Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 4th December 2006, 00:01   #61 (permalink)
@dhir,
You got all the things which you have to replace.
Do you want to DIY project or some electrician will do the job ?
Mugen.
Mugen_Power is online now   Reply With Quote
Old 4th December 2006, 10:46   #62 (permalink)
agentsmith's Avatar
Can anybody explain H1, H2, H3 .. H7 "ratings"? What do they indicate?
Agent Smith.
__________________
And all that you touch and all that you see, Is all your life will ever be.
agentsmith is offline   Reply With Quote
Old 4th December 2006, 11:34   #63 (permalink)
tsk1979's Avatar
Agent Smith.
They are not ratings, they are specifications.
H4 is the standard halogen with low high beam in one bulb.
Then you have a different specification for fog lamp halogens.
They concern the shape and design of the halogen bulbs and are not "ratings".
__________________
Reclaimed, wrung dry and recycled....!
Old 6th December 2006, 12:09   #64 (permalink)
Yesterday I went to an auto accessories shop, asking for prices of different headlights.
1. Philips Blue Vision 90/100 - He said, he wouldnt suggest it for high way driving...
2. Narva - again white light... not advisable
3. Philips Rally 90/100.... he advised me to go for it.... He also added, I wouldnt require any extra fitting as I own an accent. It seems accent already comes with cut outs and relays...
So my questions:
1. Have any one used white light on highways?... How is the visibility of highway driving?
2. What he said about accent is true? (ie about the CutOuts and relays already built in for accent?)
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 6th December 2006, 12:18   #65 (permalink)
suman's Avatar
Talking about high low together, the indica allows that.
The Dicor does as well, by pulling the stalk towards you when on low beam......
__________________
"Unborn TO-MORROW and dead YESTERDAY,
Why fret about them if TO-DAY be sweet!" - The Rubaiyat of Omar Khayyam
Old 6th December 2006, 12:19   #66 (permalink)
gigy's Avatar
osram silver star is the best upgrade possible without installing any cutout and without damaging the plastic of headlight assy. else go for complete xenon upgrade. temporary addition of lights can come by putting on bioth beams together. i have done that there is marked improvement in total beam spread but cant comment on how long will it last if used for long. i have put in a additional switch and relay for this purpose.
Old 6th December 2006, 13:17   #67 (permalink)
agentsmith's Avatar
For what it's worth, the chaps at Sringar recommended all the three (infact all the headlights rated 90/100+) to be good for highway driving.
So my questions:
This would be good to know, in any case.
Smith.
__________________
Old 6th December 2006, 14:26   #68 (permalink)
tsk1979's Avatar
White light reflects much better of road markings, and reflectors. This is my personal experience. Apart from that there are other factors which are important
1. Reflector shape and beam spread
2. Headlight aiming - This is very important. Improper aiming can make waste of even the best headlights.
I am using white lights in my indica. Currently the wiring is original, so the bulbs are not getting exact 12V. I will get a PMP wiring kit which should make things even better.
For clear lens lights, I think white is great, as I have seen on Getz with 60/55W Vision+.
Drove in hills/highways/snow and the lights were simple awesome.
__________________
Old 6th December 2006, 15:00   #69 (permalink)
RedOne's Avatar
tsk1979,
Which place in Noida did you get this done? And do thay have the PMP kit as well? How was the installation? I was in sector 16 on Monday to fix a pair of Bosch horns on my OHC and their installation guy was scary !
Did you try out the Phillips Rally series, as there are a lot of compliments for that bulb in this thread. Are the Narva as blue as the blueVision? I am not looking for those bluish white beams. White, and if not, then regular halogen golden is what I prefer.
Gears,
Red-One.
RedOne is offline   Reply With Quote
Old 6th December 2006, 15:08   #70 (permalink)
tsk1979's Avatar
Originally Posted by RedOne View Post
tsk1979,
Gears,
Red-One.
I am yet to get a PMP kit. could not find in NOIDA. So will try Lajpat nagar during the weekend.
I used to have 130/110W Phillips rally, but the bulb got damaged.
So I got roots 100/90W which were very bad.
Now I have Narva 100/90W and am happy with them, though ideally I would prefer Osram Silverstar if I get them anyday! But the bulb is white light(just like bluevision) and in normal light range the brightest ones are Osram Silverstar if you look at luminosity. Hella 100/90W are also supposed to be pretty good but never tried them.
you can go for 100/90W Phillips rally in your OHC, but to get full benefit you will need wiring kit
__________________
Old 6th December 2006, 15:18   #71 (permalink)
RedOne's Avatar
Thanks. Which shop in Noida did you go to? Did they have the Phillips rally bulbs as well?
Also, after your search, do let me know where you were able to find the PMP kit in Delhi.
Gears,
Red-One.
Old 6th December 2006, 15:24   #72 (permalink)
suman's Avatar
Tanveer, not sure what I have on the Dicor now but will Navra or Osram fit in without any modifications or additional wiring/relays?
The high-low (together) beam intensity is what I'd ideally like to have & of course its not feasible to keep the stalk pulled towards you all the time!
__________________
Old 6th December 2006, 15:33   #73 (permalink)
tsk1979's Avatar
Suman,
you should never do that. You will blow the bulb if you do high low together for long periods
If you dont want to go for relay's you can go for Silverstar 60/55W or Philips Vision+(Not bluevision or diamond vision). 60/55W.
they will give better light than stock but nothing beats 100/90W, for which you will need a relay atleast.
Since safari has fog lams, I suggest you go for the silverstar 60/55W. You can contact Osram.co.in for dealer info etc.,
I used 60/55W Philips vision+ in Getz and was pretty happy.
RedOne, I think noida is more of luck. Sometimes these guys have stuff in stock sometimes not. I think Lajpat nagar is a better option. If you want we can go together on sat evening(5ish).
__________________
Old 6th December 2006, 15:51   #74 (permalink)
iraghava's Avatar
Suman may I suggest the magic word XENONS
__________________
Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water.
Old 6th December 2006, 15:56   #75 (permalink)
RedOne's Avatar
Ok. Will PM you Friday for contact no if I can make it on Saturday.
Gears,
Red-One.
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
