Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 9th January 2007, 14:30   #46 (permalink)
viper's Avatar
Originally Posted by Sideways View Post
In my experience fuel cut is normally related with speed and not RPM or gears. I may be wrong about GM's theory and am open to further details.
Hi Farhan,
You are absolutely correct. This car has been limited electronically by GM. Those donkeys out here themselves dont know or dont want to tell how hence the stupid answers. Had given Boom the same suggestion that you did as well. Gonna take the car in a day or two to install the same. Have another possible remedy as well am confident we should get around this quite easily just a matter of time and patience.
Will let Boom post on results and whether it made a diff or not.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 9th January 2007, 14:33   #47 (permalink)
ported_head's Avatar
Maybe the fuel cutoff only corresponds to a 180 kmph top speed, which was 6300 rpm in 4th but 5000 rpm in 5th, so it won't go any further. So it could be a speed and rpm based pickup signal, so then 180 kmph at 5000 rpm for the engine would correspond only to 5th gear for a certain set of fixed gear ratios , no?
__________________
BE 6.5 You lose some, you lose some.
ported_head is offline   Reply With Quote
Old 9th January 2007, 14:36   #48 (permalink)
Sideways's Avatar
I doubt their system is that advanced / complicated. You would have to programme gear ratios into the ECU for which you would have to have a seperate sensor to send a signal.
Or there has to be a link between the 5th gear and the ECU so that the ECU knows that the car is in 5th and then induces fuel cut with input from the RPM pick up.
Lke I said, i might be wrong and am open to a better explanation.
__________________
Action on the MMST race track, Chennai - 4th & 5th October 08.
Sideways is offline   Reply With Quote
Old 9th January 2007, 15:44   #49 (permalink)
Rtech's Avatar
Farhan, its not hard to conceive that there is a way that the ECU would know which gear the car is in. Heck, my 1979 Suzuki GS had a gear indicator display.
I'm not saying that GM has installed such a sensor on the Optra, highly unlikely actually. Its almost certainly just a simple speed restrictor placed by GM due to the speed rating of their OE tyres.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 9th January 2007, 16:10   #50 (permalink)
manveet's Avatar
As an example, in most jap spec cars the top speed is limited to 180 KMPH. After which the Ecu induces a fuel cut irrespective of the gear or the rpm.
O.T. - Is this why my OHC 1.5 doesn't cross 180kph?
p.s. - sorry BS, don't mean to hijack your thread.
__________________
Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
manveet is offline   Reply With Quote
Old 9th January 2007, 16:12   #51 (permalink)
Sideways's Avatar
Agreed Robin.
I doubt they have a speed restrictor in place. Seans problem is something else actually. He is going to make some changes. Lets see if it works.
__________________
Old 9th January 2007, 16:20   #52 (permalink)
Rtech's Avatar
hmm...seems you know a bit more than most, so lets see what the end result is. keep this thread alive!
__________________
____
Old 9th January 2007, 17:22   #53 (permalink)
Ford Rocam's Avatar
The ECU will know which gear your car is in with two variables one is engine RPM & other is Vehicle Speed (using vehicle Speed sensor) these values must have been calibrated with gearbox/gear ratios in use, the data is fed in ECU during development process by GM engineers. Hence when at X RPm when X is speed then = fuel cutoff.
So the ECU goes reverse way say eg when in 1st gear you are at 6000 RPM =55KMPH so ECU will read RPM (6000) & Speed (55KMPH) & it will know its 1st gear.
__________________
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
Ford Rocam is offline   Reply With Quote
Old 9th January 2007, 22:16   #54 (permalink)
harsh87's Avatar
Originally Posted by Boom Shiva View Post
Goes up to the redline (6.3k) in 4th. But the speed doesn't go past 177-180.
When you shift to 5th it drops to 5k and doesn't budge. Speedo also remains annoyingly stuck at the same place.
I got in touch with the GM people and they told me about the fuel cut off. So at least I know what's causing the issue. Now to figure a way around it!
this does sound very strange and hard to digest but you never know it may be true
btw its better you stay under 180 on indian roads no matter how good they be
try checking the gearbox and its vicinty for a gear sensor
or else it may limited via the way jitu suggested or may be speed limited
harsh87 is offline   Reply With Quote
Old 9th January 2007, 22:34   #55 (permalink)
sAP
sAP's Avatar
Arrow Bypass surgery
Care to share the workarounds with the rest of the community, gentlemen (sideways/ viper)? We have enough *classified* information doing the rounds on team-bhp anyway. So this can't hurt too much.
sAP
sAP is offline   Reply With Quote
Old 10th January 2007, 00:27   #56 (permalink)
iraghava's Avatar
I guess they're waiting for the workarounds to be proven before announicing them here. Rest assured that if they do find a solution they WILL post it here for benefit of other people too.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Thread Tools
My Landmaster Project Steeroid Post-1950 524 30th July 2008 23:27
project CHRONIC Autokustomz Modifications & Accessories 93 22nd April 2008 13:37
project help pawan Shifting gears 3 19th March 2007 00:08
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 18:26
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
