Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 13th May 2008, 21:23   #811 (permalink)
viper's Avatar
Originally Posted by balenopower View Post
I dint like the black hood at all.Infact its gives away the sleeper identy of the car.
Originally Posted by aZa View Post
Jiggy bhai, Although the matt black hood looks good but its just doesn't complete the "SLEEPER" look.
Guys,
Its time to think beyond looks. The hood is being put only because the engine bay is getting very hot and no cosmetic reasons.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 13th May 2008, 21:35   #812 (permalink)
Team-BHP Moderator
normally_crazy's Avatar
Jiggy,
The bonnet color has to match the body color. Black is not right, IMO.
normally_crazy is offline   Reply With Quote
Old 13th May 2008, 22:17   #813 (permalink)
Infractions: 0/1 (4)
Default Hi
Hi Viperji,
Car looks mean. Great build must say.According to the standards on the car IMO you should stop experimenting and go for a carbon fiber hood . That will be a killer cheers
archerdyal is offline   Reply With Quote
Old 14th May 2008, 11:35   #814 (permalink)
gigy's Avatar
i think the hot air must be diverted downwards or away through side vent rather than over the windshield. there could be issues with heating up of the windshield, and problems in rainy season.(or will it help in rains in managing the windshield temperature?)
two flush airscoops in bumper where the forward air pressure is maximum and two side vents on the quarter panel(small blowers for blow out)
__________________
Suzuki Baleno
Old 14th May 2008, 20:41   #815 (permalink)
akshay1234's Avatar
here are your pics viper. i just couldnt find a pic of a backwards impreza scoop.
akshay1234 is offline   Reply With Quote
Old 14th May 2008, 21:35   #816 (permalink)
crazydiablo's Avatar
I vote for the first one. Probably you can go white hood and black scoops to acentuate the scoops.
crazydiablo is online now   Reply With Quote
Old 14th May 2008, 23:40   #817 (permalink)
arpandiv's Avatar
matt black hood looks like a great combo.
arpandiv is offline   Reply With Quote
Old 17th May 2008, 11:28   #818 (permalink)
viper's Avatar
Default D.I.Y. - Intercooler Water Spray Added
Hi Guys,
Had opened the front bumper to replace a fog light bulb yesterday when I decided to so some experimentation. I Installed a new water reservoir with motor and decided to add 2 nozzles activated via a separate switch to spray on the inter cooler to cool it down as and when required.
After finishing the same decided that the spray was not as I wanted so took a metal brake pipe the width of the intercooler and drilled fine holes at 1" intervals. This worked out just great as now the entire cooler was getting sprayed evenly. Now only thing I need to do is fit a larger motor on the reservoir as the spray is very mild (not enough pressure).
See the pics attached of the final fitment. Will be going to fit my bonnet today as the scoops have been made and bonnet painted. Will post the pics once I get the car back.
Viper
__________________
Old 17th May 2008, 11:32   #819 (permalink)
Team-BHP Moderator
That is nice, Jiggy. Great thinking there. Get us a video of the spray if possible.
Old 17th May 2008, 18:24   #820 (permalink)
arpandiv's Avatar
Taking it a step further,i am sure the RD ecu can be programmed to fire this motor at pre-set RPMs. Should be a nice add-on.
Old 17th May 2008, 23:56   #821 (permalink)
DocG's Avatar
that would be one of the coolest things ever, or just set the motor to fire at a regular time interval, that would help in the Mumbai traffic
Jiggy need pics of the hood man, hopefully you've gone with body colour on the hood, black looks kinda out of place...
__________________
______
o/_______\o
(OO=00=OO)
0=--------=0
E30 POWER
DocG is offline   Reply With Quote
Old 19th May 2008, 11:19   #822 (permalink)
viper's Avatar
Hi Guys,
Am attaching below pics of the new bonnet with hood scoops fitted. It is currently painted matt black and will be painted body colour when the car goes for a touch up at the end of the month.
Please let me know how the scoop looks.
Viper
__________________
Old 19th May 2008, 12:51   #823 (permalink)
akshay1234's Avatar
looks great. though i think had the centre scoop been a little more behind it wouldve looked better.
Old 19th May 2008, 19:33   #824 (permalink)
gigy's Avatar
technically this position is not going to give any good airflow into engine area.i had used similar design and the air temperature entering the filter box had a good improvement. same outside air temperature compared to 60-80c otherwise. the difference was very noticeable when you stop at signals.
__________________
Suzuki Baleno
Old 19th May 2008, 20:55   #825 (permalink)
viper's Avatar
Hi Gigy,
Thanks for the suggestion. In my case my air filter is positioned exactly below the front scoop giving it the best of both worlds(direct air and no danger of water being sucked in during water logging). Will mostly revert back to stock bonnet during monsoons though.
The central reverse scoop was made to purely serve as a hot air extractor and nothing else. I am more concerned about this issue rather than getting cool air to the filter.
Viper
__________________
Thread Tools
Wanted Urgently- Engine harness for B16A2 viper Shifting gears 3 6th January 2008 20:56
Palio 1.6 Turbo Charged BUSA Modifications & Accessories 120 6th December 2007 16:38
Tuning turbo charged engines. drpullockaran Technical Stuff 8 7th May 2007 04:35
Turbo charged INDIA Vulken Auto Modifications & Accessories 24 19th May 2006 11:00
Turbo Charged City!! iomega Modifications & Accessories 13 17th March 2005 15:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
