| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #2926 (permalink) |
| BHPian | How is the performance of the nightbreakers in the monsoon? in the rains, does it effect the visiblity? or is philips crystal vision better?
__________________ Alpine ida X 200 | Blua GTA 450 | Bull CS525.75 | Velocity VXS 12 '00 Ford Ikon 1.6 ZXi '05 Pulsar 150 |
| | #2928 (permalink) |
| BHPian | Hi, I am trying to upgrade the bulbs on my new Ford Fiesta(2008) version. I have checked in a lot of places and I was disappointed to hear that the 100/90 conversion cannot be done with the Ford Fiesta. I was also adviced by one of the workshop guy that I can simply swap the bulbs to higher power watt bulbs without any relay/wiring kits. I need your help guys. I am planning a long drive to Kerala from Chennai and the stock lamps are not adequate. Thanks in advance ![]()
__________________ Interviewer: The helmet has a special meaning for many drivers! How important is it to you? Kimi: It protects my head. |
| | #2929 (permalink) |
| BHPian Join Date: Mar 2006 Location: Trivandrum
| Hi, I got the bosh 90/100 bulbs to replace philips premium 90/100 bulbs from stanes motors, trivandrum. The bulbs were RS: 160/pair. I was using the philips and now bosch without any modification to my stock wiring (just swapped the bulbs). Need to check the difference and will post the details. I think for fiesta also we can just swap the bulbs upto 90/100.
__________________ ===================== Baleno LXI BSiii 2006 185/65/R14 GT3 Alloys Wagon R Lxi 2007 Tvs Star City 2006 ===================== |
| | #2930 (permalink) |
| BHPian Join Date: Jul 2007 Location: Bangalore
| I had upgraded my headlamps from stock to 100/140 about a yr ago. Few months back, high beam failed. The problem was some loose wires somewhere. The mechanic at that time adviced against 140W lamps and suggested going for 90/100Philips lamps. Even I was not very comfortable with the idea of 140W lamps so changed them to 90/100W. Now last week again high beam failed. Again some lose connection! This time the mechanic(a different one this time) said that the fuse which is installed is of very high capacity(30A). He said replace it with 15A one. Now I am not sure what rating should I go for? I know Volt * Amp = Watt. Initially max watt required was 100+140 (when using dipper both low and high beams are on) Hence A = 240/12 = 20A. Now A = (90+100)/12 = 15.8A As per this calculation, 15A fuse will blow off the moment I use the dipper+low beam. What rating fuse should I use?(say 18A or 20A) Is my arithmetic above correct? Regards,
__________________ Mohit Finally...Esteem VXI. |
| | #2931 (permalink) |
| BHPian Join Date: May 2009 Location: Kottayam
| Hi folks Can anyone of you help me in upgrading the headlamp lights of my Indica Vista? Have any of you done it? The H1 is to be 100 w and H7 80w. Today, the technician tried with a PMP wiring harness, but the ceramic holder wouldn't match. Also there was no suitable connector to match the car's wiring. Any idea where I can get these? Also please inform me if the Philips Rally H1 & H7 bulbs are good.
__________________ In the depths of winter, I finally learned that there was in me an invincible summer. Albert Camus. |
| | #2932 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| If its swapping the HID bulbs it might be possible if they are of same type. Illumination will depend on the match of the bulb with the reflectors of Accent once the swap is done.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #2933 (permalink) |
| Team-BHP Support ![]() Join Date: Oct 2005 Location: Hyderabad
| I think he will need a complete HID kit including relays, reflector and all. Its not a straight fit. And that may also mean alterations not only in terms of electricals but also the headlight cavity etc. |
| | #2934 (permalink) |
| Yup i guess first thing is to figure out if accent has the same type of bulbs aka holder type H"x", so that one can even think about a swap in the first place. HID are designed for very different kind of reflectors and or projector set ups unlike normal halogens ![]()
| | #2935 (permalink) |
| BHPian Join Date: Mar 2009 Location: Bangalore
| Is there any foglamp upgrade for Tata Safari? I think it is a H3 type. The Philips distributer asked me to change it to 90/100. But I did not change it since increasing wattage without using relays may damage the wiring. I recently upgraded the headlamps to Philips Extreem Power 60/55. It costed me Rs. 800/- at A.K.Traders in bangalore. I feel the light is slightly whiter than the stock ones (which is good). Also the throw is good for high beam. I am unable to compare it with the stock ones because I never used high beam of stock ones in dark roads (outside the city). But on Extreem Vision I went on a long drive. I observed lot of oncoming vehicles were requesting me to dip the light by doing it themselves..... so I think it should be brighter than the OE ones. Also on the package it said 80% more. Dont know whether it is really true.
__________________ 2009-Till Date - Tata Safari 2.2VTT - King of the Road 2001-Till Date - M800 AC 2007-2008 - Nissan Altima Ltd Edition |
| | #2936 (permalink) | ||
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay
| Quote:
cya R
__________________ The memory of you will ride by our side forever. | ||
| | #2937 (permalink) | |
| BHPian | Quote:
I saw H3 3000K HID at Evo/Satya few months back. Yellow light, suitable for fogs. Ask him if he still have them in stock, if you are interested to go with HID instead of high wattage halogen in stock fogs. Not only electrical wiring but also heat produced will be an issue to go with high wattage halogens in stock fog lamp assembly. | |
| | #2938 (permalink) | ||
| BHPian | Quote:
@ anuj1237 no it's not possible to do the install as the Accent has H4 with twin point bulbs where as the Civic has separate dim and bright bulbs viz H1 and H7. | ||
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
