Old 15th February 2018, 15:22   #1
Thanked: 497 Times
Default Installed: BAT Roll Bar on my Isuzu V-Cross
I've been looking out for a roll bar (also known as a sports bar) for Emma. Unfortunately, most bars are not compatible with the Carryboy roller lid I have installed (see post below). The challenge being that the lid takes up most of the space on the sides of the tonneau, and most bars require a triangular mount at the front end.
Originally Posted by VivOverland View Post
For now though, Emma is still beautiful to me
Attachment 1675649
While this accessory is more a case of form over function; in my case I do need it to enhance loading abilities from time to time. Some of the requirements:
1. Provide mounting points for lights.
2. Tug points to run straps and ropes.
3. Support for people sitting out back on the trail.
Had looked at many options, which can be summarized to these 2
Hamer Long roll bar
Installed: BAT Roll Bar on my Isuzu V-Cross-hm005_03.jpg
Carryboy sports bar (compatible with CB roller lid)
Obviously the Hamer fit my needs, but unfortunately in stock condition it is not compatible with the lid I have. Also found these way too expensive, for what is essentially shaped tubing with powder coating (remember these are usually for form, not function). Kept looking out for options, as I was quite happy with the roller lid configuration for most of my drive cycle. Along the way, and basis notes dropped on the Facebook and WhatsApp owner forums - got in touch with Bon AutoTech (BAT), based in Mumbai. The owner also drives a DMax, and they have a range of products being developed for the truck. What is unique about BAT is that they are India based, and produce 4x4 accessories for international markets, primarily for Mahindra products in South Africa. What this means is a more appetizing price, minus import duty as the goods are manufactured in India. For the DMax I saw side steps, roll bars, snorkel, tonneau boxes, and the like.
(Disclaimer - I have no affiliation or special consideration with BAT, and paid retail rates for my purchase).
This is what was proposed, with a higher top bar (on which to mount lights).
The owner also seemed quite happy to customize his product to my needs, and we agreed on a mounting system and also additional tug points for lights (4x on the top bar) and ratchets / straps (2x on the side bars). Some variance to the standard paint job (blood red highlights) was agreed to, and we had a deal. As the product is under regular manufacture, my custom bull bar was quickly modified and ready for me in just a few days.
Here's the finished product at the workshop
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_160747.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_160757.jpg
Some thoughts from first impressions:
- you certainly get what you pay for. The finishing is a bit rough in places, but nothing I can't live with.
- BAT logo was much larger than anticipated. Again, decided to live with it.
- there were elements which were missed out from the design the owner finalized with me (jerrycan holder, 2x tug points). Put it down to Chinese whisper from his side, as I know the plant guys were on top of their game. He was surprisingly not available to clarify, when this point was raised. Neither was the sketch shared with them for better understanding.
- the plant team had no clue of my specific setup required (they thought it was a standard fitting, and were getting set to drill THROUGH the CB roller lid). However once I (re)explained my needs, they were more than ready to help, and immediately did what they could to find a solution. Another reason to always personally supervise work on your beloved machine.
This was at 4pm (I was a 1/2 hour late), and the entire process took 5.5 hours
Step 1 - position the bar to understand mounting points.
You can see the limited load-bearing space available, due to the flat panel of the roller lid.
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_161652.jpg
Accordingly, the plan was made to create brackets with supporting holders, which can take the load of the bar; while at the same time, providing necessary mounting strength for use of tug points in future. The team did explain that this solution is not as strong as the original, which I was anticipating. The idea was to create something like this, and happily the team reached a similar (IMHO, better) conclusion.
Installed: BAT Roll Bar on my Isuzu V-Cross-maxresdefault.jpg
Step 2 - taking measurements, and creating a paper template. Objective being to limit drilling, while giving maximum stability and strength to the mounts.
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_163207.jpg
Step 3 - fabricate brackets for front and back legs. Drill (3x4 holes, i.e. 3 for each leg).
Rear leg brackets - 2 pc each side.
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_173705.jpg
Drill holes for the rear leg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_201830.jpg
And the front leg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_201836.jpg
Front leg brackets - 2 pc each side (you can see the holder welded on).
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_175816.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_175823.jpg
Step 4 - mount the brackets and test sizing.
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_182028.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_182033.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_183646.jpg
Step 5 - paintshop - powder coating and fire drying(to speed up the process).
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_202406.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_201552.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_201541.jpg
Step 6 - mounting post paintwork
Front bracket mounted (before bolting the holder on top)
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_203420.jpg
Rear bracket and holder mounted
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_203703.jpg
Fully mounted at last... Case study in how to (or not) spend your day off!
