Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 25th September 2007, 13:25   #871 (permalink)
n_aditya's Avatar
Originally Posted by munishsurendra View Post
Can I replace my stock bulbs on my Maruti 800 -2004 with "Philips/Osram- 100/130w bulbs with Bakelite Holder", or should i just go for 90/100W with relay..?
Munish, if you are getting bulbs that exceed the rating specified in the owners manual, u definitely need a relay. For a M800, 90/100W is more than enough. Just get a relay and a set of bakelite holders and you're good to go.
Old 25th September 2007, 14:39   #872 (permalink)
kpzen's Avatar
I think Jitendra has already put up his query there sometime back.
__________________
Prajesh - << will be mostly offline till August >>
A true friend is someone who says nice things behind your back...
Old 25th September 2007, 15:50   #873 (permalink)
munishsurendra's Avatar
Originally Posted by sushrutha View Post
You ought to have a relay for 90/100 bulbs
Hey, thanx for the info guys..!
__________________
MUNISH
munishsurendra is offline   Reply With Quote
Old 25th September 2007, 17:21   #874 (permalink)
kick.throttle's Avatar
Yep go for 90/100W bulbs along with the relay n proper wiring, with philips rally vision bulbs. U can have these under 1,000 Rs.
Don't go for white bulbs - My personal choice.
Else get Hella 2000 or 3000 Foglamps ... they are pretty costly
guys i have a santro and i too fixed 90/100W with relay.. but i dont understand that my bulbs go off after the usage of almost 6 months..
can any body tell why is it so???
__________________
2006Dec Santro Xing[160kmph]
2006 Honda Activa[85kmph]
kick.throttle is offline   Reply With Quote
Old 25th September 2007, 18:08   #875 (permalink)
n_aditya's Avatar
Originally Posted by kick.throttle View Post
guys i have a santro and i too fixed 90/100W with relay.. but i dont understand that my bulbs go off after the usage of almost 6 months.. can any body tell why is it so???
Have your car inspected by a good electrician. There must be some loose ends or a short circuit somewhere. My Philips Rallye bulbs (100/130W) were good for over a year until the high beam filament on one bulb conked. Got it promptly replaced while the electricals were also duly inspected.
P.S. Beware of fake bulbs. They are all over and the packaging is also very similar. Only buy from reputed stockists.
Old 25th September 2007, 18:40   #876 (permalink)
razor4077's Avatar
@kick.throttle: another common reason for bulbs conking out quickly is using both the high and low beams together. You do this when using the dipper while the low beam is on. When you pull the stalk, both beams are activated. This causes the bulbs to blow quicker.
You may not be doing this... just a potential reason that came to mind.
razor4077 is offline   Reply With Quote
Old 25th September 2007, 19:12   #877 (permalink)
ad75's Avatar
will a 100/90 halogen damage the reflectors in m800?
ad75 is offline   Reply With Quote
Old 25th September 2007, 20:28   #878 (permalink)
gopz's Avatar
No, it wont. But make sure you get a relay installed.
I have been using this from the past 2 years and it has done no damage. Go for it!
gopz is offline   Reply With Quote
Old 26th September 2007, 09:06   #879 (permalink)
sathya_nars's Avatar
BTW, sorry for basic question.
What does it mean when we say 60/55W? what do these 2 figures mean?
sathya_nars is offline   Reply With Quote
Old 26th September 2007, 09:19   #880 (permalink)
power_slave77's Avatar
Default Hb3/9005 and hb4/9006
Hi guys,
I have a 2002 Honda accord automatic. I am not happy with the lighting on my car. Accord comes with 2 separate bulbs. One for Low and one for High. The low beam is sylvania 9006 hb4 (55W) and the high beam is sylvania 9005 hb3 (60W). These are good for city, but pathetic on highways. I want to upgrade to either 90/100 or go for better quality bulbs. But i searched the entire JC road and other major shops in Bangalore. I also called the the philips dealer in bangalore. None of them have these HB3 and HB4 bulbs. I guess even Civic comes with the same bulbs. Can anyone suggest me where can i get these bulbs in Bangalore.
I found that Philips crystal vision bulbs (55/60W) are available on ebay. Some guy in Bombay has it. It is 1140 per pair. I am not sure if i must go for it. Will crystal vision improve the quality of light?? I have seen lot of people giving negative feedback about it. So i am worried. But this would be a very easy job. All i have to do is remove the old bulbs and put a new one.
100/80 W bulbs are not available in india i guess. I need to import it from UK or US. But again for this i need wiring harness and ceramic holders and relay. I need to cut the existing wiring. Is it worth all this ??
Please suggest.
power_slave77 is offline   Reply With Quote
Old 26th September 2007, 15:43   #881 (permalink)
akshay1234's Avatar
if you need the extra light then get the relays etc. and get 90/100w bulbs. they will make a huge difference.
akshay1234 is offline   Reply With Quote
Old 26th September 2007, 17:04   #882 (permalink)
ramkya1's Avatar
Arrow 90/100 W makes a big difference
Hai,
Last friday we changed the stock Philips bulbs (60 W) to a Philips 90/100W in two cars. In a Scorpio and an Essteem. Our friend who is a car electrician (last 10 yeas practice) said you don't need a relay till 100 W, he says, you exeed 100 rthen relay is warranted. Both the cars have increased outputs; new Scorpio has a 20-30% improvement, the 3 year old esteem has a marginal improvement, the reflectors need replacement.
