Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 6th July 2007, 13:09   #526 (permalink)
absynthguzzler's Avatar
Default Am I Being Crafty Or Dumb ?
Originally Posted by iraghava View Post
CD is right Ankit, we blow the bulbs (atleast I do quite a few times) primarily due to my habit of using both the beams together! Possible to do when the HL's are on low-beam & you flash simultaneously. Nothing wrong with the bulb there. And there is no set life time for the bulbs, I've seen some working for a few years without any issues & some going bust in a few weeks.
And generally you can buy single pieces of most bulbs apart from a few Philips ones I guess which come pre-packed in sets of two.
would it not make sense to just use a 1mm or 2mm thick drill bit and make a few holes in the outer headlight enclosue so as to improve cooling while driving ???? or does it affect performance and also increase chances of bulb blowing up ?
absynthguzzler is offline   Reply With Quote
Old 6th July 2007, 13:25   #527 (permalink)
RedOne's Avatar
Default 130/100 long term use
Originally Posted by CARtik View Post
suren, how long have u used there high power bulbs. Have you had any issues with lens cracking/holder melting?
Am planning to install on my getz as i do a lot of highway. But want to know reliable these lights are. Pl also let me know the brand..
I have been using Phillips 130/100 on my OHC for 4+ years now. No issues with cracking/melting etc but the reflector/cover does look a bit dull. Then again, it's a 6.5 yr old car...
Gears.
Red-One.
RedOne is offline   Reply With Quote
Old 6th July 2007, 15:51   #528 (permalink)
rjstyles69's Avatar
Hey folks any idea where in Bangy can I source the Philips 130/100 bulbs ?
Cant find anyone who stocks these bulbs.
Somehow feel that my current 100/90(Hella) aint giving me enough light.
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
Old 6th July 2007, 16:01   #529 (permalink)
tsk1979's Avatar
1. I got 130/110W for JC road. If you get them make sure you have roots ceramic holders. My holder slightly melted, but thankfully no permanent damage. I used them for quite some time
2. Now I am on Halonix 100/90W +60 and they give same light as 130/110W.
I suggest you stay away from 130/110W and put in either Hella gold(Yellow light), Philips rallye(if you get originals, almost impossible) or Halonix.
3. Best option seems to be Osram, if you can get 100/90 Osram then nothing like it.
We put 60/55W Osram in a safari and light is same as the 100/90 bulbs
__________________
Reclaimed, wrung dry and recycled....!
Old 6th July 2007, 16:20   #530 (permalink)
rjstyles69's Avatar
Thanks tsk .
I already have ceramic holders with my current 100/90 setup.
Wil have to hunt around for Osram or Halonix in the 100/90 range.
Have found quite a few sellers in India on ebay with Phillips Rallye, but dont know how good these are.
__________________
rjstyles
Old 6th July 2007, 17:27   #531 (permalink)
Dragonov's Avatar
Came across "Halonix H4 +60 High Perfomance Xenon Head lamps" on Ebay. There is no wattage mentioned on them on the website but seems to be a good option, wanted to know if anyone has used them ?
__________________
Getz CRDi 08'/ Safari Dicor 3.0L 06'/ Ikon Flair 05'/ Vitara 2.7L V6
"We all have ability. The difference is how we use it."
Dragonov is offline   Reply With Quote
Old 6th July 2007, 17:31   #532 (permalink)
tsk1979's Avatar
Originally Posted by Dragonov View Post
Please read this thread, or use search function.
They are available in Sector 16 Noida at Rs. 90/bulb and I am using them. For review and comparison, just look in the previous posts.
The config is 100/90W
__________________
Old 6th July 2007, 17:35   #533 (permalink)
CrAzY dRiVeR's Avatar
Guys,
How to see if Philips bulbs are original?
Am looking for rally eye lamps.
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 6th July 2007, 17:44   #534 (permalink)
rjstyles69's Avatar
Philips Rally eye bulbs are no longer manufactured is what I got to know.
__________________
rjstyles
Old 6th July 2007, 17:45   #535 (permalink)
Dragonov's Avatar
Thanks for your reply tsk1979, but I wanted to know whether the one's available on Ebay ( supposedly Halonix +60 Xenon Headlamps) are the same Halonix +60 90/100 W which you bought from sector 16 noida. I mean are they Xenon gas filled bulbs or the normal halogens..?
__________________
Old 6th July 2007, 19:21   #536 (permalink)
tsk1979's Avatar
There is only one Halonix +60 100/90W and it is supposed to be Xenon gas filled.
They are nice bulbs, but if you expect white light, you will be disappointed.
__________________
Old 6th July 2007, 20:07   #537 (permalink)
Is there any way to adapt an h7 kit into an h8 (swift fogs ) ?
__________________
No fate but what we make!
Old 6th July 2007, 20:40   #538 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
i think youd have to change the bulb holders etc.
akshay1234 is offline   Reply With Quote
Old 6th July 2007, 20:41   #539 (permalink)
Jaggu's Avatar
replacing the bulb might not really help the swift fog lamp, its more to do with the reflector and the beam adjustment which are nearly impossible to fiddle with.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 6th July 2007, 21:02   #540 (permalink)
Sure?
Man! does that mean all the hundreds of bulbs stocked in all the showrooms i checked recently were fakes?
__________________
Thats why i'm here!
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
