Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 9th February 2008, 11:16   #1381 (permalink)
BUSA's Avatar
I just enquired with Osram India, Silverstar is not available in 100/90 There is a new bulb which is superior to the Siverstar called Night Hawk(IIRC) which is also available in 60/55 only. I am using Hella currently, which 100/90 bulbs can i go for, which are more powerful then the currect 100/90 Hella's. Is Vision Plus available in 100/90?
How good is Halonix +60, is it available in 100/90?
__________________
Got Bhp? Team-Bhp.com
Old 9th February 2008, 11:18   #1382 (permalink)
Default What do you guys think of this?
Untitled Document
niksie2000 is offline   Reply With Quote
Old 9th February 2008, 11:50   #1383 (permalink)
PRADEEP KUMAR's Avatar
Halonix +60 is 100/90.
It has better throw than PHilips 100/90( i used before this).Light intensity is almost of that of philips.
__________________
I voted.
PRADEEP KUMAR is offline   Reply With Quote
Old 10th February 2008, 12:35   #1384 (permalink)
BUSA's Avatar
Thanks, how do they compare to Osram Normal?
Has anyone used 100watts in Swift fogs, can it be used.
Swift fog is made of plastic or glass?
__________________
Old 10th February 2008, 13:03   #1385 (permalink)
Its called Osram Nightbreaker. Supposed to be 90%+ better. But Philips Xtreme Power : 80%+ is better. Here is a linky on a comparison between both.
Honda-Tech.com: Lighting: Interesting Read: Osram Nightbreaker vs Phillips Xtreme Power and Light Output
Vision plus is stopped being sold in India. It was only available on stock wattage: 60/55.
hrman is offline   Reply With Quote
Old 10th February 2008, 13:50   #1386 (permalink)
Has anyone used 100watts in Swift fogs, can it be used. Swift fog is made of plastic or glass?
Plastic I reckon.
IIRC someone was running Narva's in the fogs.
__________________
No fate but what we make!
Old 11th February 2008, 00:56   #1387 (permalink)
BUSA's Avatar
Originally Posted by s0uljah View Post
Plastic I reckon.
What wattage Narva's? Should i use 100 watts in the fogs? Is it safe, i mean it wont heat or damage the fogs? Or i can skimp on this if you gift your HIDS Souljah
__________________
Old 11th February 2008, 01:39   #1388 (permalink)
BUSA's Avatar
And yeah another question. What is the stock fog wattage? Can i use nightbreaker same 60/55w? It costs 1600 bucks, i dont know why people order for Exterme Power through the net?
__________________
Old 11th February 2008, 10:38   #1389 (permalink)
ashthedivx's Avatar
Busa,
As you seems very keen of installing 90/100 tubes, i would suggest you skip the 90/100 league and look out for a better 55/60 wattage bulb which i presume is the default wattage of the fogs/headlights which you are looking at for replacement.
As a matter of fact the relay are not going to add any wattage in your basic wiring but will only protect you wiring from the danger of getting heated up. However, for using any 90/100 you will have to get your relay and holders altered so as they not get melted by the heat produced by the tubes which further leads in cutting and modification of OEM wiring. Apart from getting melted there is another sure-shot danger of getting you reflectors faded on a span of time after using the 90/100. I may be sounding anti-90/100 at this moment, but yes this is the plain truth installing behind 90/100 league tubes.
You may bet on 55/60 +50%/+80% range from philips and osram. Otherwise, if you are serious about lighting try Xenon/HID. They are costlier but worthier.
Old 11th February 2008, 11:32   #1390 (permalink)
floor_it_baby's Avatar
Stock fog wattage is normally 60/55w. I think the Swift uses H11s in the fogs same as my honda city. I tried 80w replacements and within a week the socket had melted. Normally the LH socket will be the first to melt because of the longer wire length. Once the socket melted, the bulb kept popping out and I realised that it won't be too long before the bulb blows. So I got new wiring installed and went back to the 55w OEM bulbs. So much for experimentation!
Now I am looking for the Osram Nightbreakers. H11s are very difficult to find though. Do you know any place where these are available?
__________________
0-100 in 5.0 ...!!
'02 Ikon 1.6
'06 Alto
'06 City
floor_it_baby is offline   Reply With Quote
Old 11th February 2008, 12:19   #1391 (permalink)
adityamunshi's Avatar
I have an Indica (DLS 2004). Is it possible to change the head lamp bulbs myself ? How do i do it?
And one of headlights has collected a lot of dust inside it, can it be cleaned ?
Aditya
__________________
Sometimes, to do it right, you have to do it yourself
adityamunshi is offline   Reply With Quote
Old 11th February 2008, 12:29   #1392 (permalink)
tsk1979's Avatar
The left bulb of indica is easily accessible.
You can remove it yourself after removing the holder and the restraining pin.
Watch someone do it(mechanic etc.,)
As for the right one, only if you have small hands. Otherwise the grill nut and the headlight assembly has to be removed.
As for leaning, you need to remove headlight assembly and then use a cloth or car vac to remove the dust.
__________________
Reclaimed, wrung dry and recycled....!
Old 11th February 2008, 21:14   #1393 (permalink)
drchernish's Avatar
hi everyone.still thinking wether or not to take the xenon plunge.want better light for main headlights for verna crdi(needed bcos of the power available) or go in for philips crystal vision 55-60w.no wattage increase -dont want to spoil the reflectors.
drchernish is offline   Reply With Quote
Old 11th February 2008, 21:45   #1394 (permalink)
BUSA's Avatar
Floor it baby - Did you use relay?
ashthedivx - Thanks for the info buddy. Have been using 100/90 but wanted to know which is the best in 100/90. HIDs are good but need projectors, otherwise ill be blinding on coming traffic.
__________________
Old 12th February 2008, 01:16   #1395 (permalink)
abhibh's Avatar
[Bulbs] OSRAM Nightbreaker - Civinfo
__________________
Tyres will screech & Engines will roar - WOM
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 13:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
