| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #376 (permalink) |
| Team-BHP Support ![]() | Proxima, you have 4 bulbs in the old safari i.e. 2 pairs. One Pair is for low beam Other pair is for high beam. When you are in low beam mode 2 bulbs light up In high beam mode all 4 light up. That said old safari had pretty good lights, I suspect the reflector. Get the reflector and headlight glass cleaned and the headlights aimed. Also from your service book post what are the bulbs in a safari For example on pair may be H3 the other pair may be H7.
__________________ Reclaiming.....! |
| | #380 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | hi tanveer, i dont remember the exact model # it was OSRAM 100/80W for sure & it costed me 300 rs a pair for bulbs and app 600 for the relay. i bought it from authorised dealer in west delhi, pawan motors. the guy's name is atul and his # is 9891200240.
__________________ SINGH IS KINNNNNNNG.. |
| | #381 (permalink) |
| BHPian Join Date: Apr 2006 Location: chennai
Infractions: 0/1 (5) | try getting a philips 130 /110 with a cutout . You could probably buy ceramic bulb holders from roots and a cutout . Everything should cost around 700 rs for the upgrade . You will feel that the money is worth spent . Cutout is used as these bulbs draw a heavy ampereage and for switching ,the stock contacts can switch so much of amps and the oe wiring cannot handle the amperes . Thats the reason for a cutout . Incase someone has replied before ,kindly ignore as i didnt have the patience to go through the whole set of replies . |
| | #382 (permalink) |
| BHPian | Gosh!!! Such lovely headlamps. 200 pounds one set.. and postage wud be another 200 pounds (cos ireland itself 50 pounds) and customs another 200 pounds.. equal to 600 pounds. o m g! but its so lovely!! so sad that stock is empty. OT: Those fiesta zetec engines rock, and also the ovrm's present in this ford fiesta zetec have the mirrors of the indian escort which is much better than the present ikon's ovrm's. -Absar
__________________ Ford Ikon 1.6 Nxt ZXi, 2005 I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM. Last edited by Absar : 14th May 2007 at 23:24. |
| | #383 (permalink) |
Infractions: 0/1 (5) | my 130/110 bulbs have again failed . the high beams have gone and I got to replace the bulbs again . I am toying with the idea of getting some industrial grade relays , and also planning to limit the current by adding a diode inbetween the bulbs . I know for sure there would be a voltage drop when the diode is connected in series , but , I would like to know if there are any other protection methods to save those filaments from burning out . I have also had issues with the "electronic" relays ,and thats the reason why i am planning to get an industrial or militiary grade , high ampere relay for each bulb . Anyone out there has tried with these mods ? |
| | #384 (permalink) |
| Senior - BHPian | Have u tried ceramic holders? If not, then thats the most likely culprit. Good relay with good quality wiring and ceramic holders will mean your 130/110 bulbs will always shine. Drifter
__________________ Slow Everything Down And Feel Like God - Tata Safari |
| | #385 (permalink) |
| BHPian | I think your bulbs are failing because of heat. In city traffic using such high power bulbs will heat them up to a point it will fail sooner. along with this if you are using dipper then it is sure reason for failure. hope you are using ceramic bulb holders. other ones will melt off and when you want to change the bulbs you will see everything is a molten mass and might turn into a major problem. you can end up damaging the headlight assy itself. industrial grade relays dont make a difference here. if you are using bosch relays(30amps) it is good enough. Diode doesnt limit current. you reduce current then you are reducing power output, then why put this bulb. go for xenons or lower power to 90/100
__________________ Suzuki Baleno |
| | #388 (permalink) |
| Senior - BHPian | I want to go in for light upgrade on my Optra and Swift. The Optra has 4 bulbs for the headlamps and 2 for the fogs. The Swift has 2 bulbs for the headlamps and 2 for the fogs. Not taking into account the parking lamps. My driving is 50% highway 50% City. I want really good lamps. Looking to go in for 100/90 with Bosch relay. Now i have a few questions, lightning experts like tsk and tyre dealers with lightning knowledge like irags please put your inputs :-
__________________ Got Bhp? Team-Bhp.com |
| | #389 (permalink) |
| BHPian | hi! Guys, Need your help. Booked swift vdi and I would like to know what all option I have when it comes to upgrade headlights? I understand I can go for higher wattage bulbs. Will they void warranty if fitted? Does anyone know what wattage bulbs are fitted as standard in swift? |
| | #390 (permalink) | |||
| Team-BHP Support ![]() | Quote:
As for warranty on using 100/90 you never know. I used 130/110 also in my indica, but no warranty issues. Now its out of warranty anyways. But if your dealer says that your alternator failed due to overload, you cannot argue. Its purely your call. A good option will be to get relay and 100/90 fitted from a MASS. TASS guys do it, don't know about maruti.
__________________ Reclaiming.....! | |||
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 58 | 18th November 2008 17:02 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 15 | 16th November 2008 22:16 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 23:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
