Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 19th July 2007, 12:51   #601 (permalink)
Firebird's Avatar
I may sound stupid but, my knowledge in auto light is poor. I have Palio. I got it right that this has the setup which needs separate bulbs for High and Low. So in this case, if I have to ask for the vision plus or any equal type bulbs in a shop, what should I be asking. I mean for high and for low what type should I look for.
__________________
Firebird
Matiz SG-2000 SOLD
Palio 1.6 Sport-2006-SOLD
UVA LT-2008
TEAM-BHP - LEAGUE OF ORDINARY PEOPLE
WITH EXTRAORDINARY RIDES
Firebird is offline   Reply With Quote
Old 19th July 2007, 13:00   #602 (permalink)
tsk1979's Avatar
Firebird, Palio has very good lights. If you find the light in your car is not adequate, the culprit may be old reflectors.
Get the reflectors and headlight glass checked and cleaned. Only after that take the new bulb option.
You can take your existing bulbs and get vision+ replacement for the same.
I have experience only with H4, not with Palio type. other palio owners may be able to help you.
That said, if you can get originals in Vision+ (Go to philips distributor, not street shop) it will be great.
Other option in + series is Bosch 30%+, Or Osram silverstar +50%
__________________
Reclaimed, wrung dry and recycled....!
Old 19th July 2007, 13:19   #603 (permalink)
Hi Tsk1979 and others,
Thank you for your inputs. I think I will go to CP and get the Philips +80% . I looked at the Safari's manual and it doesn't mention anything regarding the type or specification of the bulb except that it comes with a halogen bulb and the process of replacing the bulb. I am thinking maybe I could try replacing the bulb myself.
I would need a H4 type of bulb. Now, would I need 2 or 4 of these? As I understand H4 type is for a single bulb that contains two filaments (Both for high and low beam). Please provide your advise on this.
Thanks,
-Sumit
__________________
" For Some, Its a Wheel,
For me, Its the World "
sumitsingh is offline   Reply With Quote
Old 19th July 2007, 13:21   #604 (permalink)
Proxima's Avatar
Guys, How can I put this on my 04 Safari Tdi?
It has two bulbs on either side, one for low beam and one for high beam, if I am not mistaken.
__________________
Proxima
2009 Ikon TCDi
2008 Pulsar 180
Proxima is offline   Reply With Quote
Old 19th July 2007, 13:22   #605 (permalink)
tsk1979's Avatar
For Safari main light you would need total 2 H4 bulbs
Older TCIC safari had separate high low beam, so there you would need 4 bulbs, though I am not sure of the type.
Proxima, take out the old bulbs and see what type they are.
Based on that choose Bosch/Vision+/Osram etc., 30-50%+ bulb.
__________________
Old 19th July 2007, 13:30   #606 (permalink)
hydrashok's Avatar
@ Firebird, I'd upgraded my Palio's bulbs to Philips Rallys a few weeks back - 100w H1s and 80w H7s. I also had to add a Bosch Relay. I don't remember the exact total, but it was Rs.1600/- or Rs.1800/- total.
The light was all right earlier with the stock bulbs. But with the heavy rains and the poor roads (also usually unlit), I felt an upgrade would be nice.
I never drive with the brights on in the city, but the new lights do help me to flash oncoming traffic (with undipped lights) into submission . The light (both spread and throw) has improved substantially and I'm really happy with the upgrade.
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 19th July 2007, 13:58   #607 (permalink)
tsk1979's Avatar
hydra, along with the relay did you also change the stock wiring?
If not do so ASAP.
The reason is that stock wiring will give you a significant voltage drop with higher wattage bulbs, so you won't be using them to their full potential.
In some cases it may also damage wiring.
Its like using a thin copper wire for your ICE
Normally Roots/Bosch etc., relays also have complementing wiring kits.
You can buy a roots wiring kit + ceramic holders for 350 odd.
Ceramic holders are important because stock holders may get damaged due to high heat.
__________________
Old 19th July 2007, 14:01   #608 (permalink)
hydrashok's Avatar
Whoops! The wires did get changed with the relay (it was a full kit, like you said), but not the holders! I'll get this done ASAP. Thanks for the heads up
__________________
Old 19th July 2007, 14:38   #609 (permalink)
hydrashok's Avatar
Whew! Just checked. The holders had also got changed (duh!) The whole shebang was one full kit-thing I guess (Whatta relief)!
__________________
Old 21st July 2007, 10:00   #610 (permalink)
Originally Posted by swathyd View Post
I am going to buy silverstar tomorrow.
Bought and got it fitted, but sincerely speaking not any difference found. I think this 50 + and all are gimmicks.
Another thing is that light from right and left have different throw and quality. I got my right changed after 3 days of delivery due to water presence, it is the right which has poor light.
swathyd is offline   Reply With Quote
Old 21st July 2007, 17:10   #611 (permalink)
Phew, got the delivery of the much awaited Philips Extreme Power (80%+). Fitted them last night. The difference is visible but whether worth Rs. 1600, only time will tell.
__________________
Nitin Kapoor a.k.a. NK
nkapoor777 is offline   Reply With Quote
Old 22nd July 2007, 03:26   #612 (permalink)
ankitahuja's Avatar
Ok I fitted the Halonix +60 100/90.
I'm SO DISAPPOINTED. The are like stock 60/55 which are as useless as anything else. The Philips Bluevision 100/90 I had were 10 times better. I don't know whether to get the same ones now or try Narva / Osram. Any suggestions guys?
__________________
åĐïğŧėđ Tŏ Ÿoů...
Old 22nd July 2007, 03:37   #613 (permalink)
tsk1979's Avatar
Which car..?
Did you get a Relay/Wiring upgrade?
If you look at the comparison pics between Narva and Halonix on my Indica, you will see that the Halonix were much brighter than the Narva.
__________________
Old 22nd July 2007, 12:15   #614 (permalink)
PRADEEP KUMAR's Avatar
Which is the best in the 100/90 category in terms of light intensity and throw.
Experts pls advice.
__________________
I voted.
PRADEEP KUMAR is offline   Reply With Quote
Old 22nd July 2007, 13:00   #615 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
i have narva 100/90 white bulbs. they are very bright. but i dont know about halonix.
akshay1234 is offline   Reply With Quote
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
