Old 6th November 2006, 20:16   #1
vezj420's Avatar
Thanked: 17 Times
Lightbulb
Sorry if this is redundant...I really have some itching questions concerning perf. upgrades in BLR!
For those that don't know already, I've got an Ikon 1.6 Nxt with K&N air intake+cone filter, Denso Iridiums, stock engine, and N1 spec mufflers. I'm looking for my next big push in performance upgrades, and have the following ideas and questions:
Kit 1
For even better airflow, I've heard good things about the Pipercross Viper induction kit (this is a CAI with chrome-top cone filter and cold air feed). Cost ~ Rs. 9-10k
For enriching/tweaking the AFM, I was thinking of installing an FSE Power Boost Valve (fuel pressure regulator). Cost ~ Rs. 10-11k
(btw, if anyone knows where I can get these for cheaper, lemme know please!
Now, I'm thinking, INSTEAD of spending the 20k-ish on the above two items, why not go for:
Kit 2
A piggyback module that can adjust AFR and ignition timings (ie. Race Dynamics RD0406, Next Level Tri-phase, etc.). Why I think of this as an alternative is that it can be mapped to accomplish pretty much the same thing the above (Kit 1) does. Is my reasoning/line of thinking correct? Or am I being a naive newbie?? Please impart your wisdom, fellow Team-BHPians!
Now, I am of course aware that BOTH kits together would make a helluva difference, but my budget and cautious nature only allow for one kit at a time...maybe with a couple of months in between for break-in time. Plus, I'm thinking of saving up for a wet N20 kit! (keep this in mind for your advice)
Okay, that part's done....on to the next section: (esp. for the Bangaloreans, this one!)
Which place in BLR can do or provide the following for the Ikon 1.6?
1) Front strut brace
2) Flywheel lightening and balancing
3) Short-throw gear lever
(I may be asking too much of BLR....Hey, she's my hometown too, man! Prove me wrong, people!)
vezj420 is offline   Reply With Quote
Old 6th November 2006, 23:42   #2
Thanked: 11 Times
vezj420,
First of all you should have to look at Team-Bhp rules, Smilies usage is restricted to Two per post.
Why dont you try search option in advanced mode ?
Few Links..
http://www.team-bhp.com/forum/modifi...ded-ikons.html (Modded Ikons!!!)
http://www.team-bhp.com/forum/modifi...us-cities.html (Car Accessories Shops In Various Cities)
Or PM psycho for performance upgrades.
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 7th November 2006, 00:35   #3
nitrous's Avatar
Thanked: 285 Times
Dude,of the above two kids,i'd suggest the tri-phase.
Anyways, front strut brace is a good idea.
But, y do u want to lighten ur flywheel?
Old 7th November 2006, 02:22   #4
v1p3r's Avatar
Thanked: 27 Times
The best is in BLR.
You could get a good flow job done to your head. That would bump up power some. Increase compression too. That's another nice way to go. Or get a custom cam. Speak to Ford Rocam, he once did it for his Ikon, so I bet he can help you out.
Old 7th November 2006, 12:09   #5
Thanked: 17 Times
Man! Nice intentions you have. It seems, you just want full performance and no show. That's good man.
Whatever you wanna do, consult Psycho also. He's our very own tuner in Teambhp.
I'm a bit curious of your car though. Ikon's have a tailhappy syndrome and it's brakes are not much reliable. First, I thought it was my experience alone. But later heard of the same from others too.
Old 7th November 2006, 15:21   #6
vezj420's Avatar
Thanked: 17 Times
Thumbs up Where, where?!
Originally Posted by v1p3r
The best is in BLR.
Hey V1p3r, thanks for the info. I looked on the "mod shops in various cities" thread but couldn't find where in BLR I can get cylinder head work done....any idea where? That would avoid me having to order one from Electra Performance (Chennai).
A camshaft is still an open option, but which shop can tune it properly?
Old 7th November 2006, 15:34   #7
vezj420's Avatar
Thanked: 17 Times
Exclamation
SpeedZak, you're totally right about the Ikon's brakes....they do suck! (although they're better than some cars in India). Actually, I was thinking of upgrading my brake pads and lines right after adding a good performance boost....
Old 7th November 2006, 15:42   #8
vezj420's Avatar
Thanked: 17 Times
Question
Well, if Dave Baker's articles on PumaRacing.co.uk are anything to go by, flywheel lightening helps out a lot with power gain at the flywheel (due to decreased rotational inertia) and therefore directly at the crankshaft.
I'm sure you knew this already....were you asking why I wanted an Ikon flywheel lightened? Is there any reason not to, in your opinion?
Old 7th November 2006, 16:03   #9
Vid6639's Avatar
Thanked: 21,083 Times
doesnt lightening the flywheel reduce bottom end performance or was it tope end performance. I remember that it definitely reduces one of those.
Old 7th November 2006, 18:49   #10
rdkarthik's Avatar
Thanked: 11 Times
I would suggest you contact RAC. They do a lot of rally cars, and are very good at some of the thing you are looking for.
