Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 2nd January 2008, 18:51   #1246 (permalink)
Default Xenon for NHC
Hi guys,
Can you please let me know if anyone has any experience with changing the stock headlight bulb of NHC with Xenon. If yes, howz the experience and approx how much it costs?
thanks
skydiver is offline   Reply With Quote
Old 2nd January 2008, 19:32   #1247 (permalink)
n_aditya's Avatar
For the second time my RHS high beam filament has fused (in about 6-8 months). Using Philips Rallye 130W/100W with relay and all. The previous bulb lasted over a year. The LHS however is still going strong for over 2 years and with no change yet. *touchwood*.
Do i need to get the electricals checked? Had got it checked last time and was told its ok. Are these bulbs prone to low operating life? I dont think so cos the LHS bulbs are fine and they are the first set for almost over 2 yrs now.
__________________
Download Junkie !!!
Old 2nd January 2008, 19:48   #1248 (permalink)
@ kartik iyer - i have the pre crde scorpio and have been using the 100/130 headlight bulbs with cutout etc. 'touchwood' no issues till now.
rgds
indianrunner is offline   Reply With Quote
Old 2nd January 2008, 20:01   #1249 (permalink)
arpandiv's Avatar
Originally Posted by kARTIK IYER View Post
have fitted standard Lumax lights on my bumpers , It really is not of great help and light thrown is average and is now use as a additional light . Can you suggest a good bulb that i can replace this with current ones and what will be cost
Could you post a pic of the light along with the mounting?
Lighting from such lights depends on
1) reflector
2)Mounting
3)wattage of bulb.
Such bulbs usually take in a H3 bulb.
try putting in a Phillips 100W h3 bulb,make sure your wiring supports this though.
Mount the reflector in such a way that it is able to focus light onto the area where you need it. What kind of illumination are you looking for? a spread ? or a spot?
arpandiv is offline   Reply With Quote
Old 3rd January 2008, 19:32   #1250 (permalink)
kARTIK IYER's Avatar
Hi ,
It is fitted in the bumpers where there is space for extra lamps on the bumpers and it is not the refelector ones .
If you can suggest me then i will discard this one and install a reflector one with better visibility as this is showing me area road right below till some distance ahead .
Rgds .. kat
kARTIK IYER is offline   Reply With Quote
Old 4th January 2008, 00:01   #1251 (permalink)
arpandiv's Avatar
umm all lamps have a reflector buddy.
Whats the shape of the lamp?
If you want you can try for a "plough lamp" they provide decent spread.
Old 4th January 2008, 11:16   #1252 (permalink)
arif_t01's Avatar
I think Kartik is refering to 'Fog Lamps' when he says 'Bumper Lamps'
__________________
Trying To Discover A New Identity!
arif_t01 is offline   Reply With Quote
Old 6th January 2008, 13:21   #1253 (permalink)
Default need help
hi this is soban
looking for zen bumper signal light with fog light combine
and smoked head & tail light
pls help
thank you
soban is offline   Reply With Quote
Old 9th January 2008, 03:55   #1254 (permalink)
aah78's Avatar
Default 6000k-6500k
Originally Posted by viper316 View Post
The next thing for the low beam i have a xenon 10000k hid light , in the low beam there is a cutter which cuts the light so that it acts as a low beam and the light is not speard all around , i wanted if we can remove that cutter which places the light as low beam.
Can't help you with the high beam. Don't know what you mean by cutter, but as far as your low beam is concerned - your 10000k HID produces a very dark violet coloured light - thats why you probably don't see a beam spread. You should be fine with 6000k to 6500k, which is what OEM's use.
check this:
Originally Posted by tsk1979
2000K would be yellow, around 4000-5000K would be white, 6000K is blue tinge white, 8000K would go towards violet.
aah78 is offline   Reply With Quote
Old 11th January 2008, 07:17   #1255 (permalink)
straight6's Avatar
Can I install an Hid Kit on my RX-135 if I upgraded the battery?
What modifications am I looking at if I have to go ahead with this?
straight6 is offline   Reply With Quote
Old 11th January 2008, 14:12   #1256 (permalink)
praJEEP's Avatar
Get an amby round headlamp dome(doom) from the scrap market its a direct fit on the RX, a 9amp battery woulb beenough to handle the HID, but i have adoubt where are you going to fix the ballast box in your rx ??
praJEEP is offline   Reply With Quote
Old 11th January 2008, 18:32   #1257 (permalink)
check this:
Yeak 6000k is the ideal colour temp. I think OEM's usually run 4300-6000k if im not mistaken.
Also a guy who worked in a company manufacturer HID kits told me that identical ratings(say 6000k) from 2 differement manufacturers would be a slightly different colour. But in general its like the charts show.
__________________
No fate but what we make!
Old 12th January 2008, 16:09   #1258 (permalink)
straight6's Avatar
I have already found the headlight of a Hero Honda CD Dawn, it holds an H4. My only concerns are will the battery get charged when the HID is running? Will I have to upgrade the rectifier? Will A relay help?
Old 12th January 2008, 16:58   #1259 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
hids only use 35w so it shouldnt be a problem.
akshay1234 is online now   Reply With Quote
Old 12th January 2008, 18:16   #1260 (permalink)
praJEEP's Avatar
No problems then go ahead. but i am again asking where are you going to fix the ballast kit. battery will get charged when hid is on, but make sure you upgrade the battery before.
EDIT: upgrade the rectifier also..
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
