Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 21st December 2006, 14:44   #1 (permalink)
sans33's Avatar
Default How to raise Altura's ride height
Hi I need to raise my Altura's ground clearance by at-least 1".On a recent trip to a small town, I found Altura scraping most of the speed-breakers.Service adviser at MSM suggest rubber pads at shockers but warns about bad handling.Is there some better way to increase ground clearance?
__________________
Great ideas need Landing gear,as well as,Wings.
sans33 is offline   Reply With Quote
Old 21st December 2006, 16:03   #2 (permalink)
Tool's Avatar
helloo sans
you could try koni dampners with Stiffer Springs. The added stiffness would go a long way in preventing your car from bottoming out. This is simply because with the stiffer springs and koni's what happens is that the dampners take longer to reach their full extention. this woud give you enough time to clear the speedbraker without hitting it . i would suggest that you first get the springs changed and see if this sorts you out.. if not then go for koni. The rubber pads for the hight increse will just ruin the handling as it will raise the center of gravity of the car.
hope this helped
__________________
Why Drink And Drive When You Can Smoke And Fly ??.
Front Wheel Drive Is The Work Of Satan !!!
Tool is offline   Reply With Quote
Old 21st December 2006, 16:20   #3 (permalink)
superavi's Avatar
Where is reply # 2?
Let me guess - reply from a newbie, awaiting Moderator scrutiny!
superavi is offline   Reply With Quote
Old 21st December 2006, 17:33   #4 (permalink)
kpzen's Avatar
Whats your current tyre size?
__________________
Prajesh
Pssssssh thE whisTling is gonna gEt Deadlier ..Coming Sooooon....;)
kpzen is online now   Reply With Quote
Old 21st December 2006, 17:40   #5 (permalink)
sans33's Avatar
Stock tyres 165/80/R13 Bridgestone
__________________
Old 21st December 2006, 19:11   #6 (permalink)
gigy's Avatar
you can change tyres to 185/65/R14 for little increase in height. total dia of this tyre will become 23.46''. stock is 23.39''
__________________
ATR 72-212A; BNG737-700/800/900
Old 21st December 2006, 19:57   #7 (permalink)
kpzen's Avatar
All baleno's has this problem of underbody scraping....Not much u can do about it without sacrificing the handling ...
One jugaad is putting 175/80-13 tyres on stock rims but this is not the correct upsize but will surely save the car's underbody from scraping...
__________________
Prajesh
Old 21st December 2006, 22:02   #8 (permalink)
sans33's Avatar
What if I opt for 15" alloys with relatively higher profile tyre,so as to increase total dia by about 1"
__________________
Old 22nd December 2006, 08:25   #9 (permalink)
doing so will affect the braking ability of your car and also large speedo errors. The mileage figures that you will calculate will also be not correct as the odometer reading will also be not correct.
surely go in for a stiffer shocks like the koni's. let us know how it helped.
princesri1981 is offline   Reply With Quote
Old 22nd December 2006, 09:59   #10 (permalink)
kpzen's Avatar
No pls dont go for 15" it will end up screwing your ride quality in a big way....14" is more than enough for Baleno..
Also 1" increase what are size are u planning for?
so are u saying its a fact with all size 15" installs in a Baleno or some particular size explain
Have u tried those ?
__________________
Prajesh
Old 22nd December 2006, 10:59   #11 (permalink)
iraghava's Avatar
Well it's not recommended unless you're prepared to sacrifice ride quality. Also if you have a high-profile 15" tyre then your body will foul with the tyre in loaded situations. I would either say if you really want to increase the height either go in for KP's suggestion i.e. 175/80 R13 (Not an ideal upsize but should do the job) or live with it as is.
Do you have any idea what Koni's cost? Please suggest affordable solutions unless the person is specifically asking for a new suspension.
__________________
Until you've lost your reputation, you never realize what a burden it was.
Thread Tools
Baleno ride height panks15 Technical Stuff 5 1st January 2009 17:05
95 Premier Padmini S1: Problem with Ride height & front suspension kavesh55 Technical Stuff 10 2nd May 2008 11:51
Lowering suspension(ground clearance or ride height) for the SX4 dharmana Modifications & Accessories 27 29th April 2008 23:34
Daimler Plans to Raise Its Stake in Mitsubishi v12 The International Automotive Scene 0 14th April 2004 14:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
