Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 12th January 2007, 10:34   #121 (permalink)
desigNation's Avatar
hi there,i would suggest,100/90 philips, 130/100 would be a wrong choice,chances of headlight reflector gettin faded , because of too much of heat are higher.
desigNation is offline   Reply With Quote
Old 12th January 2007, 10:43   #122 (permalink)
Team-BHP Moderator
tsk1979's Avatar
The problem of being blinded has more to do with headlight alignment and beam and little to do with power.
A 60/55W headlamp can blind others if you are on high beam and your headlight positioning is set to high.
Most HID cars have HIDs for low beam and provide light more towards the ground.
__________________
Old 12th January 2007, 11:36   #123 (permalink)
HAFI's Avatar
yeah 100 watts philips vison will do good..it looks realy bright and u get it for both white and blue colour....
HAFI is offline   Reply With Quote
Old 12th January 2007, 12:19   #124 (permalink)
a4_attitude's Avatar
spend some mullah and get uself HID bllast....
__________________
To live is not just to survive, but to thrive with Passion, Compassion, some Humor & your own Style !
a4_attitude is offline   Reply With Quote
Old 12th January 2007, 12:26   #125 (permalink)
jkdas's Avatar
go for vision plus or rally as they would serve better during foggy climate.
get 100/90W with new relays to cope with the additional current they will need.
@ a4; and HID will cost? 10 k up right?
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 12th January 2007, 13:24   #126 (permalink)
willy's Avatar
I see no problem like the headlight reflector getting faded with 130/100. Guys, can you please let me know if any one has faced the problem.
willy is offline   Reply With Quote
Old 12th January 2007, 13:28   #127 (permalink)
speedzak's Avatar
It's evident from many posts made in the Auto Lighting thread that 100/90 bulbs are a best buy and suits our driving conditions here.
Unless you want to go for more expensive options like HID, Projectors etc.. the info you required is pretty much available in the above mentioned thread. Use the search function. It works wonders.
__________________
If you want to see a rainbow you must first sit through the rain.
(Hungarian Proverb)
speedzak is online now   Reply With Quote
Old 16th January 2007, 21:09   #128 (permalink)
condor's Avatar
Has anyone tried the 75/70 H4's that Bosch has?
Bosch - Lighting
I want to upgrade my lights, but dont yet feel like going for the 100/90's. Hence exploring the 75/70's. My stock lights are the 60/55. Will I need fresh relays even for 75/70?
__________________
Life is Analog. Digital is an approximation.
Old 16th January 2007, 21:46   #129 (permalink)
condor,
Why dont you get Philips 90/100 ?
Mugen_Power is offline   Reply With Quote
Old 16th January 2007, 22:49   #130 (permalink)
rahul_intlad's Avatar
@Condor, me too have the same question as mugen.Also have you considered the philips clearvision bulbs if you do not want high wattage.
Ps: Heard Osram are good if not better than philips[could somebody add to this please..],maybe you could have a look at that too.
rahul_intlad is offline   Reply With Quote
Old 16th January 2007, 23:09   #131 (permalink)
iraghava's Avatar
Ran 2 sets of Osram's & they were great but are very hard to find. Philips is not as good IMHO since I'm currently using a set of Crystalvision's.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 17th January 2007, 08:03   #132 (permalink)
condor's Avatar
I have used Philips crystal-visions, and they are a better option than the stock bulbs, when one wants to stick to the regular 60/55W [without an upgrade]. Also, my stock bulbs have lasted much longer than the higher priced Crystal-visions.
I have no doubts about the 100/90 setup. I am trying to see if I can manage without going upto 100/90. I think warranty gets void with 100/90's, when the stock is 60/55W. A couple of other reasons:
1. Cops: they suddenly get into a high-beam check mode, and at that time, they dont listen, forget understanding any explainations.
2. There have been instances when the on-coming guy has his high-beams on, and is blinding me. I have switched to high-beam, and the guy goes crazy. I would like not to get into an avoidable situation if I can. Considering today's driving environment, it does help to be a bit cautious too. People wont be able to make out if I have better lights or if I am using my high-beams.
__________________
Old 17th January 2007, 09:19   #133 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Bosch - Lighting
No need of relay's for these. Don't know about beam intensity though.
__________________
Old 18th January 2007, 06:25   #134 (permalink)
condor's Avatar
Any brand of relay /cut-out that I need to avoid?
the 75/70's are rated about 25% higher than the 60/55's. Would the stock relays be able to handle the 75/70's without any thing getting damaged?
tsk, what's rating on the Indica ? Will look for the Narva's, else will take the Bosch. I want to get better lights on the Marina and the Sumo, and it would be really good if I can just put the 75/70's without any addnl changes.
__________________
Old 18th January 2007, 09:17   #135 (permalink)
Team-BHP Moderator
tsk1979's Avatar
If you really want a relay get a roots one. But for 75/70W you don't need one as this much tolerance is already built into the system.
But with the relay you can upgrade to 100/90W later if required.
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 24 25th July 2008 21:20
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 12:42
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
