| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #301 (permalink) |
| BHPian | I went to JC Rd. today. I was basically looking for Osram Silverstar 100/90 or atleast 60/55, but no luck. Instead i found Narva 100/90 with prices between 750 - 475 bucks. The shop which has ones for 475 had a Narva seal on the original Hard Plastic Box packing. Is this a good price for Narva. Also PMP wiring + cutout was Rs 450. Anyone using Narvas here? Please suggest.
__________________ ______________________________ WagonR LXi 2004 (clean no mods) Swift VXi w/ABS 2007 (Llumar tints, Pioneer and JBL ICE) |
| | #302 (permalink) |
| Team-BHP Support ![]() | I use Narva's and have seen what Silverstar 60/55 can do the light from Osram 60/55 is same as narva, and cost you 250RS + you do not need a relay and your service station cannot deny you warranty too. Narva's are brighter than bluevision etc., and at the same level as Osram 60/55W
__________________ Reclaiming.....! |
| | #303 (permalink) |
| BHPian | Thanks tsk. But i couldn't find any in Bangalore @ JC Rd. You mean i can get Silverstars @ Rs.250/pair? Bangy boys, can anyone please help me source a pair of Silverstar. I also need white parking lights. The guy at the shop showed me some local W5W bulbs @ Rs.30/pair. He said its white and would match with Narva. One stupid question. Is cut-out and Relay the same thing. One guy at a shop said they are same. he said Relay is required for horn and cut-out for Headlamps? Correct?
| | #304 (permalink) |
| Team-BHP Support ![]() | relay reroutes current, so that your OEM wiring designed for 60/55W does not go bust cut-out is a device to switch off things. For headlights you get a full wiring kit with relay and holders. You can go for either master or roots. Roots kit is expensive but can do 130W too, master kit is 100W. You can look at www.osram.co.in for bangalore distributor numbers.
| | #305 (permalink) |
| BHPian | Thaks tsk. Made some calls. Osram Silverstars 60/55 available @ 175/piece. :-). I am getting a pair tomorrow. Osram Bangalore Sales Manager = Satya Praveen 9341031097 Reliance Auto Agency (dealer) = Nilesh Gandhi 9880896117
| | #306 (permalink) |
| BHPian | Installed the Silverstars. :-( Not happy though. Its not at all White Light. its brightness, color of light is exactly similar to the GE Nighthawk 60/55 which i was currently using. Maybe a thin % better than stock. As tsk mentions that Silverstar = Narva (brightness), i may shift to Philips Rally 100/90. Any 4000K light (i like white light) with good brightness as Rally 100/90?
| | #307 (permalink) |
| Team-BHP Support ![]() | Get your aiming done first. The brightest white light bulbs as seen on a Santro and my indica have been the Narva's and to some extent bluevision. GE Nighthawk is better than stock bulbs, that why you see only slight difference.
| | #308 (permalink) |
| Distinguished - BHPian ![]() | Update on Hella Gold's: The left bulb high-beam went bust after nearly 2-3 months of usage so had to replace that. Likely reasons being (dealer says) don't use it on high-beam for than 30mins at a stretch since that'll cause heat builup & cause the bulb to fail, but on highways that's quite hard not to do. My thinking is that it's mostly because I do at times use both beams together which might have lead to the bulb getting heated & going bust. Anyways replaced it for Rs. 175/-
__________________ There is a very fine line between "Hobby" and "Mental Illness". |
| | #309 (permalink) |
| BHPian | [quote=tsk1979;418521]Get your aiming done first. [quote] Could you please throw some light. Is this to be done using the Leveler (0-4) given nowadays in all cars? I have done that, but the light doesnt move up and down. ![]()
| | #311 (permalink) |
| BHPian | i mean i have tried to aim at a wall with Low Beam as well as High Beam. When i slide the leveler up and down i cannot see any difference in the level/beam moving? If that is the case, i would go to service station ASAP amd also take some suggestions from fellow BHPians at our Bangy meet on 23rd Apr.
| | #312 (permalink) |
| BHPian | Update on Osram Silverstar 60/55 I used these for the first time in Bangalore roads yesterday night. Lights are bad. Definitely not +50% as they claim. Not worth the money. I was using GE Nighthawk 60/55 before as was much more happier. Its throw, brightness is much better than OSRAM's. I would change back to Nighthawk today evening. Planning to go for Philips Rally 100/90 next month. Wasted 350 bucks... :-(
| | #313 (permalink) |
| BHPian | I went through the whole thread on "Auto lighting" and had almost made up my mind on Osram Silverstar 55/60 for my wagon R Lxi (2007 model). The last post by 'hyper-VTEC' has put me back to a state of mind as equally confused as I was when i was reading through the first pages of this thread posted months back. Anyway here are my shortlisted headlights after going through the whole session over months on this thread: 1st Pref: Osram Silverstar 55/60 2nd Pref: Philips Vision Plus 55/60 Reason for the above choices: No alterations required on the basic settings of the vehicle. No known issues with the cops nor warranty. Reasonable pricing. Now I would like to hear from any of the above brand users to give a final go. Only a person who has used it in city/highway will have an accurate judgement. Feedbacks appreciated.
__________________ "Woods are lovely, dark and deep. But I have promises to keep and miles to go before I sleep." Robert Frost |
| | #314 (permalink) |
| Team-BHP Support ![]() | Okay guys, one thing about lighting which I have stressed before also. Its not the bulb only. The bulb "power" is just 20% of the equation. A very important thing is where the filament it. A bulb can be very very good in one reflector because the filament is right at the sweet spot, but lousy in another. Cheap chinese bulbs usually have this behavior. Even among Philips etc., sometimes you can get such a sample. Normally the probability of getting such a bulb is 20% and you cannot do anything about it. Automags normally test 5 bulbs, and if more than1 bulb shows little deviation, they don't rate it. If 1 bulb is faulty by a large margin, then also a failure. To experiment if you take 2 Philips vision plus, or any other brand bulbs, there is a chance that the quality of light you get is different. Thats why I say, put the bulb in your car and see. Ishan did the same. One side went Hella gold, and other side went Narva, and now he is a happy Hella gold customer, inspite of blowing one.
| | #315 (permalink) |
| BHPian | guys i am planning the put fog lamps for my zen 2001 model....i saw hella fog lamps square type can any one tell what will be the cost of those ..and also are their any other brand fog lamps whis i can go for........ Note from the Support Staff: Please avoid typing dotted messages. Try to keep the post as clean as possible. Thank you http://www.team-bhp.com/forum/indiancarpicture-365.html this kind of fog lamps....... Last edited by tsk1979 : 28th April 2007 at 12:55. |
« K&N Apollo air filter for my Swift Petrol??
Swift Mods : Post all queries / pics of Swift Modifications here. »
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 37 | 22nd September 2008 11:03 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 6 | 6th September 2008 10:46 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
