Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 21st May 2008, 23:57   #841 (permalink)
sujaylahiri's Avatar
Peak torque at 6500 rpm and peak power at 7500 rpm. That's so Japanese. When will they learn to make engines with more usable lower end torque?
I am assuming that the torque figures are in lbs-ft.
__________________
I'm Mr. Brightside.
sujaylahiri is offline   Reply With Quote
Old 22nd May 2008, 01:32   #842 (permalink)
Most enthusiasts prefer it that way, as its always fund revving the motor. Also to add, the B16 is a old motor, more than a decade old. I am sure the Japanese have done many enhancements to their motors during this period. Also interesting is how these motors rev compared to American counterparts. They reach those revs much faster than American engines.
dipen is offline   Reply With Quote
Old 22nd May 2008, 02:05   #843 (permalink)
chetanhanda's Avatar
Originally Posted by viper View Post
Keshav - All runs have been done on the high lift cams only. Also as discussed have got slightly lower compression which may or may not affect the HP figures. Do not experience any power loss whilst driving.
Shrey,
There is yet some doubt on the Vtec part which we are investigating.
@Dinar - The ECU that is presently on my car does not support Vtec and that is the ECU on which each and every run has been done. I have the other ECU supplied by Karthik which has Vtec control enabled which we will test in a day or two.
To all concerned shall be doing a run with the new ECU and then another run by physically disconnecting the Vtec solenoid to be 100 % sure that vtec is OFF and see what results we get.
I think that is the only way to solve the vtec mystery.
@ GTO - When there is nothing to hide or prove then why be secretive. Am not ashamed to divulge any info whether good or bad about the install or health of motor.
Viper
Hey Jignesh..
You could get a vtec indicator light,it will light up whenever the vtec gets engaged. I think its quite inexpensive also.
chetanhanda is offline   Reply With Quote
Old 22nd May 2008, 02:37   #844 (permalink)
They know how to make power just that they are designed for a different audience.
Unusable power for you means usable power for a different set of audience.
Also Japanese engine sizes are smaller as compared to the lethargic huge american gas guzzling engines; so in order to make power you either make the engine bigger or rev it higher.
Lots of people like high revving screamer engines as compared to tractor/truck like american engines its a matter of taste what you like to drive.
If the cc of the B16/B18 was raised to say 3litres instead of just a mere 1.6 of 1.8 litre Im sure these more efficient engines would have made twice the power of the lazy american engines.
Before going very OT on this thread - another real world example of 2 sporty cars in the same price bracket.
- Ford Mustang 6 cylinder with 4000 cc makes 210 hp
- Honda Civic Si 4 cylinder with 2000 cc makes 200 hp
And Im sure the K20Z3 engine will rev up quicker than the Ford and reach the rev range where it makes max torque/power.
Looking at these specs makes me think did the American companies not learn to make engines till now ?
Engine size and low end torque means nothing to most car enthusiasts specially for people in a thread discussing a Honda B series engine.
Old 22nd May 2008, 04:43   #845 (permalink)
If the cc of the B16/B18 was raised to say 3litres instead of just a mere 1.6 of 1.8 litre Im sure these more efficient engines would have made twice the power of the lazy American engines.
Firstly, just because I like some American cars doesn't mean that I hate all other cars (Japanese and German). I keep my mind open to everything in the market.
Contrary to what you've said in the quoted post, Honda themselves seem to think otherwise. Most of the peak torque figures in their recent cars are around the 4000 rpm range which is a more usable range (although still a bit higher than German/American engines) for daily driving. I double checked the torque figures for the latest 4 cylinder offerings from Honda in North America and came up with these figures:
2008 Civic 1.8L - 128 lb-ft@ 4300 rpm
2.0L - 139 lb-ft@ 6200 rpm
2008 Accord
2.4L - ~161 lb-ft@ 4300 rpm
What I meant to say before is that by altering the Variable Valve timing (VTEC in case of Honda) to kick in at an earlier rpm and altering the valve overlap(s) sequence, the engines could be made to generate more lower end torque without sacrificing specific power output, which Honda seems to have done in the recent years.
The 2.0L in the Si, the 1.3L rotary in the Mazda RX-8 and the 2.2L in the Honda 2000 are all exceptions as they were designed from ground up to be "racing" engines and just concentrate plainly on achieving a higher specific output, which is what many enthusiasts prefer.
