| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #3032 (permalink) | |
| BHPian | Quote:
Hey Green horn , thanks for that input mate, now how can we do this?. Will changing the timer sort this issue, the catch here is that the hazard works perfect, it is the same bulbs and the same current source. The issue is only when I use the turn signals. Please advice mate..
__________________ What's life without a passion.. | |
| | #3033 (permalink) |
| Senior - BHPian | easiest way is to connect the old indicator bulb itself in parallel. otherwise eBay.co.uk Guides - Load resistors for LED indicator bulb replacement
__________________ '07 Indica DLG - Almost a DLX |
| | #3034 (permalink) | |
| BHPian | Quote:
| | #3035 (permalink) |
| Team-BHP Support ![]() | Use this site for calculating resistor based on number of LEDs and voltage,. When your car is running expect 14V as the driving current MetkuMods - Because you love your hardware!
__________________ Reclaimed, wrung dry and recycled....! |
| | #3036 (permalink) | |
| Senior - BHPian Join Date: Aug 2008 Location: Bangalore
| Quote:
It is quite likely that the big filament has burnt out, which is why you see the dim flash when you lock/unlock your car, but not when you step on the brake pedal. A change of bulb should solve this problem.
__________________ Maruti Suzuki Alto (May 08) - 23,000 KMS Hyundai Santro (Feb 05) - 59,000 KMS | |
| | #3037 (permalink) |
| Newbie Join Date: Apr 2009 Location: trivandrum
| Hi Friends I would like to upgrade my factory fitted headlamp bulbs in skoda fabia to some which is more powerful. Specifically for driving in highways with little or no external lighting available. Whats the best option? The service personal told me that bulbs are available for 2500INR but wont recommend the same as its not good (does not last longer, damage to existing circuit) regards
__________________ Fabia TDI and Yamaha RX-100 |
| | #3038 (permalink) |
| Team-BHP Support ![]() | You cab go for Osram silverstar +50%, they are 60/55W and cost 350rs a pair. Other options are Philips Xtreme power +80% which cost around 700rs a pair. Both these have 60/55W and will not overload your system.
| | #3039 (permalink) | |
| BHPian | Quote:
Till date that hasn't happened.So can I be assured that all is well? I do monthly battery maintenance routinely.
__________________ Ice,Ice....My Baby !! [Pearl silver Zen Estilo Lxi,May 2008] [Moonbeam silver M 800,March 2003 -Sold] | |
| | #3040 (permalink) | |
| Senior - BHPian | Quote:
a filament bulb is electrically identical to a resistor ![]()
__________________ '07 Indica DLG - Almost a DLX | |
| | #3041 (permalink) | |
| BHPian | Quote:
A bit late with this great idea..just ordered for the 4 load resistors from Hong Kong. ![]() Thanks for the idea.
| | #3042 (permalink) | |
| Team-BHP Support ![]() | Quote:
Since your battery is not going dead, it means you do not overdraw for long durations of time
__________________ Reclaimed, wrung dry and recycled....! | |
| | #3045 (permalink) |
| BHPian Join Date: Jul 2007 Location: goa bangalore
Infractions: 0/1 (4) | I presume xenons = HID. Is it a simple Plug and play or one needs serious wiring etc. costs please?
__________________ Fiat 1975 sold Omni 1995 sold Matiz 2000 handed down Dzire VDI Jul 2009 |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