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_212943.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_212928.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_213004.jpg
The team that made it happen for me, posing at 9.45 pm, after nearly 6 hours of passionate work. Hats' off to these guys, they could have easily asked to push the job forward another day, but did not even question once. Looks like a good team, and I had some great conversations with their manager Dhiraj. They saved the day for me.
Will post some pics of the setup in better lighting soon. For now, just loving the feel - and can't help stealing glances in the side mirrors every now and then
Installed: BAT Roll Bar on my Isuzu V-Cross-20180213_213458.jpg
Last edited by VivOverland : 15th February 2018 at 15:39. Reason: Reloading photos
VivOverland is offline   (13) Thanks Reply With Quote
Old 15th February 2018, 20:43   #2
zzzehar's Avatar
Thanked: 43 Times
I have been following your thread, FB posts etc. for a long time. The mounting fabrication looks fabulous.
On the other hand, the finished product doesn't look good. The BAT 4x4 logo looks hideous and could have easily been customized to an Isuzu or a VCross. I think the horizontal bar on which the logo is cut out isn't quite horizontal, it seems to be at an angle.
Of course, if you are happy with it, my opinion doesn't carry much weight. Enioy the ride and keep posting. You are an inspiration, I am going to get mine soon.
zzzehar is offline   (3) Thanks Reply With Quote
Old 15th February 2018, 21:34   #3
Thanked: 497 Times
Default Re: Owner's take: My Isuzu V-Cross 4x4
Thanks zzzehar, good to hear your thoughts. I can only attest that the logo looks better in the flesh, though I'm probably wearing my rose biased glasses as I say so!
The logo is easily addressed if I change my mind, stickering or paint job + basic metalwork can work wonders. The panel is load bearing (hence the angle), so that stays as is.
VivOverland is offline   (1) Thanks Reply With Quote
Old 18th February 2018, 16:25   #4
Thanked: 497 Times
Better pictures, as promised. Got Emma back from her 1st monthly wash.
Fits very tidily over the roller lid, which remains fully functional. HMSL unobstructed.
Installed: BAT Roll Bar on my Isuzu V-Cross-20180218_152224.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180218_152148.jpg
The blood red tug points hint at future design elements, perhaps some decals. The points will be well used, hopefully they help support Skoppie (RE Thunderbird AVL 2004) on one of our trips. I know what wheel chock is required, and where to fabricate it! Just need to find some good ratchet straps next, shouldn't be too hard.
Installed: BAT Roll Bar on my Isuzu V-Cross-20180218_152158.jpg
Tug points for aux lights clearly visible on the top bar.
Installed: BAT Roll Bar on my Isuzu V-Cross-20180218_152211.jpg
Those CB steps are looking a bit battered from our trail rides. Should've probably chosen proper chassis mounted sliders - blame it on the rush to get out of the showroom. Will get them touched up and reset on the next service (1,500 to hit 20,000 kms).
Installed: BAT Roll Bar on my Isuzu V-Cross-20180218_152122.jpg
Installed: BAT Roll Bar on my Isuzu V-Cross-20180218_152135.jpg
Time to figure out lighting systems next. Not sure which way to go - Hella (700FF? Rallye?) or light bar + work light combination (bar up centre, work lights on the corners with swivel mounts)... Am very amenable to suggestions, and a recommendation for a good technician Mumbai-side. I would be very careful before using the typical car accessories shop + attached 'electrical expert'.
VivOverland is offline   (7) Thanks Reply With Quote
Old 19th February 2018, 08:30   #5
Thanked: 106,410 Times
Default Re: Installed: BAT Roll Bar on my Isuzu V-Cross
Thanks for sharing, VivOverland! Moving your roll bar posts to a new thread, so that other V-Cross / Pickup truck owners can easily find it. This detailed post surely deserves its own thread.
GTO is offline   (3) Thanks Reply With Quote
Old 19th February 2018, 09:46   #6
ariesonu's Avatar
Thanked: 1,476 Times
Ref below arrangement for front bracket mount, you could have gone for 'C' channel beam. It would give more cleaner look and less of bolting points, which can anytime get loose. Just my 2 cents:
Present arrangement:
'C' channel beams
Also IMO, red lip on you alloys will give your EMMA a NEW look.
