Old 18th January 2007, 13:06   #1
neo_trace's Avatar
Thanked: 38 Times
Default Baleno : Turbo + Direct Lpg Injection System = V_E_R_Y Satisfied
HI
BACK AGAIN WITH NEW EXPERIMENT THAT succeed
I have turbocharged baleno running at 7 psi which is done by VIPER
I installed LPG system into it ,because it has ECU problem(map sensor) with turbo..and was not working fully at higher above 4000 rpm in petrol
But now i have installed Lovato 120kw suppoerted Direct injection system with LPG injectors
Ecu of LPG injector system is self tunable..which i have tunned at home myself
Ecu senses MAP values from car's ECM at variable RPM level and variable petrol injec tion timings(ms) and then uses formula with multiplying value for LPG injectors to inject LPG into cylinder..........which is very very useful for TURBO / SUPERCHARGED cars.
Car is running very smooth and fast and boost is very high running upto 6000RPM
NO intake leaning problem //// No ECM remapping required /// CHEAP
finally got what i want.
will send all pictures lateron
Hope this will help someone
neo_trace is offline   Reply With Quote
Old 18th January 2007, 13:35   #2
Akshay1234's Avatar
Thanked: 7,242 Times
nice.. can you also put up some timing figures and pictures..
Old 18th January 2007, 13:41   #3
Psycho's Avatar
Thanked: 95 Times
Congrats that was a good Idea would suggest that you invest into an AFR an fine tune your setup
Old 18th January 2007, 13:47   #4
Congratulations NEO and VIPER,
Neo, did you happen to do a run before and after to see timings etc? If so would you be able to let us know the figures please.
Cheers.
2L8uLoose is offline   Reply With Quote
Old 18th January 2007, 20:09   #5
HAFI's Avatar
@neo
please mention information on how much did it cost for you for the lpg as iam plannin it br fitted on my palio...
HAFI is offline   Reply With Quote
Old 18th January 2007, 22:14   #6
flipsyde's Avatar
Thanked: 62 Times
congrats!! cool turbo charged LPG baleno!! now who would have thought!
pls post some pics and also some details on how you went about the setup.......other than the fact that you drove the car right into VIPER's garage!!!
flipsyde is offline   Reply With Quote
Old 18th January 2007, 22:25   #7
SRK
SRK's Avatar
Thanked: 356 Times
WOW!!!
I think it has to be 1st of its kind..
A LPG Turbo Charged Baleno..
Sounds wierd when heard 1st..
By the way is it comparable to the feel provided by petrol car..
If yes i think you will have created an economical fast car..
SRK is offline   Reply With Quote
Old 18th January 2007, 22:43   #8
CrAzY dRiVeR's Avatar
Thanked: 19,845 Times
Originally Posted by SRK View Post
WOW!!!
economical... yet fast...
Old 18th January 2007, 23:03   #9
harsh87's Avatar
nice work there
congratulations for being a pioneer, now many may follow you
is the ecu running closed loop, are you using lambda sensor readings
harsh87 is offline   Reply With Quote
Old 19th January 2007, 00:16   #10
Mpower's Avatar
Thanked: 1,687 Times
COngrats NEO, how about some pics.
The 120Kw kit was meant for which car?
MAP is positive (not vacuum) for turbo cars, I hope the Lovato ECU understands that.
Old 19th January 2007, 06:27   #11
Gtea's Avatar
Congrats Neo and Viper.
Are you running on LPG alone or you switch between LPG and Petrol????
Please post pics ASAP.
Gtea is offline   Reply With Quote
Old 19th January 2007, 10:12   #12
Ford Rocam's Avatar
Thanked: 16 Times
Really appreciate the efforts you are putting it in to your project my recommendation get an E.G.T & water temp gauge & monitor the temperature both engine & exhaust dont rely on instrument clusters temp gauge your engine will be running more hot with lpg.
you should also time it with Gtech pro & see how much is the improvement.
power output will be far better with petrol than lpg & your problem could have been sorted out with petrol & i bet it can still be!
Ford Rocam is offline   Reply With Quote
Old 19th January 2007, 20:44   #13
neo_trace's Avatar
Thanked: 38 Times
ya car is running faaaaaar better than Petrol because its ECU managed LPG injection and can be switched to petrol to lpg and back
U just need to programe ECU right
ECU programing is running on TWO main Formulae
One Apply Volumetric efficiency chart created for
1.Displacement
2.initial RPM
3.final RED line marked RPM
4.Min and Max MAP value (upto 200Kpa)
5.if Boosted then boost pressure or if nat.aspireted Engine then this value will be zero.
Second Petrol timings and then applied multiplier according to VE chart
1.petrol timing that is naturally from CAR's ECM to LPG ECU
running car at variable level of RPM and MAP value will find exact Petrol timeing for turbo car then Lpg ECU will generate theoritical petrol timing for even higher 200KPA MAP value for boosted car. THEN LPG ECU will generate TABLE for RPM vs MAP graph
2. apply multiplier according to VE table generated from formulae
3. minor changes will solve jerks between gear shifts and will adjust initial RPM and test it.
keep driving and find for exact RPM jerks and adjust multipliers for minor.will solve problems
LOVATO FAST 120kw will support upto 120kw car
1. i have choosen this system because its has highly capable pump and bigger injectors which can withstand with turbo air press
2. I can use same system again for bigger car in future.
3. not much price diff . betN 90kw and 120kw supported systems
perfect petrol timing and multiplier belongs to testing and testing
will send u perfect multipliers and timing that i have used
LPG kit has cost of rs 58000/ for me with 1yr warranty and 5 yrs service discounts (because turbo was first car for him)
i m using lambda sensor readings for wide band AFR
just want to keep watching on engine TEMP and water+coolent levels
Will send u pics lateron after 25th..cause i m out of city
Old 29th January 2007, 18:48   #14
Mp421b's Avatar
hey Neo, whats the size of your LPG tank and you can post some pics please.
Mp421b is offline   Reply With Quote
VTEC Turbo + Direct-Injection: Honda's latest addition to Earth Dreams lineup sarathlal The International Automotive Scene 44 28th October 2015 19:30
Turbocharging and Fuel direct injection in Petrol Engines rangakishen Technical Stuff 20 9th May 2013 18:00
Direct Injection engines for Petrol !!! vikrantj The Indian Car Scene 19 1st September 2009 16:52
Direct Injection of Petrol pratheesh Technical Stuff 3 9th January 2006 20:01
