Old 11th February 2010, 17:28   #211
greenhorn's Avatar
Thanked: 1,450 Times
i use 3M finesse IT rubbing compound. Should be available at most auto paint shops
Old 11th February 2010, 17:51   #212
sohail99's Avatar
Thanked: 163 Times
@mailmaldi - You can easily remove/lessen(depending upon the depth of the scratch) the scratches from the panel!
but the dent proper cannot be removed(unless you opt for a dent repair and paintjob on the affected panel)
Try using rubbing compounds like 3M Finesse it(as greenhorn mentioned)
but its quite powerful compound and leaves scratches of its own(as I observed)
and you need a mild rubbing compound/polish to remove those scratches then!(I use Meguiars ScratchX / Formula1 ScratchOut)
Originally Posted by Gilead View Post
I have a small scratch on my car bumper. I am thinking I might be able to make it look a little better by using a rubbing compound and polish. What exactly is a rubbing compound and where do I get it? Any known brands? And what polish do I use?
This is the scratch. It's actually not as big as it looks.
Rubbing compounds are abrasives that abrade the clear coat surrounding the scratch. This causes the scratch to become less visible as the surrounding clear coat comes at the level of the scratch.
It should only be used when the scratch is limited to clear coat!(depth assessed by running your finger nail perpendicular to the paint surface across the scratch)
If your nail gets stuck, that means that the scratch is deep and the rubbing compound might not be able to correct the defect.
If the scratch is superficial, use mild qty of '3M Finesse it'
and always apply rubbing compound across the scratch line and not along it!
btw Nice color!
sohail99 is offline   Reply With Quote
Old 11th February 2010, 18:09   #213
greenhorn's Avatar
I have a solid white Indica, so have never noticed anything
/advantages of buying a solid shade, especially white
Old 11th February 2010, 20:21   #214
Thanked: 7 Times
Gilead, why is the scratch appearing as black? I thought under the top paint coat, it would be kind of whitish primer paint (in my MS it looks like that)..You would have to be very carefull using a rubbing compound as it can spread the defect and make it look worse.
Did u try getting a quote from mpl/cf or for that matter the bosch opp avm studios (another one near Jawahar Vidyalaya, Ashok nagar, cheaper here). If there is no dent, i guess the bosch center fellow can do it for cheap. The avm studio quoted some 25K for full body paint of my ikon (it had a paint+baking booth), whereas the ahk ngr fellow qouted 14K (no specialised baking booth)..it should cost you <1K IMO, if you try out with either of these guys. Check out with mpl/cf as well. Maybe they will try to suggest a full panel coat, but if you insist a spray only on the affected area, they might relent.
Alternatively, you can paste a "limited edition" sticker on that..visit pudupet this sunday, you may be surprised with what all you can with these stickers;-}
sanjayc is offline   Reply With Quote
Old 11th February 2010, 20:21   #215
funnyguru's Avatar
This looks like a scratch on the bumper. Is it a Blue Blaze Ritz?. I had a bigger one and I used com-paint. It worked like a charm as I followed all the directions right. But if the cut is deep it will still show up the depth of the cut, but the colour would be back on it..
Let me know if you need more inputs.
funnyguru is offline   Reply With Quote
Old 11th February 2010, 20:49   #216
Thanked: 7 Times
Gilead, this is the sticker job I did. I know, it looks creepy (particularly becos it has a deep dent as well)..but for the time being, I want to live with it some time, and at least it is not an eyesore.
For com paint, you can look at similar colors for other car/models as well. It is avlbl in Chennai.
Old 11th February 2010, 20:56   #217
Gilead's Avatar
Thanked: 20 Times
I don't know why it's black. Maybe the CF guys will know 'cos they did it! Maybe it touched a black car standing there. There is no dent though. I am definitely not going back to CF for this. I am planning to try some DIY rubbing myself to see if I can at least make the black disappear.
It's an Aquarius Fiesta 1.6S. Com-Paint does not appear to have this color. It's available only on the S variant. Full pic for reference: http://www.team-bhp.com/forum/attach...cn2195-50-.jpg
The sticker job looks good. But why don't you replace the prancing horse with a Shelby Cobra. More apt.
btw Nice color!
Thanks. I'll keep your advice in mind.
Gilead is offline   Reply With Quote
Old 11th February 2010, 21:10   #218
Thanked: 7 Times
You need to be carefull about the rubbing compound though! AFAIK, the rubbing compound works by spreading the colors from the nearby areas..I hope the black does not spread and make the situation work. A paint spray maybe the only option.
Will not some i20 blue shade or other close shade do the job?
I am done with spending too much time (lot of work piled-up becos of attention to the car) and hence did some quickfix with 100 bucks( total 8 stickers)..plan is to give a new look each month with a new theme! My own variation to keep pace with the oh-so-frequent limited editions launches!
Old 5th March 2010, 21:43   #219
meonbhp's Avatar
Thumbs down
Brand new car got scratched :(
Color: Solid Electric Red
What is the best option?
meonbhp is offline   Reply With Quote
Old 5th March 2010, 21:58   #220
greenhorn's Avatar
sorry, you need a repaint
I'd say wear it for a while
Old 5th March 2010, 21:59   #221
S.I.N.G.H's Avatar
Thanked: 31 Times
sir, u could go for the compaint touchup cans. or else if you dont want any kind of diy, then u could go to a professional painter and get the job done. compaint would cost you something around 300 bucks. i did it to my linea and alto.
S.I.N.G.H is offline   Reply With Quote
Old 5th March 2010, 22:28   #222
meonbhp's Avatar
*Goes into depression*
Should I wait for 1st service (<200KM on odo right now)? Maybe they will do the paint job for cheaper then. How much does it cost to re-paint a bumper anyway?
Com-paint was the first solution that came to my mind but I am little reluctant to use it.
Old 6th March 2010, 02:51   #223
greenhorn's Avatar
thing is, you can use com paint(my scratch was similar sized), but after my experience, I'd be a bit more wary.
Use rubbing compound to reduce the damage.
check out my pics here
http://www.team-bhp.com/forum/1091994-post133.html
Old 7th March 2010, 11:52   #224
Compared to what it was, it certainly looks very good . you must be reasonably satisfied ...... Do let me know if you've found a way to remove the coarseness
Car-e-cature is offline   Reply With Quote
Old 8th March 2010, 11:24   #225
Thanked: 91,992 Times
Meonbhp, good thing is, most of the damage is on your bumper. I'd much rather repaint a bumper than a body panel. Suggestion : Get the bumper repainted, and use some rubbing compound / minor touch up for the fender (don't repaint the entire front fender).
Touch Up Guys : A Pictorial Experience of Paint Repair in Australia SS-Traveller Technical Stuff 26 25th July 2016 18:46
Touch Up spray/paint amit Technical Stuff 12 10th July 2011 11:06
paint over paint DRC Technical Stuff 33 25th August 2006 12:05
What a paint job..S2000 with Clear Paint.. _Crazi4Speed_ The International Automotive Scene 6 20th September 2004 23:44
Don't tubes have speed ratings??? Shan2nu Tyre & Alloy wheel Section 18 9th July 2004 23:18