Regards-Sonu
ariesonu is offline   (2) Thanks Reply With Quote
Old 19th February 2018, 10:50   #7
Thanked: 497 Times
Regards-Sonu
Thank you Sonu, you're absolutely right. Put it down to us having to reverse engineer on the spot! Made, not bought The channel beam you've suggested will definitely work, and bolting can be done vertically (top to bottom) instead of crosswise as I did. We also thought that the holder (panel which mounts to the bar) could be merged with the upper bracket, so it's all 1-piece. This setup can become a template for future truckers with a roller lid, who still want a proper roll bar.
I did think of the red lip on the wheels - but that would not survive our next outing on the trail, especially when aired down (Owner's take: My Isuzu V-Cross 4x4). Scratches, nicks and marks to the lip would defeat the purpose IMHO. This truck gets down and dirty regularly, so all my mods need to be fairly functional too.
Old 19th February 2018, 16:52   #8
AJITHAAA's Avatar
Thanked: 249 Times
Since it is only for form and not for function, would do a world of good if you could get rid of the BAT 4X4 cross piece, its crudely made(guess stencil, gas cut and hand finished) and crudely put on.
Don't think the D-max comes with a provision to mount a Roll bar, its only a Sports bar mount which can be used to mount accessories. Roll bars need to be part of the Chassis to perform its intended duty. Mounting it on sheet metal can do more harm than good in an eventuality(god forbid).
AJITHAAA is offline   Reply With Quote
Old 19th February 2018, 17:25   #9
AJITHAAA's Avatar
Thanked: 249 Times
Also highlighting potential impalement points and safer designs.
AJITHAAA is offline   (4) Thanks Reply With Quote
Old 21st February 2018, 00:46   #10
Thanked: 247 Times
Wouldn't a heavy MS box section be a more elegant and much more rigid solution to C or L sections? Or am I missing the obvious?
vishwaschettri is offline   (1) Thanks Reply With Quote
Old 21st February 2018, 08:35   #11
Thanked: 497 Times
Interesting and very viable option. Depends on the user IMHO. I for one prefer a clear and open tonneau lip, for loading access and also aesthetics.
How would you suggest this be mounted to the bed, as we do need access to the bolts for maintenance.
VivOverland is offline   Reply With Quote
Old 21st February 2018, 10:27   #12
Thanked: 40 Times
Issues during maintenance will only come up once you have mounted them in first place. In fact i think similar issues in mounting will be there in a solid C-section beam as well. In case you can mount them easily then i doubt there will be any access issues for maintenance at a later date.
roamer012 is offline   (1) Thanks Reply With Quote
Old 21st February 2018, 14:12   #13
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 484 Times
As VivOverland asked later, accessing the mounting holes to tighten the bolts would be very tricky in case of a box section.
In my opinion, if someone is fabricating them newly, creating the entire bracket out of one single piece of metal would be the best. One of the designs could be as shown below with a rib each on either end for additional strength and support. It is similar to a C section that ariesonu showed above. One would need a bending machine to fabricate the bracket.
Viewed from the top
Upside down
From the bottom
pjbiju is offline   (3) Thanks Reply With Quote
Old 21st February 2018, 14:29   #14
Thanked: 497 Times
Viewed from the top
Attachment 1733637
Upside down
Attachment 1733638
From the bottom
Attachment 1733639
This is awesome work! Happy to retrofit if we find a worthy fabricator
Old 25th February 2018, 00:07   #15
Thanked: 247 Times
I had something very simple and easy to fabricate in my mind.
@ pjbiju - Your solution is very elegant but may deform when screws are fully tightened. A stiffener on either side of screw location or even better a sleeve is reccomended.
  1. Option 1
    Weld the stock top plate to box section and drill holes through and through. Make top hole larger so that it can accommodate bolt head and socket. Refer image below
  2. Option 2
    Weld the stock top plate to box section and drill holes through and through. Insert heavy duty metal sleeves of outer dia matching the hole dia and weld all around from both sides. Use longer high strength screw. All load is taken by sleeves so that box section does not collapses or deforms. Refer MM550 NGCS chassis mounting hole detail
    Installed: BAT Roll Bar on my Isuzu V-Cross-modified-cross-bar-steering-link-rod.jpg
Vishwas
Isuzu V-Cross : Offbeat Adventure Drive & Camping with JMD Isuzu tazmaan 4x4 Excursions 21 24th July 2017 22:16
Rear anti roll bar for Indica greenhorn Modifications & Accessories 4 13th February 2009 21:38
Anti-roll bar in Scorpio easyrider Technical Stuff 2 29th June 2007 14:26
Can I fit anti roll bar on Swift ? abhaybakshi Technical Stuff 8 29th January 2007 20:04
