Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 26th November 2007, 13:39   #1126 (permalink)
What will happen if installs 90/100 philips bulbs without installing cutouts ( relays ) ?
TIA
nicejits is offline   Reply With Quote
Old 26th November 2007, 13:44   #1127 (permalink)
tsk1979's Avatar
TIA
Best case : you get light which is less than that off a 60/55W bulb
Worst case : Your wiring burns and you are left without a headlight
Halogens work best around 13.5-14V. The voltage at your battery terminals with engine on will be around this range.
Having a thin wire means voltage drop. A 5% drop will reduce your light output by 20%.
__________________
Reclaimed, wrung dry and recycled....!
Old 26th November 2007, 14:05   #1128 (permalink)
Hi Guru's,
I need to install fog lamp in my 2003 ikon. The odd shaped one.
what will be the make and price? where can i buy it in chennai?
Ford_madhan is offline   Reply With Quote
Old 26th November 2007, 19:42   #1129 (permalink)
ashthedivx's Avatar
Originally Posted by rendezvous View Post
I was told that this is excellent combi for an Optra for lights mod:
low beam - H7 - HID
high beam - H1 - Philips crystal/blue/diamond vision
Whats the opinion about it? How costly this deal can vary?
Just in case, if I go for Philips crystal/blue/diamond vision H7 (low beam) & Philips crystal/blue/diamond vision H1 (high beam) for optra, how good is it?
I would try to answer this, as right now i am also struggling into the same thing right now...
What i have rounded off is
low beam - H7 - HID - Cheaper/with warranty BOSCH around 6-6.5 K, on higer end you can go for phillips or any such high end HIDs
high beam - H1 - Philips crystal/blue/diamond vision - should cost between 500-700 depending upon ur choice.
Ashi
Old 27th November 2007, 01:24   #1130 (permalink)
Thanks Ashi but I was given round figure of somewhere 8-9k for BOSCH kit. I'm unsure about it & special care has to be taken while fitting in HID kit in car.
Any suggestions or comments, TEAM-BHP???
rendezvous is offline   Reply With Quote
Old 27th November 2007, 09:14   #1131 (permalink)
Gurus,
One more question:
Is it possible to replace the reflectors alone? Are there any performance reflectors?
lsjey
__________________
2000 - > Wagon R Lxi
Pre 2000 -> Nataraja service
lsjey is offline   Reply With Quote
Old 27th November 2007, 10:58   #1132 (permalink)
neoonwheels's Avatar
Hi guys,
One update on Vision Plus: I got a reply from Phillips marketing West zone that [FONT=sans-serif][SIZE=2]Vision Plus type of bulb is no longer in their range[/SIZE][/FONT]. So this ends my search for Phillips Vision Plus H7.
Guys could you please let me know how Crystal Vision is mainly for highway driving? and Does Crystal Vision mean white light? Below is an extract from the mail I got:
[FONT=sans-serif][SIZE=2]Dear Abhijeet,[/SIZE][/FONT]
[FONT=sans-serif][SIZE=2]Vision Plus type of bulb is no longer in our range,but i am surprised to know that you could not find Philips automotive products in pune, because i myself have seen all the accessory dealers selling our full range.There are some new products instead of the Vision plus,which are better light out put like Xenon systems,Crystal visions and lot more.[/SIZE][/FONT]
__________________
NeoOnWheels
FIAT Palio 1.2 Sport
Wishlist: Linea FIRE 1.4 / 1.4 TJet
neoonwheels is offline   Reply With Quote
Old 27th November 2007, 15:57   #1133 (permalink)
joe_mclaren's Avatar
In need of Philips crystal visions H7 for my esteem? Can someone source it?
joe_mclaren is offline   Reply With Quote
Old 27th November 2007, 23:10   #1134 (permalink)
jkdas's Avatar
Default 90/100W upgrade for Santrp Xing
Sun wiring kit( includes relay) = 500Rs.
Bosch 90/100W Halogens x 2 = 160Rs
Fuse 20Amp x 2 = 10Rs
Fitting = 50Rs
Total = 720Rs
No wiring cutting was done!
PMP also has a kit which is similar, plug and play, for same price.
__________________
Audio, video, disco
Tat tvam asi
Old 27th November 2007, 23:30   #1135 (permalink)
tsk1979's Avatar
500 is steep. Did it comes with ceramic holders which can take high wattage? Holders are very important. I used a local wiring kit before getting roots 130x2W kit, and one of the holders partially melted.
With roots wiring kit no such issues now.
__________________
Old 28th November 2007, 08:51   #1136 (permalink)
jerish666's Avatar
Please suggest a good light for SKODA Tdi 1.9.
jerish666 is offline   Reply With Quote
Old 28th November 2007, 09:55   #1137 (permalink)
jkdas's Avatar
Not ceramic, plastic I guess but with extra covering. Seems the people came back with issues with 130 and hence asked me to avoid.
For Jerry, its Xenons.
__________________
Audio, video, disco
Tat tvam asi
Old 28th November 2007, 19:16   #1138 (permalink)
Hi all,
I want to mod Optra's lights from company fitted to white light. All your advices will be appreciated.
I heard something about projected lights. Whats that?
How about HID kit? What cost?
what about lights for low beam, high beam & fog lamps?
Kindly give your precious opinions. What cost in total & who's the best dealer for all this in Gurgaon / New Delhi?
Vik
Old 28th November 2007, 20:42   #1139 (permalink)
For the headlamp? If so then it should be H4 right ?
__________________
No fate but what we make!
Old 28th November 2007, 21:07   #1140 (permalink)
shuvd's Avatar
Guys, need some help.
1) Are the Octavia fogs H7s? Can HIDs be used as fogs?
2) What are the specifications for the Magnum head lamps and fogs? What upgrade options do I have?
__________________
I (still) feel the need...the NEED for SPEED
shuvd is offline   Reply With Quote
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
