| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #3001 (permalink) |
| BHPian Join Date: Feb 2009 Location: Bangalore
| Can any of the users give me a comparison between 1. OSRAM Night Breakers, 2. Philips Extreme Vision and 3. Philips Crystal Vision ? I see different recommendations here and have not been able to make up which is suitable under what circumstances? This is for Stock replacement of H4 bulbs in i10. Thanks to all in advance. |
| | #3002 (permalink) |
| Newbie Join Date: Aug 2008 Location: Bangalore
| I switched over to Swift from Wagon-R. & it’s about an year old now. ICE, Wheel/Alloys upgrade etc are over. About lighting, I upgraded to Night Breaker & fogs bulb to H7 55W Night Breaker (bought thru e-bay). I’ve gone thru the lighting thread (almost all pages) & now confused more. I thought of going for Phillips Xtreme. But, I read many reviews/opinions that for best illumination of road switching to 100/90 would be the best option. I found that all these 50+, 80+, 90+ etc. are marketing tricks & nothing like 100/90. I decided to go for Rally 100/90, but I never seen how these are. Any expert opinion on Phillips Xtreme compared to 100/90? Among the group which 100/90 is the best? Are there bulbs available in 55/100W? I know this must ‘ve been answered somewhere in the thread, but I rqst for suggestion & this might be a useful info for new members Tnks Post EDITED since it contained various [FONT], [COLOR] and [SIZE] tags. Posting with such text formatting should be avoided on Team-BHP as it is inconvenient for members to read post. Kindly go through Announcements section before proceeding. Thanking You for your anticipated co-operation The Team-BHP Support Last edited by Jaggu : 30th June 2009 at 11:19. Reason: Removing font tags, thanks. |
| | #3003 (permalink) |
| BHPian | Ok i have a question here - Can i run these lights AIRCRAFT LANDING LIGHTS / HALOGEN LANDING LIGHTS on a gypsy?? What will be the impact or using a 250watts light?
__________________ -Kaushik OHC Vtec - Gypsy King - Pulsar150 - Kinetic Honda "The crashes people remember, but drivers remember the near misses" |
| | #3004 (permalink) |
| Senior - BHPian Join Date: Dec 2006 Location: Bangalore
| yes you can , get a relay which is rated for operational currents of more than (250/12) ~ 21 amps and you should be safe.
__________________ FREEDOM EXISTS ONLY WITH POWER Pete'd Hyundai Verna CRDI VGT '06 Maruti Suzuki Swift LDI '07 Maruti Alto Lxi '02 |
| | #3005 (permalink) | |
| Team-BHP Support ![]() | Quote:
Two 100W bulbs in the main headlamps means 200W. One lamp will draw more current than 2 headlights,. If you want brightness without upgrading your alternator, I suggest you look at Xenon. Buy two cheapo fog lamps, and fit H3 Xenon in them, cost = 4500rs approx for everything.
__________________ Reclaimed, wrung dry and recycled....! | |
| | #3006 (permalink) | |
Watts / Volts = Amp Your Car battery is 12 Volts. Your lights need 250 Watts. So you need about Amp = 250 / 12 = 21 (approx) But your car battery has less than a fourth of that. When the battery is being charged by running the car engine, the drain is still enough to dry it out. Any such mod will require a couple more batteries and some very thick wiring.
__________________ Ever catch yourself listening to a nice song on the radio and dedicating it to your car. | |
| | #3007 (permalink) |
| Team-BHP Support ![]() | What do you mean that battery has less than a fourth of that? Battery is rated at Ah. For example a 65aH battery means that if you draw 65 Amperes the batter will die in one hour. If you are running 21Ampere light, your battery will run out in 3 hours from full to flat. Now if your alternator is supplying more current than consumed by system, your battery will keep charging, however if drain current exceeds charge current battery will die. So if you intend to use the light for couple of minutes in emergency, its okay, but if you want them as running lights, a strict no no.
