Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 9th October 2007, 19:25   #946 (permalink)
kpbhatt's Avatar
one query regarding Indigo LS -- is it possible to retrofit Xenons as against the manufacturer recommended Lumax pieces that come in as OEM ? if so which size and brand should i look for ?
__________________
1991 Ford Taurus
1992 Honda Accord
1999 Plymouth Grand Voyager
2004 Tata Indigo
kpbhatt is offline   Reply With Quote
Old 9th October 2007, 19:34   #947 (permalink)
akshay1234's Avatar
you can fit them. but do you have the new indogo or the old one? the old one had an h4 bulb. the new one has 2 bulbs. one for low and one for high. not sure what sizes those are.
akshay1234 is offline   Reply With Quote
Old 9th October 2007, 20:54   #948 (permalink)
Default Civic Angel Eyes/Projection HeadLights in Mumbai/Pune
Hi
I am buying a Honda Civic by the end of this month and was facinated by the Angel Eyes/Projection Headlight Kits displayed. Can smone pls tell me from where can I get them in Pune or Mumbai. And wat is the approx price??
diezel is offline   Reply With Quote
Old 10th October 2007, 10:26   #949 (permalink)
gopinathann's Avatar
Originally Posted by diezel View Post
Hi
I am not sure about Honda Civic, but I have seen angel lights for Swift in ebay.in which costs around 35K.
I don't know why they cost this much. The idea is very simple if you watch the following link.
Angel Eye Modification
__________________
Why do they call it rush hour when nothing moves?
_________________
SX4 ZXI - 2007
gopinathann is offline   Reply With Quote
Old 10th October 2007, 11:58   #950 (permalink)
crazydiablo's Avatar
Question for Baleno:
Recently one of my 100/90W bulbs fused. Question is buy that one or move to blue vision?
How is the bluish light at night? is it better than crystal vision? hows the focussing?
crazydiablo is offline   Reply With Quote
Old 10th October 2007, 13:46   #951 (permalink)
Life time of the bulb.
Blue - *
White - **
Yellow - ***
Light intensity & spreadness
Blue - *
White - **
Yellow - ***
Yellow is best and Blue is worst. This is one of the reason why I didn't go for blue.
__________________
_________________
SX4 ZXI - 2007
Old 10th October 2007, 13:51   #952 (permalink)
mobike008's Avatar
I disagree with your ratings. White lights indeed give you better spread than yellow lights, if your rating is true then all xenon owners should throw their lights out and get yellow bulbs fitted.
I dont know about blue, but it cant be that bad.
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 10th October 2007, 14:40   #953 (permalink)
ST7677's Avatar
I am planning to go for 6000k Xenon for my Civic, but along with them I would also want to change my parking/DRL lights and High beam to super white lights. What is recommended?
I think the stock Highbeam bulb is 65 W.
Should I go for 100W Philips Crystal / Dimond vision bulb?
Note: I do not want to change my wiring or add additional wires...!
ST7677 is offline   Reply With Quote
Old 10th October 2007, 14:51   #954 (permalink)
mobike008's Avatar
If you decide to go for anything higher than stock bulbs like 90/100 or 100/130 then you will definetly need a relay. Dont install otherwise
__________________
Old 10th October 2007, 14:54   #955 (permalink)
ST7677's Avatar
Moobike008, Yellow light is indeed better, because human eye is more sensitive to it.
Most stock Xenon lights are 4500k colour which are on yellowish side. They appear white / blue because you watch them from an angle and not directly from front.
Since the light comes through a projector lense, white and blue component of light disperses (prism effect) and hence the light appears white / blue from angle.
Higher color temp lights 8k, 10k, 12k go from blue to ultra violet range but our eyes are less sensitive to them.
You would notice most people using xenon look alike white lights facing visibility problems because of this issue.
After market Xenons can still live up with higher colour temperature like 6 k because visible light output of xenon is 3 times more than std halogens, so sensitivity loss of colour is compenstated by additional brightness.
BTW, Day time light colour is about 5400k
Old 10th October 2007, 14:57   #956 (permalink)
ST7677's Avatar
I would want to make sure of that, because there is hardly much difference from 65W to 100W, and I am told that most modern cars do not require additional harness.
But I would like to confirm on that...
Also, If I do what risks do it run, blowing up a fuse or burning down the whole car...???
I also wanted to understand what does stock 65/55 means?
The Xenons typically operate at 35 watts... what implication it has on other lights...
Is the supply treated individually or combined (65+55)
Old 10th October 2007, 15:02   #957 (permalink)
vid6639's Avatar
A 90/100w is a sufficient amount of current increase. The minimum damage you would have is a blown fuse. But more likely is to fry up the wiring and probably damage to the ECU as the worst that could happen.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 10th October 2007, 15:04   #958 (permalink)
mobike008's Avatar
55/65 means 55 wattage for low beam and 65 wattage for high beam. It is possible to go up to 90/100 without a cutout but there is a risk of fuse blowing not the entire car getting burnt down . One of my friend installed a 100/130 with a relay in his viva crdi and his clear lens have darkened a lot when i compare it with mine.
I am running on 90/100 yellow bulbs with relay and quite happy with its results.
__________________
Old 10th October 2007, 15:14   #959 (permalink)
ST7677's Avatar
so can I safely go 35 W for low beam (xenon) and 90W or 100W for high beam (halogen), without changing wire?
(total still doesn;t change much from 65+55=120; 35+90=125)
Old 10th October 2007, 15:31   #960 (permalink)
Team-BHP Moderator
tsk1979's Avatar
huh?
Care to elaborate please.
any source of your information.
I have never heard of such a thing. It actually depends on a number of factors and the color of the light is not one of those.
__________________
Reclaiming.....!
Thread Tools
LED lighting in cars gigy Technical Stuff 33 6th September 2008 02:02
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 12:42
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