The accessaries guys said if we don't put the relay there are many dangers: 1) The bulb will conk out 2) Wiring might burn up 3) The contact points of the switch assembly will burn out 4) The reflecters will burn out. However, our electrician was so confidant, he said he has been doing this work for years and there has been no problem to run without a relay !!!! Moreover, stock bulbs or upgrades, the reflectors will loose their sheen in 3+ years.
We did a small research on the costs: Philips comes in two packings, bulbs are the same. Manufactured in Germany, marketed thro. Thaiwan & China. The yellow cover and while covers. Cost is 135 for one bulb. Wiring kit, local 200/-. If you buy the MKS relay (they sell the relay only) its 235 for the relay only, wiring harness is 200/- extra. The Mico relay costs 450/- wiring kit extra 200/-. Wiring kits are available from 200/- to 500/- in many qualities. I am sure these prices may vary across the nation, except for the philips bulbs.
I am waiting for some time to upgrade for my car to see how the bulbs in the Scorpio and Esteem are performing without the relay.
Happy Driving,
--Ramky
ramkya1 is online now   Reply With Quote
Old 26th September 2007, 17:22   #883 (permalink)
akshay1234's Avatar
buy a relay. your friend is wrong.
Old 26th September 2007, 17:27   #884 (permalink)
TomCyatz's Avatar
Default Xenon Vs Halogen: A must read for those who wish to upgrade
Hi Friends,
It all started when I decided to upgrade my Alto's headlight possibly to something better. So I looked out here for suggestions and other reviews on the net.
At one point I was almost done with wasting my money on cheap imported Xenons on the advice so called experts in the after market who just want to sell of things. ( He promised to give me Sagitta xenon lamps imported from Taiwan for just Rs 1200 claiming it as a discount price.Installation procedure is simple. Just replace the bulbs.That is what he said. I was almost done by his blah blah, decided to buy it and waited for the technicla guy to do the installation. At that time, my wife called and I had to urgently leave . So I said excuse and left the place. )
To verify the marketing guy's claims,I went through this thread carfully and after reading most of your reviews and suggestions I did some research on the net .
The result is, Thank god I escaped somehow from wasting my money.
The following is the conclusion that I reached .
Please correct me if I am wrong in any of the points:
1) Xenon headlamps are technically known as Xenon HID light.
HID stands for High Intensity Discharge, and refers to the technology involved. Instead of a glowing filament, the light is generated by a spark which jumps across a gap constantly - just like a constant arc of mini-lightning.
2) Xenon's produce more , but not better light we expect on practical driving environments.
The colour of the Xenon lights are a lot closer to that of daylight. This is noy necessarily a good thing: At night, your eyes adapt to the warmer tones of the motorway lighting and other drivers, and the daylight-colour of Xenon lights might be problematic, as the eyes may not be able to register colour information correctly. In addition, light from Xenon lights is of very specific colours, rather than a continuous string of all colours of the rainbow
3) Xenon's cannot be proper upgrade for a halogen lamp assembly. The main difference is that Halogen bulbs use reflectors to aim the beam, but most HID-headlamps use lenses. Replacing a halogen bulb with a HID-bulb and assembly will frequently be illegal, and will cause safety to decrease, both for yourself and for the other road users
If you upgrade, 99% of teh time you are lost, because as experts suggest it is something to be done with lot of homework and expertise which you can never get in the aftermarket.
4) You cannot replace a halogen bulb with a Xenon bulb.Cheap Xenon look alikes in the aftermarket are just gimmics.
A full Xenon lighting system consists of
the following components:
1 Xenon light source
2 Ballast
3 Igniter
4 Reflector
5 Lens
There are a few packages out there that replace the entire headlamp assembly (i.e the front glass, filters, lenses etc) with a HID unit. These are of varying quality, but could only in theory work correctly.
5) So, is it logical, should you choose Xenon headlamps?
Advantages
Xenon lights give a higher light output than their halogen equivalents, it allows car designers more freedom in designing unique-looking cars which still fulfill the needs for strong light.
It improves the look of the car when upgraded in the aftermarket.
Disadvantages
In theory, Xenon is a good idea. In practice, more light doesn't necessarily mean that the quality of your night-vision is any better. In fact, it may be worse: The fact that the light is so bright could make your eyes adjust to the brightness. This means that you can see perfectly right in front of your car, but especially on wet roads, the glare may be tiring and problematic. In practice, despite the light being brighter, you may not be able to see further in front of you at night.
Please refer this site for more information about HID's.
Daniel Stern Lighting Consultancy and Supply.
http://www.mvlc.info/pdf/MVLCbrochure.pdf.
Those of you really want to know why Relays's are important during upgrading to a higher wattage, this link is informative.
So I have decided to upgrade to PHILIPS,OSRAM or BOSH Halogens. Haven't yet decided, whether to go with the same wattage better bulbs or higher wattage and bulbs. My alto is the model without clear lens lamp. So those of you guys who had done similar upgrade can help me.
TomCyatz is offline   Reply With Quote
Old 26th September 2007, 17:47   #885 (permalink)
hay friend thanks for that....
i do use High beam with low beam and that may be makes the bulb go off... right now i have fixed the stock headlighs as i was tired opf chaning the bulbs.. not that i got the reaason, i better fix the 100/130 as i already have the realy. and will follow the instructions by you team-bhp fellow mates...
thanks to one all for replying...
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 31 18th August 2008 15:48
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 12:42
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439
