Old 8th November 2006, 08:55   #1
tabrez02's Avatar
Angry HELP-How to connect RPM meter in SWIFT
Hi Guys,
This is for the technical expertise,
i recently bought a smoke series 3inch RPM of R-tech or so, after fitting found out that SWIFT has a dual coil and the RPM cannot be fitted. is it so? is there any possibility that i can fit it ? has anybody done it ? Please help...
tabrez02 is offline   Reply With Quote
Old 8th November 2006, 08:58   #2
viper's Avatar
Thanked: 9 Times
It can be fitted contact a good electrician or Psycho he shall help you out.
Viper
viper is offline   Reply With Quote
Old 8th November 2006, 09:22   #3
Samurai's Avatar
Thanked: 15,760 Times
I'm surprised. Doesn't Swift come with a tacho? or is this some fancy upgrade...
Old 8th November 2006, 09:29   #4
tabrez02's Avatar
Its a fancy upgrade, any inputs samurai.
Old 8th November 2006, 09:30   #5
Vid6639's Avatar
Thanked: 21,042 Times
yup Samurai, i believe all models do come with a tacho. I was just thinking the same thing.
Old 8th November 2006, 09:32   #6
gd1418's Avatar
Thanked: 656 Times
Your fancy tacho and the company installed would work in tandem or are you going to remove the OE? Leaving apart the fact that gizmoing has no logic (I also do.. ), what is the need for this upgrade, if I may ask?
Old 8th November 2006, 09:37   #7
tabrez02's Avatar
Actualy i was fitting the meters on the right beam (dont know what they call it) i have included a, AIR/Fuel, Volt meter and there was an empty hole for one more meter to fit, as that guy didnt had Oil Temp meter and has a tacho instead, it went as a fancy. this is the story behind having another tacho and as it is a smoke series and looks cool. I am requesting help for the same.
Old 8th November 2006, 09:58   #8
aZa
aZa's Avatar
Thanked: 17 Times
Tabrez : i think you have the Smoked out meters which come in a set of three? and are attached on to the A pillar right? i have one on my santro too and i have the same problem dual coil so the rpm meter shows only half the rpm. I'm gonna get it fixed through manik(driven) in a day or two will keep u updated.
Old 8th November 2006, 10:06   #9
prabuddhadg's Avatar
Thanked: 46 Times
And then if the two tacho's show different readings, you can worry some more and post some more queries.
prabuddhadg is offline   Reply With Quote
Old 8th November 2006, 10:11   #10
tabrez02's Avatar
aZa, thanks.
I realy astonished to see there is not a single thread concerning this issue. Hope this will be solved but i am sure its not that difficult.
Old 8th November 2006, 10:33   #11
Jaggu's Avatar
Thanked: 8,674 Times
dumb idea: but will taking the input readings from the existing tacho wiring help???
Old 8th November 2006, 10:49   #12
tabrez02's Avatar
Tried even from the existing tacho, not able to find any wire for that.
Old 8th November 2006, 11:54   #13
thoufique's Avatar
I have the same problem on my corsa.. it has no rpm meter by default. the electrician isolated the rpm signal but it is showing only half the rpm.. any help ?
thoufique is offline   Reply With Quote
Old 8th November 2006, 12:17   #14
tabrez02's Avatar
Even spoke with the MAD guy for the solution, the guy promised to let me know the info in 3-4days.
Old 8th November 2006, 12:25   #15
Samurai's Avatar
Why don't you wait for the Oil temp guage instead of having two tachos?
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Lancer RPM meter malfunctioning rajivanoj Technical Stuff 2 22nd November 2009 19:37
INNOVA VVTi RPM meter & upgrade rash28 Modifications & Accessories 7 10th December 2008 03:03
RPM Meter for WagonR Lxi ravi@64bhp Modifications & Accessories 11 25th June 2007 15:58
Wanted RPM Meter ! khaadu75 Shifting gears 7 15th August 2004 11:30
