Old 19th September 2008, 11:30   #46
Hi, this is Vikram Sharma again.
Here are solutions to some problems that i read in the forum
Prob:
One BHPain 'Mr. Sajan' told that the paint began to drip as he used it.
Sol.
You have to hold and spray from a distance approx 12" from the surface otherwise the Paint will Sag and run. Spray in a stroking motion like...one puf then stop then second puf then stop.....
Secondly, the Can has to be shaken for atleast 30 seconds so that you can hear the ball inside moving freely. The paint pigments do get settled in the can and if not shaken some diff shade will come out.
After shaking spray a few puffs in the air and let the paint start flowing and taking its color.
Kindly also go thourgh the application instructions for a detailed process.
We catagorise the problems of mismatching and dissatisfaction of customers as:
1.
Last edited by Rehaan : 24th September 2008 at 03:12. Reason: Post edited to conform to the TBHP rules.
y2vikram is offline   Reply With Quote
Old 19th September 2008, 11:52   #47
Thanked: 245 Times
Good to have you here Vikram, but I always had one query, nowdays paints come with a basecoat and then the topcoat (clearcoat).
I know that you might say that com-paint does not require topcoat but it wold be good to have a clearcoat spray for people who want to use it on the body or on the rims. Also a spray for the rim colour will also help.
Old 19th September 2008, 12:03   #48
hemanthisgreat's Avatar
I did buy com paint for doing up some scratches on the car. I did buy the exact shade also and followed the procedure to the T. But the paints do not match, com paint shade was darker. So i had to spray the com merge and remove the paint. I did read the instructions properly of holding the can a bit far, if the shade was darker, but nothing helped. The shade looked like a dark patch on the existing paint. The shade was charming grey for hyundai.
hemanthisgreat is offline   Reply With Quote
Old 19th September 2008, 12:17   #49
Thanked: 31 Times
Vikram looks like from Delhi.
I guess company should show demo's to some BHPians with correct method to understand the correct procedure.
Vikram do we have people appointed to do that job. I believe it is not.It can be a feedback to a company
aka_iitd is offline   Reply With Quote
Old 19th September 2008, 12:19   #50
There is a demo video on the com paint website showing the entire procedure.
Old 19th September 2008, 12:22   #51
Thanked: 31 Times
I have seen that but if they show in person i think it will help more if they are really useful
Old 19th September 2008, 12:53   #52
Thanked: 245 Times
You need practice for an even spray and the distance part. Even if they show you physically, it will help them develop a confidence in their product but not your skills.
So practice on any junk object and then you should be good.
Old 19th September 2008, 13:11   #53
rkbharat's Avatar
Thanked: 613 Times
Originally Posted by y2vikram View Post
To be honest, Yes, our Com-Paint Can can never give an absolute showroom type Finish again once your car is scratched, but if you treat it as a repair work, IT WILL GIVE 95% satisfactory work which depends on how you do it.
contd.......
Vikram, honestly speaking you are just selling
When was the last time you used it?
Leave about the finish, but even the color shade for my Silky Silver SX4 and paint sold by ComPaint for same color SX4 does not match at all.
If the dependency is so much on how user do it, than its not a DIY and should not be preferred for new cars.
Just use it for old cars where finish just does not matter.
rkbharat is offline   Reply With Quote
Old 22nd September 2008, 13:07   #54
Well i agree with you Dadu that all the metallics and pearl finishes are sealed with a clear coat. We were once providing a set of clear can with the base coat but it didn;t work i the parket. Customers used to unpack it and buy only the base coat and the clear cans were eventualt returnd to us.
The idea of giving Com-Merge was to minimise the patch formation if the customer doesn't do rubbing after 2 days. Our Clear lacquer is available seperately and if required customer can buy it.
Silver for wheel rims is also available in 300gms. We are already supplying it to the wheel rim manufacturers like Wheels India Ltd. and Steel Strips etc.
for hemantthisgreat,
Charming grey is a metallic shade and they appear darker if there are more coats than the desired.
Try it the following way:
1. when spraying wait for atleast 3 minutes between every coat. if the shade appear darker, increase the distance.
2. Spray the last coat from a distance about 14- 15 inches (mist spray)
This will correct any darkness
3. then apply a merger on the overspray.
If the problem still persists, write to us from where did u buy the can and its manufacturing date, we will arrange for a replacement.
for rtbharat,
See we dont need to sell our product as it is the only one of its type available in India. There are plenty of satisfied customers of ours and i am here for some dissatisfied customers like you or who want to know more about touchups.
There is a term called 'OBV' original batch variation which happens in every industry. We match the shade to the shade panel that we get from the original sources and can limit our shade matching to that only. But if there is a batch variation and you use a Can which was shade matched to a different panel, there will be a mismatch. We have even seen 2 Maruti wagon r cars of same color "pearl silver' one 2008 and one 2007 and the color was different.
Then there are a lot of factors that affect the color like weathering, humidity etc. and
Therefore, working with a proper technique can improvise the results in touchups.
Anyways, at present we have demo of only one color posted on the web, but we shall be posting for different metallic colors soon!!
And don't worry even if you messup, simply remove the paint using com-merge and retouchup. Our product doen't harm the surface.
Thanks,
Last edited by Rehaan : 24th September 2008 at 03:16. Reason: Post edited to conform to the TBHP rules
Old 22nd September 2008, 20:39   #55
nobetterID's Avatar
Default Waiting for delivery of the Value pack!!
I ordered the value pack and Aeroshot top-cut online today.
I will try it on a low visibility spot first and let you guys know how it goes.
nobetterID is offline   Reply With Quote
Old 22nd September 2008, 21:02   #56
AbhiJ's Avatar
Thanked: 512 Times
y2vikram, can we buy some kind of sealant/Clear coat for alloy rims?
AbhiJ is offline   Reply With Quote
Old 22nd September 2008, 21:28   #57
Thanked: 253 Times
There are 'clear lacquer' sprays available in spray cans. These would do the job sufficiently well.
Old 22nd September 2008, 22:57   #58
AbhiJ's Avatar
Thanked: 512 Times
Any brands/products that you have tried and recommend?
Old 22nd September 2008, 23:37   #59
.anshuman's Avatar
Thanked: 9,149 Times
I tried com paint on my accent once,the quality and finish is pathetic though it may match the color it will always appear odd.
Old 23rd September 2008, 01:02   #60
ibm_jennifer's Avatar
Thanked: 7 Times
I bought a Com Paint for my Safari and it matches perfectly - almost 99% - but it was painted by a professional spray painter.
ibm_jennifer is offline   Reply With Quote
Touch Up Guys : A Pictorial Experience of Paint Repair in Australia SS-Traveller Technical Stuff 26 25th July 2016 18:46
Touch Up spray/paint amit Technical Stuff 12 10th July 2011 11:06
paint over paint DRC Technical Stuff 33 25th August 2006 12:05
What a paint job..S2000 with Clear Paint.. _Crazi4Speed_ The International Automotive Scene 6 20th September 2004 23:44
Don't tubes have speed ratings??? Shan2nu Tyre & Alloy wheel Section 18 9th July 2004 23:18
