| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #76 (permalink) | |
| Senior - BHPian | Quote:
But a little advice to those who want to convert to 100/90W - Mind you, these bulbs are really powerful for you and also for the oncoming traffic. Please do not use the bulbs for aggressive and offensive night driving. Rather use high beams as a defensive technic.
__________________ *06 Alto LXi* *97 Zen LX* *03 HH Ambition* *RC Cars - HPI Baja 5B SS, Thunder Tiger SledgeHammer S50, ST-1 & Sparrowhawk XB* | |
| | #77 (permalink) | ||
| Team-BHP Support ![]() | Quote:
The problem with white light is that on well lit streets with sodium lighting they appear to be "less powerful". But if you are talking about ability to illuminate cyclists etc,. they are amazing. One disadvantage is fog. In fog the normal lights which have yellow tint will do better than the white ones. Quote:
From hyundai stable, the Getz does not come with 100W relay, thats why we got 60/55W Vision+ If a relay is not there, you can blow a fuse if it reaches tolerance limit, and blowing fuses on dark unlit highways is not fun. I think there need not be so much hesitation to get a rs 300 part which will save you from such incidents As for high+ low beam thing, some gyan. Halogen H4 technology is not some rocket science. Its more to do with glass technology. Basically, the higher the gas pressure, the better the light output, as it increases filament temperature which gives better light. So your high performance bulbs, which claim to give 30%, 50%, 80% more light at same wattage do this by increasing gas pressure and increasing filament temperature. For this they use special glass which is resistant, but such high pressures, esp for the 100/90W high performance bulbs means that glass is at its tolerance limit. So when you do high+low you have 2 filaments active at same time. Double the pressure almost. Sustain it for long time, and your halogen will go pop. So avoid it. Another disadvantage which is inherent is sensitivity to your electrical system. As nitrous told me in another thread, an indigo blew headlights because of over voltage due to alternator regulator fault. Therefore before you go for high performance 100/90W(not regular 100/90W with older tech) make sure 1. You have a relay to bypass the current from your electrical system 2. Do not use high low beam together 3. Make sure even while revving the voltage at your battery terminals does no exceed 12.8 volts with headlights on. IF you have stock wiring, it will give a voltage drop which will mask your regulator problem. But with wiring harness where there is no significant drop, you have to be careful.
__________________ Reclaimed, wrung dry and recycled....! Last edited by tsk1979 : 13th December 2006 at 14:31. | ||
| | #79 (permalink) | |
| BANNED Join Date: Feb 2005 Location: Mumbai
| Quote:
You may not see a visible difference, but it will prevent your electricals from overloading and going kaput when you're driving in the middle of the night. It's always neccessary to install a relay when upgrading to overwatt bulbs, unless your car is preinstalled, as some cars are. | |
| | #80 (permalink) |
| BHPian Join Date: Apr 2006 Location: Bangalore
| I got the Head light bulbs (100/90 watts) replaced the 130/100 philips ralley along with the relay and the holders in my esteem (2004). I noticed that as soon as I turn the headlights on, the engine sound changes and I feel that the engine is getting over loaded. But there is no change in the engine performance with the lights on. Can some on tell me if this is a normal thing that is happening? Or I have to get it checked? Or is it time for me to replace the battery? This is noticible only after I got the bulbs upgraded to 130/100 philips ralley. The lighting is very good with 130/100 on highways. I never use the high beam in the city roads. |
| | #81 (permalink) |
| BHPian Join Date: Oct 2006 Location: Kochin
| hey guys i wud like to change the headlights on my zen.. its an LX.. the 2002 model.. i drive down to b'lore quite a lot.. the standard bulbs are too bad to drive on highways.. any recommandations as to what i shud change my headlights to..?? pls give me the ratings and specific brands if any.. and anyone knows a gud shop in cochin ver i can go in for the works..?? ur replies wud be much appreciated guys.. Note from the Team-BHP Support Staff : Slang and SMS Language are STRICTLY prohibited on Team-BHP. Please type in full and proper English for the benefit of other community members. |
| | #83 (permalink) | |
| BANNED Join Date: Mar 2006 Location: India
| Quote:
You can get these from any reputed automotive spare shop or accessories shops. If you have the stock wiring for the Headlamps, it will have to be replaced with a more higher capacity headlamp wiring kit. This can be done from any service workshops or accessories shops. If you have some spare time, visit Emperor @ Palarivattom, Car shoppe @ Palarivattom, General motor accessories @ Mamangalam or any nearest shop in Cochin. Wanna know more? Come for our proposed meet. Read about it here: http://www.team-bhp.com/forum/team-b...-2006-a-8.html (Rumble in the Jungle - Kerala Meet) P.S. Next time, type properly to avoid warnings. ![]() | |
| | #84 (permalink) | |
So if you car is not giving any starting problems etc., no need to get anything checked. About the relay and wires, do you have a 300W relay or a 200W one. 200W one can go kaput with 130/110W bulbs.
__________________ Reclaimed, wrung dry and recycled....! | |
| | #85 (permalink) | |
| Quote:
And what you're experiencing is normal. Nothing to worry about!! | |
| | #87 (permalink) |
| The low beam does not do that, high beam does. I never use it in the bangalore trafic. Most of the time I use my fog lamps, which is more than enough. But I really feel that I need bright light on high ways and bad roads. |
| | #88 (permalink) | |
| Quote:
100/90 would be fine enough for highways too. | |
| | #90 (permalink) |
| BHPian | Okay a quick deal..... Two hella 4000 (luminator series) for 6k or 4 hella comet's for 2.5k?? I drive an alto... For all the morons who drives with bright lights and refuse to dip....... What do you guys think??????????
__________________ Wear your seatbelt (I will vouch for it) Last edited by Knight Rider : 19th December 2006 at 17:37. |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
