| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | LinkBack | Thread Tools |
| | #3286 (permalink) |
| BHPian Join Date: Aug 2009 Location: "Luck-City", Capital of ? (AP/TG/UT)
| I have been searching for Philips Xtreme Power or Osram NightBreaker to replace the bulbs in my car at Hyderabad but have been unable to find them below 1,200 for a set. Seeking the help of other Team-Bhpians to a reasonably priced genuine shop. |
| | #3287 (permalink) | |
| BHPian Join Date: May 2008 Location: Tuticorin
| Quote:
Last edited by arunjohnpaul : 8th September 2009 at 14:03. Reason: additional info | |
| | #3288 (permalink) |
| BHPian | Hi I am new to T-Bhp and a complete noob about Auto-Lighting. I have few queries. My i10 Magna Stock headlamp light is pathetic. In areas without street light i find it very difficult to navigate in nights. Moreover, it doesnt have Fog lights which makes my night driving miserable. Currently my night drive (from office to Home ~ 8KM) is run on "Human GPS" + Guesstimates + Luck.Kindly Suggest me ways and means to improve its Lighting. Can i Install OEM Fog lamps? Would they serve the purpose ?. In the event of upgraded Headlamps (read increased wattage), will it hamper my battey ? (I am running 2 Amps) Kindly suggest the me few better alternatives at reasonable cost (ya, dont expect me to spend more than 15k on lighting) [COLOR=black]P.S: Human GPS is a mechanism by which humans develop GPS capability through continuous usage of particular Roadway. However this may fail miserably during rains/floods/Government actions (PWD Dept) [/COLOR]
__________________ |i10 1.2 Magna|X693|ESK 163L|ECX 165|RF [T400-2] [P300-2] [R500-1]|12" GZRW-XDAL|RFK4D| |Swift Vxi|5050|DSK 165|DCX 165|GTA 480| |
| | #3289 (permalink) |
| BHPian | Guys, I want to fit the Hella 450/550FF rectangular driving lights to my Aveo's bumper by using the foglight fitting areas on either side. Can someone suggest a reputed installer in BLR to do this and what cost can I expect? Also, does Hella now come with B&W considering that they are officially in India now? Any pros and cons from anyone? I do not want to fit them on top of my bumper or adjoining the air intake/grill areas.
__________________ Into each life some rain must fall |
| | #3291 (permalink) | |
| Senior - BHPian | Quote:
Shops you can try are Xenex (Madhapur - Opp. food world, Kavuri Hills), Car Jewel etc. on Minister Rd. Secunderabad. Cheers
__________________ Live to drive! (For commuting - take a bus) | |
| | #3292 (permalink) |
| BHPian | I have installed a relay wiring mated to 100/90 philips rally eye bulbs. I have come up to a opinion that if you car sports glass reflectors, ugrade your wiring. Install the 100/90 philips rally eye bulbs which cost abt 150 bucks a piece. evem if one filament failed just throw it off and buy anew one. the throw spread and power is brilliant for continours night driving on and off the higway. Turns out to be a much more economical choice than buy expensive bulbs worth a lot more than 150 bucks.
__________________ 2003 Mitsubishi Lancer GLi - 112K 2002 Bajaj Caliber UG - still stuck on 18.5K 1991 Bajaj Chetak 12V - 85K |
| | #3293 (permalink) | |
| BHPian | Quote:
Upgrading the bulbs to 90/100W with wiring and relay will help you a lot and wont drain your battery fast unlike the 130W bulbs. So, Lumax fog lamps 2k + 0.5k(original hyundai switch-optional) 90/100W with wiring, relay and holders will cost you less than 1k. | |
| | #3294 (permalink) |
| BHPian | Hi, I have installed 130/100 lighting with diff wiring n ceramic holders et all the works. It was working fine till one day one of the headlights was dimmer than the other. Got this checked and found that the ceramic holder was burnt so got it replaced. It was fine for sometime and again I got the same issue of one of the lights being dimmer than the other. This time I was told that there is some problem with the earthing and earthing was rechecked and redone with some additional earthing connects done. After some days the problem repeats and again the earthing was done and it was working fine. A few days back I started getting a wierd sound from the engine bay, got the car serviced and the service engineer told me that the headlight adjuster or whatever its called has a problem with the motor and the entire headlight unit has to be replaced and I lose warranty as I have used a high wattage bulb. My Question is how the higher wattage bulb damage the headlight adjuster and is the service engineer right to deny me replacement of hte headlight unit? or is there a way I can get this corrected. Alternatively the service engineer suggested he can remove the connection to the adjuster and that would eliminate the sound coming. Any suggestions guys?
__________________ 2008 Getz CRDi - Passion Red, Pete's Tune Box Be Quick or Be Dead |
| | #3295 (permalink) | |
Please have all of the headlight wiring, relays etc. checked as your problem seems to be recurring too often. Cheers,
| | #3296 (permalink) |
| BHPian Join Date: Oct 2008 Location: Mumbai
| I simply don't understand why people put high watt bulbs? Whats the use huh? Waste money on additional systems, then burn the current systems and then against waste money. Never ending cycle of wastage!
__________________ YoYo... Live n Let Live! :D |
| | #3297 (permalink) | |
| BHPian | Quote:
I was having the same impression in olden days because our cars were not that fast and rare long night travels. Now our machines speed on 80KMPH+ average once out of city and munch 100s of miles without any time bar in any weather. My Palio headlamps were upgraded not to make others blind but to ensure me no blindness in my overnight trips to native. I rarely drive on high beams in my city drives. I have the same issue with Accent too, Alto's lighting is quite fine compared to Palio and Accent in my experience.
__________________ Cheers....Jacs "The best car safety device is a rear-view mirror with a cop in it. " - Dudley Moore | |
| | #3299 (permalink) | |
IIRC I paid about 3K for the set of 4 bulbs (2 H1s for low beam and 2 H7s for high beam). I have used them through the rains (or whatever passed for the rains this year) without any problem. The light is yellow and not blue so glare from rain drops fogs etc should not be an issue. Cheers,
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 117 | 9th March 2010 19:14 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 10:49 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652
[/COLOR]
