, if the lights will blow off, due to excessive heat.
Can somebody please give me advice on this.
So Yatin, how did ur car take to the superpowerful 130/100 headlight on the highway? it would be great to hear ur experience so that I can try the same thing on my Accent.
Thanks,
Harsha
__________________
If you're incompetent you have to be honest, and if you're crooked you have to be clever.
harsha.cs1 is offline   Reply With Quote
Old 19th May 2009, 15:44   #2894 (permalink)
I have used this relay kit in 2 to 3 cars and never faced any problem with service station.. may be it's to common for them to complain.
Old 20th May 2009, 14:24   #2895 (permalink)
umang dutt's Avatar
I am looking for either of the following in Ahmedabad for my Safari (in order of preference)
1. Osram silverstar +50%
2. Philips Extreme power plus
3. Osram Nightbreaker
Any idea where I could get them in Ahmedabad ? From what I understand that there are a lot of fakes floating around so it would help if the person was reliable even if he charged a little more
Thanks in advance
__________________
Umang
Tata Safari GX (Cycus Grey + Arctic Silver)
umang dutt is offline   Reply With Quote
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
