Old 8th September 2004, 01:29   #31
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by [b
Quote[/b] (Rudra Sen @ Sep. 05 2004,15:35)]Is there any problem with new plastic reflectors when you put higher watt lamps? Those days it used to be glass with mirror coating. I've 100/130 Flosser lamp (hope the spelling is right) in my Ambyfor last 2 years.
hey rudra,
did u change ur bulb holder to accomodate the 130/100w bulb.
i have hard that the normal holder can melt when used for long periods with a 130w bulb.
satya
speedsatya is online now   Reply With Quote
Old 9th September 2004, 12:53   #32
Rudra Sen's Avatar
Thanked: 4,295 Times
Quote[/b] (speedsatya @ Sep. 07 2004,23:59)]did u change ur bulb holder to accomodate the 130/100w bulb.
No, I'm using the same what I had for 90/100.
No problem till date. Your connection should be correct in terms of cable quality etc. I've used FINOLEX.
Old 10th September 2004, 01:38   #33
speedsatya's Avatar
Thanked: 712 Times
i have a lucas relay which is supposed to be the best.
can any one tell whether the headlights consume 100w per bulb or is it the total consumtion of both bulbs.
as i already have extra fog lamps and two extra hella brake lights.so do not wanna put load on the alternator.
satya
Old 10th September 2004, 02:29   #34
Rehaan's Avatar
Thanked: 25,043 Times
Quote[/b] (speedsatya @ Sep. 10 2004,00:08)]can any one tell whether the headlights consume 100w per bulb or is it the total consumtion of both bulbs.
Hey Speedsatya,
Thats 100w per bulb (on high beam)
90w per bulb on low beam
and 90+100w per bulb when u flash
cya
R
Old 13th September 2004, 01:07   #35
speedsatya's Avatar
Thanked: 712 Times
that means 260W of power from the 2 bulbs.no way i am gonna put 130w bulbs.i am happy with my 100/90W.
anyways thanks guys.
satya
Old 27th September 2004, 14:35   #36
Quote[/b] (speedsatya @ Sep. 05 2004,00:27)]Of late we have been seeing advertisements of Philips Visionplus bulbs claiming to give 50% more light.since these are of 60/55W ,theoeretically they should give an o/p equivalent of 90/82.5 W.
Has anyone used these bulbs .
So this means that no modifications for wiring and relay would be required if these are used !
And howz the feedback for these, any users ?
Tarun
Tarun is offline   Reply With Quote
Old 30th September 2004, 15:23   #37
speedsatya's Avatar
Thanked: 712 Times
tarun,
if u use 60/55W vision plus ,u need not go for a relay.
satya
Old 1st October 2004, 15:03   #38
Smile
the xenon kit costs about 30,000 in mumbai. and the entire assembly with wiring harness/etc needs to be changed. you can get the best stuff with warranty at four Seasons - contact 24940444. if you haev the money they are well worth it. just be careful driving around else each replacement will be serious expensive
auto is offline   Reply With Quote
Old 30th October 2005, 02:30   #39
dadudeonfire's Avatar
im buying philips blue vision 4000w 65/something...just want to know which size i should buy for opel corsa and honda city
dadudeonfire is offline   Reply With Quote
Old 30th October 2005, 08:06   #40
virkdoc's Avatar
just go for normal philips 100/90 watts bulbs H4 for honda city, been using them since 2001, amazing light,and do get a relay
virkdoc is offline   Reply With Quote
Old 30th October 2005, 13:39   #41
whats a relay dude???
Old 30th October 2005, 13:52   #42
karthik247's Avatar
Thanked: 16 Times
Guys whats the difference btw Philips Crystal Vision and Philips Diamond Vision??
karthik247 is offline   Reply With Quote
Old 30th October 2005, 14:10   #43
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
the crystal visions give a white light effect whereas the diamond visions give a blue xenon like effect..
Old 30th October 2005, 14:28   #44
how do you guys find chrystal blue vision by philips???how much is it for in mumbai
Old 30th October 2005, 14:38   #45
lamborghini's Avatar
Thanked: 1,667 Times
Thinking about crystal Diamond vision for the Palio,
Anyone know whether it will fit? And how much will it cost with the relay.
The Palio comes with 2 pin bulbs.
lamborghini is offline   Reply With Quote
Stickers for bright red Swift vxi dodgeviper Modifications & Accessories 19 21st May 2010 22:41
DIY:Santro Dome Light with Bright White L.E.D. ghpk DIY - Do it yourself 13 4th June 2009 00:20
Quality Super Bright LEDs, where can I find them ? s0uljah Modifications & Accessories 20 20th February 2009 17:20
For Sale : Zen Vxi 2005 (Bright Red) Freaky_Sid!! Shifting gears 1 14th December 2007 09:05
Accessories for Bright Silver Getz mangywarez Modifications & Accessories 7 26th July 2005 11:32
