Old 13th November 2006, 15:30   #31
Driven's Avatar
hi,,,
swift projector's do exist,,
and they are available in delhi,,also!!!!
u can check the pics,,
regards,,
driven
Originally Posted by low_bass_makker
I would really pleased to know if something like this exists.....
Driven is offline   Reply With Quote
Old 13th November 2006, 17:58   #32
Thanked: 294 Times
oye bale bale for how much are they avalable for and where........
Old 14th November 2006, 00:05   #33
Thanked: 11 Times
Wow..
Thats a good who owns Swift.
@ Driven, BTW For how much ??
Mugen_Power is offline   Reply With Quote
Old 14th November 2006, 11:51   #34
tabrez02's Avatar
Question
Originally Posted by Driven
hi,,,
regards,,
driven
delhi ?? which place ??? whats the shop name and number ??
tabrez02 is offline   Reply With Quote
Old 15th November 2006, 01:36   #35
Originally Posted by neo_trace
i think twin light setupswith 2 diff. compartments (like old and new accord,civic ,skoda,corolla,merc,bmw ...etc headlights) actually really defines XEXON'S light perfect.
as there is only one beam no hi or low , installing one light with xenon and other with normal helogen will solve the problem so that a dipper function can be achived.
Isn't the placement switched for halogen and Xenon. You would like the xenon for low beams (usual postion is outer headlight) and use high beam as dipper.
Master530i is offline   Reply With Quote
Old 15th November 2006, 02:56   #36
autopsyche's Avatar
Thanked: 15 Times
Yes thats correct. the xenon and halogen positions are switched in the example pics, the low beam (outer) is normally xenon. But even in a twin setup case the xenon will always be in a projector and not in a reflexive beam.
autopsyche is offline   Reply With Quote
Old 23rd November 2006, 17:53   #37
islandman's Avatar
Exclamation A little confused
Ok. this may sound (should i say look) very naive. I have gone thru this link and i would request all experienced folks to please correct/verrify my understanding and answer my questions,
1. If only HID Kit is installed then there will be no high and low beam setting as in normal Bulbs.
If this is true, will the vision range not be limited because in normal or 100/110w bulbs, your vision range ( thats my term for distances upto which you can see) on high beams increases dramatically. I am sure everybody would agree with me that hight beam helps in spotting the odd buffalo coming onto the road
from a distance, will that feature go out of the window when HID's are installed?
2. I have a Baleno, I am planning to install a P4 HID Kit for about 15-16k. What is the best way I should I get it installed? Projection type,reflexive type or what??? Remember I am putting in such a high expense only to be able to
1. See more of the road and see it more clearly at nights.
2. i do not intend to blind oncoming motorists at all costs.
3. the car to look at little cooler ( only if 1 and 2 are satisfied).
islandman is offline   Reply With Quote
Old 23rd November 2006, 21:50   #38
manveet's Avatar
Thanked: 586 Times
Well, This is incorrect.
I am not entirely sure of the reason, but from what I understand - H4 bulbs have the ability to move forward and backward which causes high & low Beam.
The single bulb concept (e.g. the Type1 OHC) was common earlier but it's usage is progressively dercreasing.
Well, as has been much debated and finally concluded - the ideal way would be to use a Projector setup. But it's usage is a function of the following 2 key factors -
1. whether a projector setup is available at all, for the Baleno
2. whether you want to incur the extra cost of getting rid of the existing reflexive setup.
manveet is offline   Reply With Quote
Old 6th December 2006, 16:33   #39
Abix's Avatar
Hey Driven, could you please pm the details as to where i can get the projector headlights for the swift! Wud be a huge help! Cheers!
Abix is offline   Reply With Quote
Old 7th December 2006, 01:23   #40
harsh87's Avatar
a h4 hi lo halogen bulb has a pair of filaments in it which gives us the hi and low beam function
a xenon with hi/lo function has either a solenoid actuated moving bulb or some new ones have two discharge chamber i.e the actual filament as you may call it and these new kits sometimes come with two ballasts for each bulb
aftermarket projector housings are also available which themselves move without moving the bulb to give hi and low beam
harsh87 is offline   Reply With Quote
Old 8th December 2006, 02:13   #41
speed0mania's Avatar
any info on d projectors??? have been hoping to lay my hands on a pair for quite a while now!!
speed0mania is offline   Reply With Quote
Old 21st December 2006, 02:02   #42
any info on d projectors?? driven!!? anyone??? pls let me know!!
Old 21st December 2006, 02:18   #43
iraghava's Avatar
Thanked: 156 Times
Driven is currently out of the country so wait till next week & he'll answer your queries then.
Old 3rd January 2007, 01:13   #44
I need these projectors for Optra, who and where in delhi is selling the projector lights .. they might have one for Optra also .. please let me know
gdhiraj is offline   Reply With Quote
Old 18th January 2007, 13:47   #45
Akshay1234's Avatar
Thanked: 7,242 Times
here are some projectors for the swift -
http://swift-power.com/Products%206.html
Xenons on my Lancer revtech Modifications & Accessories 48 14th December 2005 15:41
need xenons for zen mclaren1885 Modifications & Accessories 7 18th August 2005 22:01
Xenons for the Octavia anyone?? karthik247 Modifications & Accessories 24 14th March 2005 18:34
Bi-Xenons For C,E and S-Class S600BENZ Shifting gears 13 22nd January 2005 14:55
