Old 29th December 2006, 04:31   #31
gemballa's Avatar
Thanked: 313 Times
hey just got the car back form viper...did all u said plus the tri phase...moves well
gemballa is offline   Reply With Quote
Old 6th January 2007, 10:09   #32
Thanked: 24 Times
Smile
Originally Posted by gdhiraj View Post
if more air goes into the combustion chamber then logically more force should be exerted on the piston and hence more should be vibration (considering that the engine is not desinged to take that much air)... isnt it ? am i wrong here ?
AFAIK, the safety factor for passenger cars is put at 2.5 . In that case the engine output can also be increased to a max of 250% . I am not sure about the engine, somebody comment on this. But its true for structural rigidity and suspension.
P.S. the safety factor for sports cars is put at 1.5, shocked??. This is explained as the number Kilometers travelled by passenger cars is way greater than sports cars. (if my statements need correction, please suggest)
V
kkr2k2 is offline   Reply With Quote
Old 8th January 2007, 19:33   #33
gemballa's Avatar
Thanked: 313 Times
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
1> Free Flow Exhaust
2> Throttle Body Enlargement
3> Porting/Polishing
4> Head Shaving
5) tri phase performance unit
6) headers
7) uprated clutch
8) 2 tone red and black interior
9) pioneer head unit running full jbl set up front components, rear speakers and jbl bass tube
10) 15' alloys with 205s yokos
11) 2 tone black and white paint job
12) sport air filter and iradium spark plugs
RUNNING ON 97 OCTANE SINCE NEW
Old 8th January 2007, 20:08   #34
babhishek's Avatar
Looks crisp!
What make are those alloys and how much did you get them for?
How sportier is the ride?
AB.
babhishek is offline   Reply With Quote
Old 10th January 2007, 12:17   #35
gemballa's Avatar
Thanked: 313 Times
Originally Posted by babhishek View Post
Looks crisp!
AB.
not sure the make but they cost bout 35 grand roughly..... the handling is much improved and the ride is a lot more sportier and very responsive
Old 10th January 2007, 12:30   #36
Thanked: 11 Times
Car looks good. Good thing you kept it a sleeper.
Boom Shiva is offline   Reply With Quote
Old 11th January 2007, 13:26   #37
X-Machine's Avatar
Thanked: 12 Times
Wow, what a co-incidence. I have the same wheels on my car for more then 2 years. When did you get em??
X
X-Machine is offline   Reply With Quote
Old 11th January 2007, 23:24   #38
chetanhanda's Avatar
Thanked: 44 Times
looking at the setup of the air filter..seems it will do more harm then good.
it will suck in even more hotter air than the stock intake system which had an enclosed box. the filter is not going to get any cold air into the system, just plenty of super hot air and very quickly..
also the pipe connecting the filter is going to get cooked by the engine heat.
dude.. reroute the piping or get a heat sheilded enclosure otherwise you are going to just reduce the power with this setup...
chetanhanda is offline   Reply With Quote
Old 11th January 2007, 23:36   #39
viper's Avatar
Thanked: 9 Times
This is the original FIPK piping sold by Four Seasons. They had supplied him with a really tiny filter which was installed 3-4 " away from the radiator fan.
We fitted it in this position for 2 reasons lack of place wihtout making any alterations and we did not want his money being wasted as he paid Four Seasons a packet for the pipe, hence we reused the pipe altering it marginally.
Viper
viper is offline   Reply With Quote
Old 11th January 2007, 23:44   #40
Thanked: 44 Times
Originally Posted by viper View Post
Viper
Hey Viper, I think as per the given conditions which you have explained and the budget constraint ..
I think it was the best possible setup for that situation...
Old 30th January 2007, 18:16   #41
Awaiting Email Confirmation
HI
Any one can please tell me .Does changing the spark plug to 2 or 4 pin point once would help to get a better pick up and a good average if yes .Any one tell me were would I get the spark plug .
Thank you in advance
Rahul290976 is offline   Reply With Quote
Old 6th February 2007, 22:45   #42
harmon_bro's Avatar
Default Rims of the TOXIN
Arush,
Could you please share the model number and the brand of the Rims used on the TOXIN(Lancer).
Thanks.
harmon_bro is offline   Reply With Quote
Old 6th May 2007, 21:14   #43
gemballa's Avatar
Thanked: 313 Times
Default cam
just installed the piper cam car running wild
Old 6th May 2007, 22:13   #44
ported_head's Avatar
What camshaft specs?
ported_head is offline   Reply With Quote
Old 6th May 2007, 22:23   #45
Ford Rocam's Avatar
Thanked: 16 Times
Must be Regrind to Pipers BP 285 Spec, i think viper can throw some more light on this.
aren't any aftermarket cams available for swift, direct bolt on?
Ford Rocam is offline   Reply With Quote
My Modified Premier Padmini & Swift Mods Queries vikid Modifications & Accessories 19 13th December 2009 21:41
my modified Suzuki Swift archerdyal Modifications & Accessories 50 24th July 2009 12:36
The RCFI Sports Coupe aka Modified Swift [AWESOME] SumitBahl Modifications & Accessories 35 11th January 2009 11:55
Modified cars in Saudi Arabia Team Fiat The International Automotive Scene 4 11th September 2004 19:13
