Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 26th February 2008, 17:18   #1456 (permalink)
from what I read online, white lights indeed are yellow lights but with a blue tint. so I don't think the blubs are defective.
he said he will install the cut-outs in a day or two but he hasn't told anything about the relay. I will visit him now and get the Blue Visions and cut-outs.
I don't want to risk with high wattage bulbs and risk my warranty by installing a relay.
what's your opinion about the Blue Visions?
sunilvarma is offline   Reply With Quote
Old 27th February 2008, 17:05   #1457 (permalink)
pshyamsundar's Avatar
Hi.
Excellent info on the Osram bulbs. However, are the the 55W H11 bulbs yellow or white? If white, what colour temperature? Are they a direct replacement for the H8 bulbs on the Swift or are modifications required?
Epic
The fog lamps 55W H11 bulbs are yellow light only. Yes they are direct replacement. No modificaitons required.
The white lamps are for head lights.
pshyamsundar is offline   Reply With Quote
Old 27th February 2008, 18:40   #1458 (permalink)
akshay1234's Avatar
as long as its done properly you wont have any warranty issues. not all bulbs have the blue coating. but since your lights are giving out yellow light the blue coating must have worn off. now either your bulbs are defective or your dealer has given you old bulbs. thats why i said to get them replaced. get the relay and cut outs installed then see the difference it makes on the narvas. 55/60w blue visions will be just for show. they wont give out much light.
akshay1234 is online now   Reply With Quote
Old 27th February 2008, 20:19   #1459 (permalink)
Originally Posted by rajesh1868 View Post
im having a wagonr duo and have travelled 1200 kms in total of which only <300 km with lights. tonight, the light wasnt switching on, and high beam indicator was on in the display. is the life of bulb this short? or can it be any other reason? why the high beam indicator was shown?
The best way of checking is by installing the Spare headlamps and testing if it works. If yes, means the earlier bulb have conked off. Normal life of bulbs is not so short. Its about 1000 hrs.
hrman is offline   Reply With Quote
Old 27th February 2008, 23:15   #1460 (permalink)
is the cut-out installed to tolerate the extra heat generated by the lights or do they have other purpose?
and is it really necessary to install a relay? what are the cons of not having a relay installed?
Old 28th February 2008, 08:47   #1461 (permalink)
akshay1234's Avatar
the relay makes sure your bulb gets the adequate wattage since stock wires are meant for 55/60w.
Old 28th February 2008, 09:01   #1462 (permalink)
tsk1979's Avatar
This is not correct. According to policy of most companies, they can void your warranty(if they so desire) if you get the electrical system tampered with. The best policy is to pay a little more and find out an "Authorized dealer" who does this. For example, concord motors blr used to do this.
A relay and wiring is installed to bypass the stock electrical system. The stock wiring and circut's are designed to handle 60 watts, which comes close to 10A total current for both bulbs.
When you install 100W bulbs your current requirement is about 16A.
Thats a 60% increase in the current, and it means you are pushing the stock electrical system to the limit.
Therefore you install a relay with wiring so that the current is taken off the stock system to this bypass system which is designed for this load.
To know about what is a relay, read this
Relay - Wikipedia, the free encyclopedia
__________________
Reclaimed, wrung dry and recycled....!
Old 28th February 2008, 13:21   #1463 (permalink)
Default Need a reliable source for changing the headlights
Hey friends,
I need a reliable source near f'bad / south delhi to change the headlights on NHC VTEC.
We got the car last year and I immediately upgraded the headlights to Philips Rallye 100/90 with relay. It was ok but the bulb fused within 5 months. Next I changed to Philips BlueVision 100/90. Again they lasted just a couple of months. Fed up with halogens, I tried the HID kit. BIG MISTAKE. Never try HIDs in reflectors. Although the intensity is very good but focus is horrible. Its good for low beam but in high beam I feel the depth of vision is better in halogens. Otherwise there is no problem with the HIDs.
So now I want to change back to halogens. I want 100/90 wattage bulbs.
1. Please suggest what are good options in this wattage. I personally like Blue Visions but an open to try something different.
2. I don't want yellow or blue lights. White light is just perfect to my eyes.
3. Most importantly - let me know a reliable source to get a relay and the bulbs (with approx costs) so that it doesn't blow off too soon.
Thanks a lot
Naman
naman is offline   Reply With Quote
Old 28th February 2008, 13:26   #1464 (permalink)
whats the purpose of a cut-out? do i have to get a cut-out if i use blue visions?
Old 28th February 2008, 13:41   #1465 (permalink)
akshay1234's Avatar
if you use 55/60w bulbs you dont need cut outs or relays. just fit them in. what i dont understand is how your using 100/90w bulbs without either?
Old 28th February 2008, 18:27   #1466 (permalink)
what my friend (he is the dealer) said is that he will install cut-outs in a week. he said its not a problem to run without cut-out for a short while but it will cause problems after few weeks.
Old 29th February 2008, 13:21   #1467 (permalink)
Default white fog lights!
Hello guys..
Is it possible to replace stock fog lights with a white one! If yes, which one!
I have decided for the blue vision, but i dont want yellow fog lights with it!!
Also, is it possible to repace indicator bulbs aswell ..to white!!
Thanks for your suggestions!
btw.. the car is fusion
Gaurav
Moderator's note: Please use the search function before posting new threads. Merged.
gauravchawla is offline   Reply With Quote
Old 29th February 2008, 13:59   #1468 (permalink)
Any bulb can be replaced on the car a slong as you get the correct specification and wiring.
Check the specification of the stock fog lamp (h7, h8 etc) and then buy a 55 or 50watt crystal vision/blue vision.
You would be lost in the rain/fog though :(
__________________
No fate but what we make!
s0uljah is online now   Reply With Quote
Old 29th February 2008, 23:02   #1469 (permalink)
TARUL's Avatar
Hey gaurav I would strongly suggest not to go in for white fog lights as the intensity of light given out by these bulbs are very poor.The best alternatives for white lights are xenon's which are expensive but worth the price.
__________________
If some horse power is good,then more is better and too much is just about right.
TARUL is offline   Reply With Quote
Old 29th February 2008, 23:12   #1470 (permalink)
My swift has white fog lamps? what colour should they be?
I wouldn't have thought that intensity is the biggest deal for fog lamps, as they illuminate the road fairly close in front you, helping you to follow it and avoid obstacles.
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 13:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
