Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 30th July 2009, 19:59   #3121 (permalink)
vid6639's Avatar
Originally Posted by msbehave View Post
Hi all,
Am a novice so would really appreciate your help. My gypsy has hella foglamps. There was a scrap object that broke the glass of one of the lamps while parking in a dark garage. Does this mean I have to buy a new set or is it possible to just procure glass for it? The bulb is fine, just the glass has cracked. Thanks!
You will need the full headlamp cluster i.e. the glass and the back. It is sold as a single sealed unit. Bulb you can use in the new assembly.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 30th July 2009, 20:04   #3122 (permalink)
aaggoswami's Avatar
Not exactly the lighting query, I have a couple of questions regarding out 2005 E-III Baleno.
1) After a minor accident, the headlamps were changed. Now the focusing in meaningless. Very very short throw, in high beam the light in focussed in front of right heamlamp.
How to adjust the headlamps. I am not able to help myself. I have opened the hood only to find that there is no screw to adjust the headlight. Dealer was asked to fix the issue, but he just worsened the case.
We have atleast four 4 close shaves with major accidents till now, specially near Junagadh region.
2) Is it possible to just plonk in 100W H4 in Baleno without relay ? My main query is whether the relay is required or not. From my knowledge, it is indeed required, but I have seen quite a few cars without them running reliably.
__________________
Never Dream because broken dreams hurt the most.There is no market for emotions.
EVENTUALLY FATE DECIDES EVERYTHING.
aaggoswami is offline   Reply With Quote
Old 30th July 2009, 20:11   #3123 (permalink)
msbehave's Avatar
Many Thanks vid6639. bought the gypsy recently and so will be spending more time here and really looking forward to it!
__________________
2005 Maruti Swift Zxi
2001 Gypsy MG413W
msbehave is offline   Reply With Quote
Old 30th July 2009, 20:13   #3124 (permalink)
pulsar56's Avatar
Will I be able to fit them on my 1998 Zen's bumper?
which one would be a better choice?
Amazon.com: Navigator NV-510W Fog Light Kit: Automotive
Amazon.com: Hella H71010241 Optilux 55-Watt Fog Light Kit: Automotive
__________________
Turn right to go left! Guess what? I tried it, and you know what? This crazy thing happened - I went right! - McQueen
pulsar56 is offline   Reply With Quote
Old 30th July 2009, 20:18   #3125 (permalink)
gpa
gpa's Avatar
aaggoswami,
This is very scary. Every headlamp assembly will have screws to adjust the beam. Why don't you get it checked at another MASS or go to a wheel alignment dealer and get it checked there? Most of them have a machine bu which they adjust the beam and they do a good job as well.
Is it possible to just plonk in 100W H4 in Baleno without relay? My main query is whether the relay is required or not. From my knowledge, it is indeed required, but I have seen quite a few cars without them running reliably.
Do not upgrade to a 100/90W bulb without a relay and ceramic holders. The electrical system of the Baleno is designed to handle a 60/55W bulb. Anything higher and you will have to put in a relay.
Those who are running a higher wattage bulb without a relay have done so by putting in a higher rated fuse which is a recipe for disaster as the strain on the electrical system will be immense and could lead to melting of wires.
__________________
Maruti Suzuki Alto (May 08) - 23,000 KMS
Hyundai Santro (Feb 05) - 59,000 KMS
Old 30th July 2009, 20:25   #3126 (permalink)
gpa
gpa's Avatar
Hi Benji,
Find my answers in bold.
Cheers,
gpa
Originally Posted by BenjiRoss View Post
Some simple queries:
1. How many bulbs should I change? - both of course if you are changing the ones in your headlamp cluster.
2. What are H4 and H7? What should I get for my U-VA? (Extremely basic query!) - Most headlamp assemblies have a H4, check your owners manual and it should be mentioned. Else, peer into the front of the glass in sunlight and look on the round steel base of the bulb and it will be mentioned there.
3. The Chevy dealer quoted a price of 1,800 for a pair (H7) and 300 bucks for fitting them. Obviously these are way too high! - Yes, these are astronomical even if your headlamp is a H7.
4. What is the Philips equivalent for NighBreakers? - Philips Xtreme Power bulbs (60/55W)
__________________
Old 30th July 2009, 20:29   #3127 (permalink)
gpa
gpa's Avatar
Originally Posted by siddharthdeb View Post
I want to know what are the best Bulbs that you can install in the car in STOCK form without overloading the electrics of the car (a.k.a blown fuses / melted bulb holder).
Hi Siddharth,
You can either switch to Philips Xtreme Power bulbs or Osram Nighbreakers. Both of them are of the plug and play variant and will not need any upgrade to the wiring or fitment of additional relays. The wattage is also 60/55W which means a direct fit into the holder of the Swift.
If you ask me which one I prefer, I'll go with the Philips Xtreme Power bulbs.
Hope this helps
Cheers,
gpa
__________________
Old 30th July 2009, 20:52   #3128 (permalink)
aaggoswami's Avatar
I
H4 is the dual filament headlamp bulb.
H7, H8, H9 and H11 are single filament. In some cars, we see two pair of bulbs. In this case they use individual bulbs for high beam and low beam, so they use single filament bulb.
H4 being dual filament comes with most of the cars, obviously it has two filaments, one for high beam and other for low beam.
Personally I have observed and experienced that dual filament bulbs found in Palio, Civic, Altis are better than the regular H4 equipped headlamps.
It depends on what your UVA has.
This is as per the best of my knowledge.
Correct and update me if I am wrong.
