Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 12th May 2007, 18:43   #361 (permalink)
iraghava's Avatar
Originally Posted by Bass&Trouble View Post
Ishan suspects an overcharging alternator to be the problem, seems like it to me too. Now I dont know what to do, since if I use another battery, the car will start, but probably wreck the new battery by the time I get to the garage also. On the other hand, I dont know what else is left to be destroyed by the alternator that may happen once the car starts. Can anyone suggest a plan of action hereonwards? Does anyone know exactly what may cause the alternator to overcharge? I would guess it has something to do with the rectifier circuit or something. Any precautions for the future? I was damn lucky I had just removed some test audio gear from the car, otherwise it would have been far more devastating.
Ajay - Don't use the car over the weekend take the Corolla or a taxi. Monday first thing tow the car to a reputed garage which is an expert is electricals (Ask Elf for this, he knows about a good one I think) and have them check the alternator. I suspect your alternmator is giving out surges of current much higher than the 13-14V it's supposed to and that is causing the electricals to blow.
I'm spcifically asking you to tow the car because any further attempts at starting or driving it could lead to further part failures. And please get rid of the damn thing now!!! It's about time!
__________________
Power corrupts. Absolute power is kind of neat.
Old 12th May 2007, 19:47   #362 (permalink)
tsk1979's Avatar
GEt the rectifier plate and the regulator checked. These parts fail commonly. Cost will be around 1000rs for replacement of both.
A new alternator costs 2500rs or whereabouts, so if the expenses are 1200+ go for a new alternator.
How old is this alternator.
__________________
Reclaiming.....!
Old 12th May 2007, 19:50   #363 (permalink)
low_bass_makker's Avatar
Ya Ishan you are right...normally if the car alternator give very high voltages about 30-40 volts if it is rotated at 3000-4000 rpm.....thats why there is a voltage regulation circuit present to drop the voltage so that it operates at 14 volts......now in the case when the regulation circuit fails the battery protects the car electricals by absorbing the high voltage....but battery cannot handle the high voltages for a long time....
Ajay Sir in your case it was the alternater which was giving out high voltages and the battery was holding till today till you heard the first pop....as the battery was gone the alternater was giving full voltages to every component of the vehicle which you operated.....you must tow your car to a good garage to get the alternator check else more thing are bound to get damage.....
Old 13th May 2007, 15:47   #364 (permalink)
Guys any place from where I can get original HID (xenon) bulbs.....as I need only the bulbs not the ballast....
Old 13th May 2007, 15:50   #365 (permalink)
tsk1979's Avatar
Originally Posted by low_bass_makker View Post
Guy any place from where I can get original HID (xenon) bulbs.....as I need only the bulbs not the ballast....
Original... What do you mean by original. Any particular brand in mind?
If you are just looking for bulbs - ballast, ebay is the best place to look.
__________________
Reclaiming.....!
Old 13th May 2007, 15:54   #366 (permalink)
nahi yaar tanveer in delhi and around one can get only taiwan and chinese bulbs...I want philips, hella, osram type of some standard company stuff...
Old 13th May 2007, 16:06   #367 (permalink)
tsk1979's Avatar
AFAIK, philips and hella do not sell bulbs, except to OEMs. So you may have to go for lesser known guys like GE/Havell etc., Try autobulbs.co.uk
__________________
Reclaiming.....!
Old 13th May 2007, 17:09   #368 (permalink)
LBM,
I have one contact in Bombay. You want one xenon Bulb ? H1 ?
Mugen_Power is offline   Reply With Quote
Old 13th May 2007, 17:11   #369 (permalink)
shazikon's Avatar
Default Ford ikon angel eyes
Has any one used this?? Is this available in india??
__________________
Cheers,
shaz
shazikon is offline   Reply With Quote
Old 13th May 2007, 17:24   #370 (permalink)
akshay1234's Avatar
it dosent seem like a straight fit onto the ikon. it seems a bit big. i doubt youll get this in india.
akshay1234 is offline   Reply With Quote
Old 13th May 2007, 17:32   #371 (permalink)
shazikon's Avatar
well the website say its a direct fit.. This is actually used for the Fiesta MK5 (indian ikon) in UK.
__________________
Cheers,
shaz
Old 13th May 2007, 20:18   #372 (permalink)
akshay1234's Avatar
cool. i guess i thought they were big because of the angle of the pic. i dont think youll get them in india. about 200pounds for these plus more shipping it to india. itll cost alot.
Old 13th May 2007, 20:30   #373 (permalink)
Arrow Lighting for a Safari
Hi guys,
I have a 04 model safari which has OE bulbs. I want to change it because I am not too happy with its power when there is oncoming traffic.
What do you suggest?
Shall I keep thsm as it is and add a pair of fog lamps(my LX does not come with one) or shall I change the bulb?
I think there are 2 bulbs in 2 enclosures, not like most other cars. Do I need to put in 2 pairs of bulbs?
Please suggest.
For whatever you sugggest, prices and where to get them in Chennai will be most welcome.
__________________
Proxima
2004 Safari LX
2008 Pulsar 180
Proxima is offline   Reply With Quote
Old 14th May 2007, 00:12   #374 (permalink)
from where can I get the above mentioned brands in india.....no website...
Originally Posted by Mugen_Power View Post
LBM,
sir i will call you for the info....
Old 14th May 2007, 17:34   #375 (permalink)
Default Help
Originally Posted by Proxima View Post
Hi guys,
Please suggest.
Gurus please help!!!!!
__________________
Proxima
2004 Safari LX
2008 Pulsar 180
Thread Tools
LED lighting in cars gigy Technical Stuff 58 18th November 2008 17:02
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 15 16th November 2008 22:16
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 23:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
