| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #766 (permalink) |
| BHPian | Found it! Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): OEM vs. Nighthawk vs. X-Treme +80%: The Showdown <56K Intense> OEM vs. Nighthawk vs. X-Treme +80%: The Showdown <56K Intense>
__________________ Into each life some rain must fall |
| | #767 (permalink) | |
| BHPian Join Date: Jun 2007 Location: Bangalore
| Quote:
| | #768 (permalink) | ||
| BHPian | Quote:
With the problems I mentioned above, I replaced the bulb few days ago and was shocked to see the condition. What the heck is this? ![]() ![]() ![]()
__________________ • åĐïğŧėđ Tŏ Ÿoů... | ||
| | #769 (permalink) |
| BHPian | Ankit, You have mentioned that electrics are all good so won't go down that route. During installation did anyone touch the bulb glass with bare hands? Even if touched was it cleaned with alcohol thereafter? Touching with hands may have caused a 'weak spot' on the bulb which ultimately caused it to catastrophically release the halogen gas contained in it.
| | #772 (permalink) |
| Distinguished - BHPian ![]() | I would think that is a result of the bulb overheating. But I think tsk would be the right person to answer that.
__________________ Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water. |
| | #774 (permalink) |
| BHPian | Wow! I've never ever seen a bulb that has a bulge like this.. Looks eerie too. Btw, is it possible for the Ikon's headlights to manage 100/130w bulbs with Roots relay and ceramic holders? cya A
__________________ Ford Ikon 1.6 Nxt ZXi, 2005 I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM. |
| | #775 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| it can be a misfit for that particular model of reflector also (thinking out loud)
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #776 (permalink) |
| Team-BHP Support ![]() | Original bulbs are made to certain regulations, so are the reflectors. This is a classic bubble failure which is more often than not caused by dirty bulbs. Many mechanics touch the bulb while installing with greasy hands. Thats enough to cause a failure. Infact such a bulb will definitely fail, its just a question of when.
__________________ Reclaimed, wrung dry and recycled....! |
| | #777 (permalink) |
| BHPian | Hmmm.. Leaves me with more confusion. First, I installed the bulbs on my own, and I did not touch them at all.(Unless they were touched by someone else before being sold). Second, my sources for spares are never wrong, so I strongly disagree about the bulbs being fake. Can moisture cause this? I noticed that there is a small hole (half inch dia) on the top of the headlight assembly which could have led to this? ![]() When the low beam blew first, I used the headlights on highbeam for a long time before it failed too. But the other bulb is working well.
__________________ • åĐïğŧėđ Tŏ Ÿoů... Last edited by ankitahuja : 30th August 2007 at 05:56. Reason: Addition |
| | #778 (permalink) |
| BHPian Join Date: May 2007 Location: CHENNAI
| Looking for brights lights for M800 97.Should i go for 90/100 philips or 130/100 will 130/100 burn the casing and the outer plastic casing .Though i need bright headlights for highway travel yet im concerned about 130/100 as it may blind the vehicles coming in the opp direction. will this -VE efect can be subdued if the light angle is adjusted. suggestions are welcome. any other brand. By the way IS blue lights are BETTER for HIGHWAYS.pl let me know.The relay/cutout MINDA. is that OK..TIA |
| | #779 (permalink) | |
| Senior - BHPian | Quote:
If you go through the thread, you'll get other options and answers as well.
__________________ I'm far from perfect. I hope i can improve. Thats why i'm here! | |
| | #780 (permalink) |
| Team-BHP Support ![]() | ankit, anything on the glass, which can be grease, moisture etc., can destroy the bulb. In your case I think there is something wrong with the electricals. Most shops just connect a multimeter to the alternator and check the voltage. Sometimes the regulator has a problem that for short periods it spiked the voltage to 15-16V for a short time. Since you have a relay etc., you get the full voltage for that short time. Since your low beam is blowing, which is a very rare case and you are having multiple failures, it points to electricals. I suggest connect a multimeter to the battery terminals and watch the voltage. While doing that rev the engine, play around with the lights, AC etc., and see if you have voltage crossing the 13.8 or something mark.
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
. and also the bulge is in the place where the tiny reflector in the bulb is pointing.