| | #3008 (permalink) | |
| Team-BHP Support ![]() | oops. confused with my bikes battery. ![]() Quote:
![]() The primary task of a battery is to store electric current chemically. Make it available when its needs and be able to deliver large amounts in a short period of time. The last being the difference between a battery being used in a car and an inverter. A load of 250 Watts will be difficult to sustain by the stock battery. So the battery needs to be upgraded and also the wires.
| | #3009 (permalink) | |
Lets see in a stock setup Headlights = 200W Tail lamps = 40W Front Fogs = 100W Music system = 50W onwards AC blower = 100W+ Fan = 250W At any given time its around 50A of current at peak load with AC and headlights working 250W will add 20A to that load. So if the user is not running the headlights, 250W is okay, but with headlights on, this will be an issue, and battery will slowly start to drain. Normally cars have 45Ah batter, SUVs have 75-80Ah battery, and diesels have 55Ah battery(indica etc.,) So using a 250W spotlamp for 10-15 minutes is not an issue, but using it as the main headlight, i,.e using 2 of them is not really recommended.
| | #3010 (permalink) | |
| Senior - BHPian Join Date: Aug 2008 Location: Bangalore
| Quote:
I have used all 3 bulbs and here are my opinions on each of them. Steer clear of the Crystal Visions, they are useless at lighting up the road especially in the rain and are mere "show off" light as they emit a white light. Osram Night Breakers are good performance. But they tend to fail after a few months of extensive usage. Philips Xtreme Power bulbs are good. They actually provide much better lighting than the stock bulbs. Also, the beam throw is much wider on the low beam and the high beam has a good throw. The light emitted is brighter and whiter than when compared to the stock halogens. Hope this helps. Cheers, gpa
__________________ Maruti Suzuki Alto (May 08) - 23,000 KMS Hyundai Santro (Feb 05) - 59,000 KMS | |
| | #3011 (permalink) | |
| BHPian | So in that case using 2 spot lamps having a total of 500W is not recommended for a long duration. But if i use it for say 5 min will it still load the alternator/battery causing any kind of permanent damage?? and when will be the next best time to switch the light back on again?? Quote:
__________________ -Kaushik OHC Vtec - Gypsy King - Pulsar150 - Kinetic Honda "The crashes people remember, but drivers remember the near misses" | |
| | #3012 (permalink) |
| I am not expert. However, I have Phillips Xtreme on myswift from last 4-5 months and I had 100/90 on my Indica. Here are my observations. 1. Phillips Xtreme : Really good, till now no issues. Excellent visibility. No changes in wiring, plug and drive. 2. 100/90 : Firstly this is wattage. In the beginning, it was better than Phillips Xtreme, however, within 2-3 months, the refectors started to darken. Additionally, needs rchange in wiring and it is not street legal. So my vote to Phillips Xtreme . regards, -manju |
| | #3013 (permalink) |
| BHPian Join Date: May 2006 Location: mumbai
| Originally Posted by nishantgandhi (Auto Lighting thread : Post all queries about automobile lighting here) @SRS - Any specific reason why you want to go for the Xtreme power series? Would be good to know how its different from the normal 'Rally' halogen bulbs? If you are not in a hurry, I can get you in 2 weeks time. My mechanic is out of town. He sources everything for me from Opera but at good prices. Hi Nishant I too am keen on getting my headlamps changed for the monsoons. I have a Indica Xeta GLS. Do let me know as well once your mechanic is back in town Cheers |
| | #3014 (permalink) | |
| Quote:
I feel it's better to stick to 55/60 instead 100/90 which shortens life(shine) of reflectors. I would like to try Xtremes, I 've to go to AK Traders & pick them up. Thanks for the response Manju. Suda | |
| | #3015 (permalink) | |
Also. whats your alternator capacity? Its usually written on the alternator. Make sure that the circuit controlling these lights is totally separate with its own wiring and heavy duty 50A switch . These are going to be seriously thick wires.
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