Looks like you need a mix of both your options. A less restrictive tuned induction kit will definetly help. You need to get tuned exhaust as well. Next, i would anyday recommend a piggyback or standalone ecu, as you have complete control over fuelling and timing, hence a greater performance potential and ability to adapt to any other mods on the engine.
You dont need to upgrade the fuel pressure regulator with an aftermarket ecu, as the injection quantity is tunable, execpt when you are exceeding safe duty cycle or when higher injection pressure is needed.
rdkarthik is offline   Reply With Quote
Old 7th November 2006, 21:48   #11
Ford Rocam's Avatar
Thanked: 16 Times
Ok I am not from banglore but would like to share my experience
Stock Flywheel of ikon's rocam engine weighs 8Kg the max you could reduce is by 1 - 1.25 Kg by machining, make sure you dont remove the teeth embedded on flywheel its small square pattern 36 nos used by Crankshaft position sensor to determine TDC/BDC.
Ford Rocam is offline   Reply With Quote
Old 9th November 2006, 17:53   #12
shazikon's Avatar
Thanked: 19 Times
I am no MOD GURU.. but here is my take: Having a heavier flywheel helps the car run better at low RMPs because of the inertia due to mass. Lightening the fly wheel no doubt helps top end performance but it would kill the lowend. I dont think you can do that if you drive in Bangalore traffic. I feel a lighter fly wheel is necessary when you have used up all the tricks and need that extra BHP.
Before i do the above , I would go for porting and polishing my internals, increasing compression raito ( uless you have plans to Turbo).. a stand alone engine management system cause i dont like the idea of a piggy back giving wrong information to the ECU by faking the sensor signals. Go for forged internals and then Turbo charge..
shazikon is offline   Reply With Quote
Old 26th November 2006, 17:27   #13
vezj420's Avatar
Thanked: 17 Times
Cool update on mod plans
Hehe, don't know if some of y'all are still reading this thread (if so, thanks!), but here's an update on my to-do list stretching well into 2007....
I finally met up with Sanjay of RAC and sought his advice concerning engine upgrades (I figure, why spend the wad-loads of cash on aftermarket bolt-ons when I have competent people to do the engine internals).
So, first thing I'm getting done in order to accomodate for the coming upgrades is free-flow headers (already got the exhaust). The next thing I wanted to do was head porting, polishing, and milling (to increase CR), but on Sanjay's advice I will be upgrading my throttle body first (ie. boring it most likely). It seems that Ford's cylinder heads are already pretty efficient, with a lot of the intake and exhaust plumbing having been detuned for Indian Fords. Therefore, the scope for most improvement lies in the plumbing.
After those two things are done, I'll probably go in for the porting and polishing, albeit cautiously because in the long, long run (in 2007), I am seriously thinking of taking the vehicle down to Mysore to Mr. Somender Singh's garage to see if he can work his magic on my Ikon 1.6! The work he does includes porting, polishing, and milling, so I don't know if it's recommended to get it done here first.... (those of u who don't know what the hell i'm talking about, refer to www.somender-singh.com or go to this thread: http://www.team-bhp.com/forum/techni...14-5-kmpl.html (My Grooved Esteem FE is 14.5 Kmpl)
Any opinions on the above, Kaizer Sozay (if u're reading)?!
Finally, that is, before Mysore, I'm thinking of going for Race Dynamics' ECU upgrade with a number of settings for 1) increased mileage 2) 'stock' performance 3) Stage 1 Fuel+ignition remaps for mild power increase 4) Stage 2 Fuel+ignition remaps for *****-out power increase!
Karthik, your opinion on this view, please!
Peace all, and thanks for all your inputs....you've managed to change me from the mindset of a "bolt-on wonderboy" to at least a half-educated modder/tuner who's not afraid of exploring options!
Old 28th November 2006, 10:21   #14
rdkarthik's Avatar
Thanked: 11 Times
@vezj - Sounds nice !! Option(1) is'nt exciting though .
Old 28th November 2006, 22:15   #15
vezj420's Avatar
Thanked: 17 Times
@Karthik, hehe I know Option 1 isn't exciting...I need it for increased mileage! I've told u this already....I gotta commute ~28kms to and fro work 5 days a week!!
anyways, thanks for the reply bro...always good to hear from you....can you PM me with feasibility and pricing for the 4 settings I've mentioned?
FYI, I'm thinking either Jan. or Feb. for putting your EMS in....when ru shifting shop?
@Viper - my ears perked up when u said cheaper and better alternatives to Konis....where and what, man?! (no sarcasm, I'm asking earnestly)
Seeking Help - Calling Travel Gurus - Thailand/Malaysia/Singapore idea1979 Route / Travel Queries 22 7th February 2017 12:12
Sensor based traffic signals (based on induction-loops) in India? vharihar Street Experiences 8 13th February 2014 21:46
Calling all PhotoShop Experts: Help me mod my Santro rareone Modifications & Accessories 3 15th April 2010 11:33
Calling all DXB/AD or UAE based BHPians - The Barbican Turbo Fest! Steeroid The Team-BHP Meet Section 34 18th November 2008 09:08
Calling All You Guys normally_crazy Shifting gears 3 19th April 2004 13:37