Originally Posted by gpa View Post
aaggoswami,
1) This is very scary. Every headlamp assembly will have screws to adjust the beam. Why don't you get it checked at another MASS or go to a wheel alignment dealer and get it checked there? Most of them have a machine bu which they adjust the beam and they do a good job as well.
2) Do not upgrade to a 100/90W bulb without a relay and ceramic holders. The electrical system of the Baleno is designed to handle a 60/55W bulb. Anything higher and you will have to put in a relay.
3) running a higher wattage bulb without a relay have done so by putting in a higher rated fuse which is a recipe for disaster as the strain on the electrical system will be immense and could lead to melting of wires.
Thanks GPA!
1) Called all of them, but each and everyone would say " Bring the car over here ". The end result is the problem is not solved and further the things are getting bad. Main reason is that they do setting at daytime. And most of them think I am a joker and they are the perfect humans to know what is best setting for me. Whenever I have worked asked them to work, the settings have gone bad. Recently my mom refused to travel at night in Baleno. We had take out M800.
I am frustrated to no end.
I have posted a few images in the thread that I will be posting here.
If you or any other user can help me finding that screw, do pin point. I am tired of taking car everywhere.
I think this is not the screw, so if possible just give tell me where is it located, if possible.
2) Quite expensive, I think I will first sort out focusing.
3) Fuse will not be touched at any cost unless there is some major issue. Thanks for warning me.
EDIT :
@siddharthdeb:
First of all, try some better bulbs from Philips with similar watts. This will be of help. If still this does not work, you will have to work on electricals. But first step is to buy some better bulbs. Philips nightbreaker is IMO the most sought after on this thread.
__________________
Old 30th July 2009, 21:00   #3129 (permalink)
gpa
gpa's Avatar
aaggoswami,
From the few pics you have posted, it looks like the headlamps have not been mounted in the right place. Also, the screws that you need to adjust to tweak the beam throw are just behind the cluster.
Focussing of headlamps (if using a machine) can be done at anytime of the day. If you are getting them focussed by parking in front of a wall, then its best done at night.
I am not too familiar with the Baleno's headlamp assembly, so you can check with other Baleno owners on ths forum.
Cheers,
gpa
__________________
Old 30th July 2009, 21:36   #3130 (permalink)
aaggoswami's Avatar
1) From the few pics you have posted, it looks like the headlamps have not been mounted in the right place.
2) Focussing of headlamps (if using a machine) can be done at anytime of the day.
3) the screws that you need to adjust to tweak the beam throw are just behind the cluster. I am not too familiar with the Baleno's headlamp assembly, so you can check with other Baleno owners on ths forum.
1) Can you elaborate ? How did you note this ?Or is it that the entire assembly is a different or odd ? The entire units were changed after accident.
2) All the places I visited, they did it with the help of a wall during daytime. Car was parked very near to wall.
3) I did check with RJstyles, he confirmed that there is a screw atop the headlamp assembly. But I am not able to locate it.
__________________
Old 31st July 2009, 10:25   #3131 (permalink)
the_maassk's Avatar
I posted these queries a couple of months ago in this thread but got no reply:
I'm not very happy with my U-VA lights. They're just about sufficient - especially on the highway.
I'm planning on switching over to Osram Nightbreakers with stock wattage.
1. How many bulbs should I change? - Two
2. What are H4 and H7? What should I get for my U-VA? (Extremely basic query!) - H4
3. Noone is Trichy has these lamps. I was considering buying them online from ebay or powerbulbs. Is there any way of getting them? The Chevy dealer quoted a price of 1,800 for a pair (H7) and 300 bucks for fitting them. Obviously these are way too high!
I had switched to Philips Xtreme Power 60/55W H4 lamps in the headlights on my U-VA around 8 months ago. They are wonderful and much better than stock. The pair cost me Rs. 1250 at that time. Make sure you get them from authorized dealers so that you get the originals.
__________________
"I do have a brain...God just forgot to wire it!"
Maruti 800 (Japanese model, restored!)
Chevrolet Aveo U-VA LS
the_maassk is offline   Reply With Quote
Old 31st July 2009, 10:34   #3132 (permalink)
the_maassk's Avatar
A colleague in office has a Baleno. Let me see if I can take some pics.
__________________
Old 31st July 2009, 12:29   #3133 (permalink)
tsk1979's Avatar
All cars have different reflector shapes, so what works in one car may not be as good in another.
I suggest you try before you buy.
In stock 60/55W you have 2 options
1. The 350rs/pair Osram +50%
These are quite good for some, but some have noticed no difference, however they are a good starting point, cheap and long lasting
2. The Osram nightbreaker +90% and Philips Extreme power +80%
These will have lower life, but give more light. Again try before you buy. Cost is 750rs/pair approx, but beware. Fakes are very common, so buy from a big reliable shop.
__________________
Reclaimed, wrung dry and recycled....!
Old 31st July 2009, 12:29   #3134 (permalink)
gpa
gpa's Avatar
Just seemed that things were not fitted the right way. To be honest, I wanted to ask you if the car has been involved in a frontal shunt. Just wait to the_maassk to post a few pics which should help you.
If the lights are being aligned by throwing the beams onto a wall, then it should be done at night. I'm surprised that they did not focuss the beam using the headlamp alignment machine. Can you check if any dealer indeed has such a machine and then get it checked there?
__________________
Old 31st July 2009, 13:03   #3135 (permalink)
the_maassk's Avatar
Okay. Here are the pics from my friend's Baleno assembly. I think they look the same as yours!
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
