| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #18 (permalink) | ||
| Team-BHP Support ![]() | Quote:
__________________ Racing Throttle Response | ||
| | #19 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| tabrez remove the meter console and you will surely see a bunch of wires going in, try finding the wires that feed signal for tacho, make a small cut and take parallel connection to add on tacho.. should work according to me lil patience is req to figure out which is the right wire and some care not to break it and tape it proper to avoid breakage and shorts
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #20 (permalink) |
| Senior - BHPian | Man! It's cool to have an aftermarket tacho fitted. So, forget what others have to say and just fit it in! As Psycho said, it can be installed using the signal wires from the existing tacho. You want a tacho with shiftlight? Ask Psycho. He has a very nice looking one. He'll sell it if you can con him with a beautifully cooked Rajma!! (dont tell him I told you this) ![]()
__________________ Music heaven a touch away! SK456's Santro. |
| | #22 (permalink) | |
| BHPian Join Date: Nov 2004 Location: Bangalore
| Quote:
do i need to take a wire out from this ? do you think will it work ? Please suggest.
__________________ Regards Tabrez | |
| | #23 (permalink) |
| hey i think you solved the mistery.. most probably u will have to take the soldering route, check if you get signal there then take it further by soldering
| | #24 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Learning is a continuos job that keeps me busy. | |
| | #26 (permalink) | |
| Newbie Join Date: Sep 2006 Location: chennai
| Quote:
i got the autogauge w/shift light and 7 led series and have the same problem of half rpm reading. any hunches ? | |
| | #27 (permalink) |
| BHPian | the best option would be fitting a tach light. if at all you are in serious drag action. another option which we tried was calling for a tach cable which is avail. only at popular garage which is a direct fit to your ecm. as per the instructions given
__________________ [FONT=Arial]If you're not breaking parts, you're not going fast enough!"[/FONT] |
« Does it make financial sense to use a CAR AUDIO in the house ??
Modded Santro's day out on the Highway! (Universal K&N Effect) »
| Thread Tools | |
Similar Threads | ||||
| Strange Idle RPM on Swift | m4ugr8 | Technical Stuff | 3 | 7th July 2008 22:31 |
| INNOVA VVTi RPM meter & upgrade | rash28 | Modifications & Accessories | 5 | 13th May 2008 12:43 |
| RPM Meter for WagonR Lxi | ravi@64bhp | Modifications & Accessories | 11 | 25th June 2007 15:58 |
| Digital Trip Meter in SWIFT | passioncool74 | Technical Stuff | 2 | 10th November 2006 11:12 |
| Wanted RPM Meter ! | khaadu75 | Shifting gears | 7 | 15th August 2004 11:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462
