Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
LinkBack Thread Tools
Old 24th August 2009, 22:21   #3226 (permalink)
Fountainheader's Avatar
Originally Posted by humm View Post
How much do those bulb cost and whats the W? Btw whats the W of the existing original swift headlamp bulbs?
60/55W
You get Philips and Osrams in that range. Not sure of the costs. Dig through this thread, you might find some info.
__________________
Sarchasm - The gulf between the author of sarcastic wit and the recipient who doesn't get it.
Fountainheader is offline   Reply With Quote
Old 24th August 2009, 22:58   #3227 (permalink)
humm's Avatar
60/55W is the range of the original fitted bulbs or Philips Xtreme Power bulbs - Osram Night Breakers?
What W can you upgrade in the existing wiring and setup without creating any load in the Swift?
Originally Posted by Fountainheader View Post
60/55W
__________________
YoYo... Live n Let Live! :D
humm is offline   Reply With Quote
Old 24th August 2009, 23:01   #3228 (permalink)
Stock is 60/55 and so are the other 2 bulbs. I guess anything more than that, which is 100/90 I assume, will add significant load to the car.
I have Philips Rally 100/90 along with a Roots relay kit. The total cost me close to 800 bucks and installation another 200. Anyday cheaper than those Philips/Osram bulbs.
__________________
Old 24th August 2009, 23:48   #3229 (permalink)
Epic's Avatar
Using the 55w bulb will cause any burns in the reflector or any load?
I am not sure if the 55W bulbs will cause and burns in the reflectors but I dont believe there would be any extra load.
__________________
There is nothing better than an AMG. Not even another AMG! - Mercedes Benz.
Epic is offline   Reply With Quote
Old 24th August 2009, 23:53   #3230 (permalink)
Epic's Avatar
I have noticed that the reflectors of my fog lamps on my 2005 Swift are damaged. The silver reflective coating have developed cracks and also the edges of glass of the fog lamp is lined with dust from the inside. This totally destroys the look of the lamps and more over suppresses the intensity of light reflected on the road.
Ofcourse the only way to rectify this is to have the fogs lamps changed. However, I am sure that the lining of dust inside the fog lamp could be due dust entering due to an opening in the covering in wheel wells, but what could be the reason for the cracked reflectors?
Can anyone help me with the above issue?
__________________
Old 25th August 2009, 00:16   #3231 (permalink)
humm's Avatar
There is no bulb for the headlamps between 60/55 & 100/90 without relay modification?
Incase I decide to go for a 100/90 bulb for my swift, which is the best relay system to be used? Won't the bulb cause any damage to the head reflectors?
@ Epic: Probably a loose fitting of the fog lamp bulbs or the connectors have resulted in water and dust entering the fog reflectors and thus causing the damage? Had you changed anything related to the original foglamp?
Reflectors can crack because of the water, heat and dust combination.
__________________
Old 25th August 2009, 10:59   #3232 (permalink)
Epic's Avatar
Well no water has entered the fog lamp assembly for sure or else there would be signs of moisture and would also probably cause the bulbs to blow which is not the case. But yes there could be a loose fitting which has allowed dust to enter the assembly.
With regards to changes made, yes, I have changed my stock 35W H8 bulbs to 55W H8 bulbs. Could this be the reason of the reflectors being damaged due to extra heat caused?
Can the interior of a headlamp/fog lamp assembly be cleaned? If yes, what is the procedure?
Epic
__________________
Old 26th August 2009, 01:12   #3233 (permalink)
humm's Avatar
@ Eric: Moisture does enter reflector areas no matter what protective measure you take. The combination of moisture, dust, heat does result in glass getting spoilt and reflectors also get damaged.
The change of bulbs also results in whats happened with you.
Apart from that 4 years is decent time for a wear-n-tear.
__________________
Old 26th August 2009, 09:58   #3234 (permalink)
sunil.nv's Avatar
Default Osram Nightbreakers
Got Osram Nightbreakers H4 60/55 after some serious search in Bangalore, JC road for 1200 a pair. Philips extreme vision wasnt available and they said that there was no supply since 2 months.
sunil.nv is offline   Reply With Quote
Old 26th August 2009, 10:43   #3235 (permalink)
gpa
gpa's Avatar
Did you check with AK Traders who is the authorised stockist for Philips' automotive lighting range?
__________________
Maruti Suzuki Alto (May 08) - 27,000 KMS
Hyundai Santro (Feb 05) - 62,000 KMS
Old 27th August 2009, 19:12   #3236 (permalink)
beejay's Avatar
Default Light Force-
I was considering to fix a pair of Lightforce lamps for the CJ340.
Planning on the Lightforce Blitz. I have had good reviews from people who have already have them fit.
Any reviews on the same here?
__________________
I am going to pursue Galileo Galilee`s philosophy: my world is also round." Luigi Colani
beejay is offline   Reply With Quote
Old 27th August 2009, 19:24   #3237 (permalink)
Amar has a pair for his gypsy and Allan has some on his Orange MM550. Very nice light but quite expensive.
bigman is offline   Reply With Quote
Old 27th August 2009, 20:36   #3238 (permalink)
quickdraw's Avatar
I am thinking about them as well, do they have any OEM headlamp shapes for our desi cars? What kind of costs we looking at here?
__________________
Still alive & kickin'
quickdraw is offline   Reply With Quote
Old 27th August 2009, 22:26   #3239 (permalink)
22K for a pair of 240 Blitz.
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Old 28th August 2009, 02:28   #3240 (permalink)
dreamdiesel's Avatar
Guys, I am currently running all OE lighting on my 2007 Swift VDI. I am thinking of installing HID xenon (4300K) just for the fog lamps (H8). Do you think its a practical thing to do? I understand 4300K should be almost equal to the OE fog lamps. I will go for a 100/90 Halogen setup for the headlamps. Any indicative prices for getting the HID in the foglamps done?
Its not for the bling factor as I am looking towards practicality. Any members who already have a HID setup in the Swift Foglamps? Need advise on this....
__________________
1997 Maruthi Suzuki Omni E - White
2004 Bajaj Pulsar 150 DTSi - Black
2007 Maruthi Suzuki Swift VDI - Silver
dreamdiesel is offline   Reply With Quote
Thread Tools
LED lighting in cars gigy Technical Stuff 117 9th March 2010 19:14
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 10:49
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653
