| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #1186 (permalink) | ||
| Senior - BHPian | Quote:
Projectors help focus the light and so your car wont have that UFO look to it. I dont see why the cops should bother you if you have a projector setup . Quote:
__________________ No fate but what we make! | ||
| | #1187 (permalink) | |
So the Narva H8 bulbs of 4000K are regular halogens and not xenons, correct? ![]() And if so, then what is their wattage? | |
| | #1188 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| 1. Has anyone got HID's fitted in a Safari DICOR? If so, * Which ones and for how much? * What has been your experience so far? If not, what are the options? * Osram Silverstart 50+ as @simply_sunny001 and @suman-ji recommended * Switch to 100/90 (with Bosch/Roots kit) - which one? 2. Anyone improved the fog-lamps? (Not sure which bulbs are in there) If so, what did you do? 3. What would be an alternative to fitting Hellas on the bull bar (I don't have one)? Mount them rally-style on the roof? What if I don't want them up there permanently? I have in the past used them at grill-level, but the experience was not satisfactory. Need to do some highway driving in the night on the west coast - hadn't given improvements to lights a thought till now. Help much appreciated!
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #1189 (permalink) |
| Team-BHP Support ![]() | Hi DerAlte, good to see you out of the ICE section ![]() Anyways coming to Osram 60/55W they are brilliant. Using them in a 3.0 DICOR, and the throw and intensity is adequate for highways. I am not a big fan of HIDs in reflector setups. I have seen 3 setups in 3 different cars, and though the light was amazingly bright, a large portion of it is scattered leading to tremendous glare for oncoming traffic. Sourcing a projector setup for safari will be next to impossible. Coming to halogens, use the 60/55W. Its the best solution and you don't needs relays and holders. As for the fog lamps, they are too tiny to give much benefit for long throw. However if you can source generic round projectors, thats a nice place to fit in the HID. You will have to remove original housing. Please note that any wiring mods can void your warranty. Since you are in Bangalore you can go to concorde(Tata workshop) and ask them to fit you a relay. After that you can go ahead with 100/90W bulbs(if you find the Osrams lacking). The best 100/90 I have seen are the Halonix +60. Philips ralleye is also good, but sadly originals are hard to come by. Rudra suggested Flosser but couldn't get them in Noida. They are available in BLR though.
__________________ Reclaimed, wrung dry and recycled....! |
| | #1190 (permalink) |
| BHPian Join Date: Oct 2005 Location: Dublin, OH
| My answers in bold... 1. Has anyone got HID's fitted in a Safari DICOR? If so, * Which ones and for how much? * What has been your experience so far? Yes I have a Safari Dicor 3.0 and I have tried all sorts of bulbs in the market ranging from the Phillips 90/100, Halonix +60 to the Phillips 100/130 watts. As of now I am content with 100/130 Phillips Rallye. I also tried the Bosch and Siemens HID kit without the Projectors but apart from the light being bright it did not have a good throw and hence was not satisfactory on the highways, so switched back to the 100/130 Rallye’s. 2. Anyone improved the fog-lamps? (Not sure which bulbs are in there) If so, what did you do For the fog lamps I just upgraded to a brighter H3 Bluevision lights although they are whitish in the beam colour and not Blue, but quite sufficient for lightening up the sides of the road 3. What would be an alternative to fitting on the bull bar (I don't have one)? Mount them rally-style on the roof? What if I don't want them up there permanently? I have in the past used them at grill-level, but the experience was not satisfactory I also thought of the same to put the Hella’s or any other Fog lamp on the bumper but then did not want the bumper to be drilled upon so got the bull bar fitted only to mount the fog lamps. I have a Korean brand (am forgetting the name) but they are all weather types. Good enough for navigating through delhi fog and recently I found them to be quite decent enough on my last highway trip on NH 8 specially in Punjab. Apart from this its illegal to have any kinds of lights mounted on the roof as per the motor vehicle act. They should be techinically at the same height as your headlights are..
__________________ Getz CRDi 08'/ Safari Dicor 3.0L 06'/ Ikon Flair 05'/ Vitara 2.7L V6 "We all have ability. The difference is how we use it." |
| | #1191 (permalink) |
| Team-BHP Support ![]() | For the fogs a good idea could be to get H3 HID kit. It costs around 93 USD when ordered online. The lamps are low so it will not blind oncoming users, and you will get a very good high instensty spread. @Dragonov, is the fog lamp bulb change DIY(like the H4 change) or you need to dismount the bumper?
| | #1192 (permalink) |
| Senior - BHPian | This is what im planning, my friend has an fog lamp HID kit thats of no use to him. Only issue is that its 8000k which more intensity and less visibility. If the swift fogs are indeed h8 then Im 99% installing the HID's. Are the halonix/narva available in white for 100/90 ? Hows night visibility ? Bumper would definitely need to be removed for the fitment.
__________________ No fate but what we make! Last edited by s0uljah : 13th December 2007 at 14:33. |
| | #1193 (permalink) | |
| Team-BHP Support ![]() | Quote:
Halonix is a normal bulb, Narva gives white light (4500K)
__________________ Reclaimed, wrung dry and recycled....! | |
| | #1194 (permalink) | ||
| I do venture out sometimes, but being in that wild bunch is generally a good diversion from work for me - like looking at green things if your eyes are tired! Wackier than even the Jokes section - everything repeats but funnily nothing is the same in every new instance.Quote:
Thanks, forewarned is forearmed!
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||
| | #1195 (permalink) | ||
| Quote:
__________________ Getz CRDi 08'/ Safari Dicor 3.0L 06'/ Ikon Flair 05'/ Vitara 2.7L V6 "We all have ability. The difference is how we use it." | ||
| | #1196 (permalink) |
| Senior - BHPian | I have upgraded my Innova's headlights to Phillips 90/100 H4 Rally bulbs and person with good experience in this industry told me for Relay and wiring is not needed for Innova unless its 100/130 upgrade. I have paid 300 rs for pair of bulbs. Anyway let me use it for few months and see If I find any issues with it. Regards, Ravi. |
| | #1198 (permalink) | |
Thanks for differentiating between the halonix vs narva. Are Narva available in 100/90? ![]() This is the chart from the manufacturer of the kit's my friend got.
__________________ No fate but what we make! Last edited by s0uljah : 13th December 2007 at 18:36. Reason: added image | |
| | #1199 (permalink) |
| BHPian | Hi, I have an Aveo 1.4. Can anyone suggest a good shop in Bangalore and/or a good brand of powerful driving lights (bumper level) which will integrate more or less neatly with the stock bumper? GM sells the OEM lights but they are 9.5k and have old-fashioned lenses and not the clear ones which look much better. 9.5k is a lot of money and I would much rather spend the same on a professional fitting of quality lights/fogs.
__________________ Into each life some rain must fall Last edited by itwasntme : 13th December 2007 at 18:46. Reason: Typo |
| | #1200 (permalink) |
| Team-BHP Support ![]() | Nothing to do with manufactures here. 8000K will look the same irrespective of manufactures. Anyways, the only way to check true rating(in case of HID kits) is to use a light meter. A simple way is to click a pick in RAW mode and set the white point at a grey card illuminated just by the headlight.
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
