Old 24th January 2007, 21:57   #16
HAFI's Avatar
okk cool...i got my gtx 1.6 for 1.5 lacs....its mh reg....i was scared when u told flood affected...doubted myself whether i got cheated...
HAFI is offline   Reply With Quote
Old 24th January 2007, 22:10   #17
khanak's Avatar
Thanked: 130 Times
Originally Posted by BUSA View Post
Thanx mclaren1885 and moralfibre - What ever you said makes a lot of sense.
My budget for the mods is around a Lac. So the car i am getting is for 70k + 1L on mods = 1.7L which hopefully should be a bit faster then a 1.6 GTX bought for 1.5L.
Its not a flood affected car. A flood affected 1.6 = non flooded 1.2 in performance.
Instead of going through the jholl of an engine swap i feel it would be easier to just get a 1.6 for 1.5 and spend 20k on basic mods...then as u save up u can mod the 1.6 further....im sure the factory installed engine would be a lot more reliable than an engine swap....especially one tht involves custom mounts nd stuff
khanak is offline   Reply With Quote
Old 24th January 2007, 22:24   #18
moralfibre's Avatar
Thanked: 6,533 Times
I second you on that. Making custom mounts is not an easy thing to do. I have seen many cases where the mountings crack.
Old 24th January 2007, 22:30   #19
BUSA's Avatar
Thanx guys, will ponder over the points.
Old 24th January 2007, 22:39   #20
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Custom made mounts is not the only headache , because there are plenty people here in bangy whose mounts are holding up insane bhp figures on cars like zens etc though the driveshafts and the gearboxes arent .. Its just the tidious process of having to go thru though id personally love it .. Finding such engines is neither the issue but its very time consuming and the chances of screw ups are more ..
U can however , buy a 1.6gtx and get the head ported and polished with headers for about 25k .. Thats what harrie did and he was more than happy ..
Old 25th January 2007, 12:15   #21
Thanked: 11 Times
If you want a drag rocket, get a Zen instead and swap the engine. Cheaper, quicker, easier to maintain and mod, and tuners have had already got loads of experience with it.
Boom Shiva is offline   Reply With Quote
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 61 13th July 2016 15:49
Fiat Palio - Engine Swap Advice manvirr Modifications & Accessories 11 15th November 2011 10:12
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 15:12
Urgent: Used Elantra CRDi swap with Palio 1.9D - To go or not? basilmabraham Sedans 54 29th July 2008 00:20
palio engine swap blue2ki Modifications & Accessories 15 20th October 2007 10:21
