Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 3rd January 2007, 16:40   #106 (permalink)
Team-BHP Moderator
tsk1979's Avatar
When your headlights are on in dipper position the stalk is towards you. When you throw the stalk forward you activate high beam. This is correct usage.
While in dipper position if you pull stalk towards you both filaments will get activated. But this position will remain as long as you are pulling stalk when you release stack it will come in dipper again.
In daytime you can pull stalk towards you when lights are off to flash your lights, this will activate only high beam, and not both beams.
Pulling stalk towards you activates high+ low when headlights are on.
__________________
Old 3rd January 2007, 17:01   #107 (permalink)
@mail4ajo,
I think you drives Alto, in alto when you will will pull stalk towards you low beam will be deactivated automatically.
so there is nothing to worry if you drives Alto.
Mugen.
Mugen_Power is offline   Reply With Quote
Old 3rd January 2007, 17:05   #108 (permalink)
mail4ajo's Avatar
Ohh my god, I almost burnt my new set of 100/90W bulbs. I always use the dipper the way TSK explained. When my bulbs are in low beam, I pull the stalk towards me and release it. The bulbs automatically go into high beam. I followed this because, this is the method mentioned the car manual.
Thanks to TSK for pointing this out.
__________________
*2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135*
mail4ajo is offline   Reply With Quote
Old 3rd January 2007, 17:14   #109 (permalink)
Team-BHP Moderator
Technocrat's Avatar
@mail4ajo: Dont worry bro like Mugen_Power said it does not happen in Alto
__________________
180, 225, 150, ??? -> 159?
Old 3rd January 2007, 17:21   #110 (permalink)
Dont worry, Nothing to worry in Alto.
Old 3rd January 2007, 17:25   #111 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Its different from car to car.
In Tata safari you have to pull stalk towards you and release to switch to high beam. Repeat action to switch to low and so forth. So the method mentioned in your manual is the one to be followed
I was talking about 800s, Indica's, OHC etc., where when one is in dipper moving stalk towards you puts high and low beam together.
__________________
Old 5th January 2007, 08:08   #112 (permalink)
Hi... I have Wagon R VXi. I have decided to upgrade my head lights to Philips Rally 100/90 based on the threads going here. Can I directly replace the existing bulbs or I have to fix Relay and improve my existing Wiring?
And one more Question, I saw a provision under head light to fix fog lamp. Can i fix a new set in that with philips 100/90 bulbs?
jeyadev_k is offline   Reply With Quote
Old 5th January 2007, 11:30   #113 (permalink)
Team-BHP Moderator
tsk1979's Avatar
For wiring and relay, you can get any Kit. cost of wiring+relay kit is around 350rs.
As per fog lamps. you can go for OEM fog lamps. Fog lamps are not H4. So they have single wattage and not 100/90W or 60/55W dual wattage.
You can get any H3 equipped headlamps, but usually 55W are enough.
__________________
Old 5th January 2007, 12:41   #114 (permalink)
sumitkalindi's Avatar
Hi, Just my two pence. Usually in most of the vehicles, the headlight stalk has the following position,
Down, High beam,
Up,Low beam
(while changing from the high beam to low beam & vice versa, you hear a click, and you can feel it also,)
Pass, you have to pull the stalk towards you from the Up position.
There is no click, but you can feel that this action is spring loaded, so when you release the stalk it returns to Up position-Low Beam.
PLEASE NOTE THAT IN YOUR CAR THE WAYS TO ACTIVATE HIGH BEAM, LOW BEAM, AND PASS MAYBE DIFFERENT. Please check the manuall of your vehicle.
Pass is used to flash the high beams only momentarily. All the bulb manufactures recommend that Pass should not be used for more than 10 Secs.
So as long as you really use the Pass position to only flash your high beams it is OK
Enjoy
sumitkalindi is offline   Reply With Quote
Old 10th January 2007, 21:42   #115 (permalink)
Guys, just being careful.
Won't using such high wattage bulbs void your Car Insurance claim incase the cause of an accident is found to be due to the driver of the oncoming vehicle being blinded ?
autoenthusiast is offline   Reply With Quote
Old 10th January 2007, 23:04   #116 (permalink)
iraghava's Avatar
How many cases have you ever heard about where a driver was convicted for an accident because he blinded the oncoming vehicle???
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 10th January 2007, 23:29   #117 (permalink)
scorp 1's Avatar
Hey, can someone guide me to a good HID kit for the Honda City Zx.
Can the fog lamps have the HIDs installed too ? What is the market price for these kits ? Finally, is it possible to remove the kit and use it on another vehicle (when planning to sell off the car) ?
__________________
The only lines that matter are the ones you make
scorp 1 is offline   Reply With Quote
Old 10th January 2007, 23:43   #118 (permalink)
You can get Philips HID kit with B/W or some other brands without B/W.If your budget permits than you can HID kit to fog lamps also.
Other brands are for approx 16K and philips around 20K. You can remove kit and fit original lamps within few minutes.
Old 12th January 2007, 05:44   #119 (permalink)
mithun's Avatar
I haven't heard of convictions in Indian land, but I've heard about a lot of accidents caused by the glare of high intensity lights especially in the case of 2-Wheelers.
Most of HID owners thinks that they are night-hawks and they give a damn for the oncoming vehicles !!!
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 12th January 2007, 05:59   #120 (permalink)
iraghava's Avatar
Well then you need to go out & see what the truckers think of themselves, 'cause most of them have their headlights positioned at such an angle that it becomes almost impossible for even an experienced driver to not be blinded. They are out in huge numbers on our roads compared to the microscopic minority the HID owners are in.
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 24 26th July 2008 21:05
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 12:42
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
