Old 16th December 2008, 12:56   #151
Thanked: 388 Times
Dear Vikram,
I need quartz black of Tata Safari it is not available on Com-paint ( Only carbon black is available) can you provide this feedback to the company to make this new shade available.
Black is the highest selling color in Safari and a magnet for scratches so it should make good business sense as well.
Amit
amitk26 is offline   Reply With Quote
Old 16th December 2008, 17:55   #152
mukeshgoel's Avatar
Thanked: 378 Times
Dear Vikram,
I have already ordered for the products including clear laquer for my T.White Civic. By the way, is there any place where I can get it done instead of doing it myself. I am in Rohini and Com-paint head is not far from my place.
Thanks.
mukeshgoel is online now   Reply With Quote
Old 16th December 2008, 19:20   #153
greenhorn's Avatar
Thanked: 1,422 Times
vikram, might I suggest another product ?
http://www.team-bhp.com/forum/modifi...blackened.html (How are headlights and taillights blackened?)
the advice given there was that a 5:1 mix of clear coat and black paint can be used to blacken tail lamps as shown in the thread. I dont think there is any stuff available locally for that ( available internationally though ) .
If there is enough demand from the people here , you might want to think of making some of that too
greenhorn is online now   Reply With Quote
Old 27th December 2008, 16:56   #154
greenhorn's Avatar
tried the finishing touch on the patched area. used 3M finesse it instead of top cut. lost a little bit of paint in some areas, but after polishing and waxing, the gloss is acceptable, except in some areas where i screwed up myself
Old 21st January 2009, 14:03   #155
Thanked: 245 Times
Originally Posted by y2vikram View Post
1. Since the scratches are still visible, you could have used a coarser emery paper of 400 no. which would have further smoothened the deep scratches.
Or, should have applied NC putty to fill the deep ones.
Or use regular M-Seal (its an epoxy putty), use it for scratches and not on flat surfaces, as it will peel off from flats with time. Mould to shape with water and hand just like your mud clay. let it dry for an hour. Use 400-600 sandpaper and then finer ones 1500-2000 before paintjob.
Dear Vikram,
Amit
He needs a colour sample size of your tow-hook bumper cover to develop the shade, you can send it to him (on returnable basis, i guess).
Originally Posted by mukeshgoel View Post
Dear Vikram,
Thanks.
Good sample video and example if someone at com-paint can do it.
Old 21st January 2009, 20:57   #156
zerocritical's Avatar
Was looking for one of these touchup sprays for long time now.. have ordered for my white swift along with a black paint can and clear laquer.. will try the black paint for "SMOKING" my tail lamp..lets see..
zerocritical is offline   Reply With Quote
Old 22nd January 2009, 11:01   #157
Hey guys.. was thinking of painting my side handles and Side rear view mirrors with this com paint.. what say? any suggestions?
Old 22nd January 2009, 11:17   #158
Fountainheader's Avatar
Smoking of tail lamps is an irreversible process right ? And is it completely DIY ?
Fountainheader is offline   Reply With Quote
Old 22nd January 2009, 11:24   #159
Yes it is irreversible.. will have to buy a new pair of tail lamps if it goes wrong. Other team BHPians have tried it and looks like its a DIY job.
Old 22nd January 2009, 11:25   #160
But they have tried it with a ratio of 1:5 paint:thinner. Dont know how this thing will look.
Old 22nd January 2009, 11:27   #161
Guess you can get it painted matte black. On a white Swift, it'd look KILLER!
Old 22nd January 2009, 11:29   #162
Thanked: 30 Times
I think it is possible but make sure you keep the already painted surfaced masked otherwise your existing paint will go bad. First try on mirrors and see the effect and your skill level then try on handles as i am not sure if paint remain there after you use them. I think you need to rub them with 1500 sand paper so that paint remain there.
aka_iitd is offline   Reply With Quote
Old 22nd January 2009, 12:26   #163
surely will try as soon i get the order. Thanks for the suggestion.
Old 22nd January 2009, 12:32   #164
greenhorn's Avatar
zerocritical, i think you need to mix the clearcoat and paint BEFORE application.
Old 22nd January 2009, 12:54   #165
Thanked: 245 Times
Follow these instructions.
Clearcoat in not thinner, although it might lighten the paint colour. Buy thinner from a Auto repair shop.
Another example of touchup job with red swift
Touch Up Guys : A Pictorial Experience of Paint Repair in Australia SS-Traveller Technical Stuff 26 25th July 2016 18:46
Touch Up spray/paint amit Technical Stuff 12 10th July 2011 11:06
paint over paint DRC Technical Stuff 33 25th August 2006 12:05
What a paint job..S2000 with Clear Paint.. _Crazi4Speed_ The International Automotive Scene 6 20th September 2004 23:44
Don't tubes have speed ratings??? Shan2nu Tyre & Alloy wheel Section 18 9th July 2004 23:18
