Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 28th April 2007, 02:43   #316 (permalink)
I am planning to put philips vision plus on my adventure h7, it is rated 80w. Should i go for a new relay.
swathyd is offline   Reply With Quote
Old 1st May 2007, 12:17   #317 (permalink)
I am using Philips 100/90 on my Santro for more than 3 years. I never had any issues and quite happy with the light. I did change my Verna also recently with the same bulbs. Better dont try out other brands as they dont seem to last as long as Philips. I had tried with Osram but one of the bulb lasted only about 3 months. Same is the case with household CFL bulbs.
appuchan is offline   Reply With Quote
Old 1st May 2007, 13:32   #318 (permalink)
dilipkumar7278's Avatar
I have been using the same lamps in my lancer and would vouch for it.The beam through and spread are great.It cost me about 2300 for a pair.
dilipkumar7278 is offline   Reply With Quote
Old 1st May 2007, 14:00   #319 (permalink)
Default What did dealer meant by fog lamp switch?
I recently inquired at TATA dealership about fog lamps, he said with TATA original switch it will cost 6500, with local switch it will cost 2500.
There cannot be such a difference with switch only.
Is he talking about relay?.....the sales person was not clear about my question for relay thing.
I hope he must be talking about relay in order to avoid overloading the circuit, please shed some light!
__________________
Arun
arunforu1 is offline   Reply With Quote
Old 1st May 2007, 14:12   #320 (permalink)
wolfinstein's Avatar
All TATA's are prewired for Music System, Fog Lamps, Additional Horns etc. You Don't need to Ideally install any additional Relay unless you are going above the recommended OEM Range...So its more of a plug and play application.
The OEM foglamps are from Minda- and cost around 700 each at the showroom plus Tax.
Outside OEM Minda will cost you 400 each plus tax.
Rates can vary so, consider them as range index.
Switch can be sourced from TATA Dealer or Spare parts shops will cost at the most 300 or 400 for OEM and around 100-200 for Local make.
So it cannot be Priced this High as Quote.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 1st May 2007, 21:12   #321 (permalink)
Old 1st May 2007, 21:25   #322 (permalink)
BUSA's Avatar
I think he misunderstood you, Even mercedes wont charge you 6500 for a Switch.
__________________
thecarsandmore.blogspot. com
Old 3rd May 2007, 07:01   #323 (permalink)
Ram
Ram's Avatar
Default Large driving lights, for my Baleno VXi
This niggles on my mind once every so often...
Where can I find large driving lights, for my Baleno VXi that fully occupy
the provided cavity in the bumper, like this...
Looking and looking and looking....
Any suggestions?
Ram
P.S. Dippy, did you get the Xeta fogs to fit your OHC?
http://www.team-bhp.com/forum/modifi...tml#post349305 (Can Indica Xeta foglights be fitted onto an OHC?)
__________________
On Google Chrome 0.2.149.27 since Tue. 02-Sep-2008.
When you struggle for something and fail, that’s when you get Experience!
Ram is online now   Reply With Quote
Old 3rd May 2007, 08:48   #324 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Xeta fogs do not fit OHC. Iraghava was looking too.
__________________
Reclaiming.....!
Old 3rd May 2007, 12:43   #325 (permalink)
iraghava's Avatar
Yup, as Tanveer said they did not fit. They were way too big for the slot.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 3rd May 2007, 12:54   #326 (permalink)
low_bass_makker's Avatar
one can change the bulb to Xenon (HID) to get better illumination on the road....the bulb color can be selected can be 4300k as it will near to yellow light and will be brighter than the normal halogen about 2 times....
__________________
156.6 db, naa....time is coming to cross it......
Old 3rd May 2007, 13:05   #327 (permalink)
Ram
Ram's Avatar
Everybody has reacted with one-liners to my Postscript to Dippy Sadekar.
But does anybody have a suggestion as to how to achieve the result as below?
Ram
__________________
Old 3rd May 2007, 13:20   #328 (permalink)
Team-BHP Moderator
Rtech's Avatar
Ram, you could always add a pair of good Hella driving lights, however, you would need to cut the bumper to fit them in. If done correctly, they will look great.
If you want driving lights that fit in the OE fog light position, them I'm afraid they will only improve the looks of the car and not provide any real help while driving.
Old 3rd May 2007, 13:38   #329 (permalink)
Team-BHP Moderator
tsk1979's Avatar
The only way to fit big huge fog lamps is to cut the bumper, install fiber(the kind used for car skirts) cut to size and have the fogs inside that.
In the stock location in the baleno bumber, you will have to go for small fog lamps, which as per my experience are not much better than the indicator lights.
You can also toy with the indica option, if they fit then good, otherwise you can try with innova, indigo(round lower fogs)... and so on till you find the right fit.
__________________
Reclaiming.....!
Old 3rd May 2007, 14:04   #330 (permalink)
zakaaaaasss's Avatar
ram,
just check whether u can get fogs from those old siennas. i did not find correct pic but here is a bumper pic of sienna..
it seems with minimal alteration u can get what u looking for....
zakaaaaasss is offline   Reply With Quote
Thread Tools
LED lighting in cars gigy Technical Stuff 33 6th September 2008 02:02
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 12:42
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