However, engines for everyday use should not have that handicap which would make them terrible in "real life conditions" (overtaking on the freeway at 60 mph, 3rd to 4th gear acceleration, highway cruising rpm, even off the line starts etc.).
__________________
I'm Mr. Brightside.
Old 22nd May 2008, 11:33   #846 (permalink)
Shan2nu's Avatar
Instead of all that, just use a short/close ratio gearbox to achieve the desired torque at the wheels, without sacrificing bhp/ltr or torque/ltr.
What torque you produce at the crank is just half the story, the transmission is what really dictates how much torque is transfered to the wheels. And as far as torque/ltr goes, i think the high revving Jap engines are doing really good.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Shan2nu is online now   Reply With Quote
Old 22nd May 2008, 12:19   #847 (permalink)
doomsday's Avatar
Post
2008 Accord
The key word in your post is "American offerings". Unfortunately Honda reserves its best work for the JDM, which is clearly reflected in the engine specs.
So while the K20 in the Civic Si produces 189Nm@6200rpm, the same engine in the JDM (Type R spec) produces 215Nm@7000rpm with a 8600rpm redline as opposed to the 8200rpm in the USDM Si.
A Honda engine that produces torque has low rpms (like the K24 in the Accord) does so because its housed in a executive car and not a sports saloon where the owner would like to rev the nuts off the engine. Same goes for the 1.8 litre R18 SOHC engine thats in the Civic which is an economy oriented motor. It makes much more sense to produce power and torque low-down.
Each performance Honda engine will produce power and torque high in the rev range, which is exactly what every NA enthusiast wants.
__________________
If a car doesn't allow you to toe-n-heel.. it ain't worth driving.
doomsday is offline   Reply With Quote
Old 22nd May 2008, 16:37   #848 (permalink)
binz's Avatar
Originally Posted by Shan2nu View Post
So, you're not 100% sure if vtec was running this time as well eh? Hmm.
Im a little confused here,isn't there a huge audible difference when vtec engages?Ive never been in a vtec in my short life but while driving a mivec which i believe works similarly the intake/exhaust note completly changes ..
My question is,is it is that difficult to know whether vtec was engaging or not?
__________________
HAhaha
Old 22nd May 2008, 16:48   #849 (permalink)
viper's Avatar
Originally Posted by binz View Post
Im a little confused here,isn't there a huge audible difference when vtec engages? My question is,is it is that difficult to know whether vtec was engaging or not?
Binz - There is a huge audible difference in a NA B16A when Vtec kicks in. Problem is car is Turbo Charged now and there is almost no audible note change across the power band. Also the problem is the Turbo is also boosting at approx the same RPM as where the Vtec would activate.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 22nd May 2008, 17:03   #850 (permalink)
Shan2nu's Avatar
Not always.
Here's a vid of an NSX acc, you don't hear the vtec activating in 1st, but the car is still accelerating hard.
Atleast goin by the chart, i think vtec was always working.
__________________
Old 22nd May 2008, 17:21   #851 (permalink)
binz's Avatar
Ok got it!,thanks guys.
__________________
HAhaha
Old 22nd May 2008, 17:22   #852 (permalink)
viper's Avatar
Shan2nu - This Vtec problem is actually becoming a nightmare for me to figure out. I know for a fact it was not working when the Turbo was installed in Feb 08 and during the Speed Run.
As per Karthik the Vtec cannot function on the ECU in the car(white ECU)as the wire is not connected and the software does not support Vtec. The original ECU stops functioning once the RD is switched on which will also make it impossible to read/check on a Hi-Scan machine as well.
On the new ECU(black) to be installed and checked am supposed to connect the Vtec wire thru a relay and only then does the Vtec switch on which it did when Karthik was in Mumbai and did the wiring.
I am as confused as before and have absolutely no clue as to what is happening. Should get sorted out once KS finds the time to install and check.
Viper
__________________
Old 23rd May 2008, 08:52   #853 (permalink)
Ford Rocam's Avatar
Set your vtec at 7000 rpm & do a pull, then set your vtec at 3500 rpm & do a pull, you will get the answer.
plus you will get your best vtec shift point, where torque from low speed cam starts falling & high speed cam increasing both the graph(torque curve) will come to an interception point, thats where you set your Vtec.
__________________
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
Ford Rocam is offline   Reply With Quote
Old 23rd May 2008, 09:44   #854 (permalink)
Jaggu's Avatar
I think Jitu has a point, very logical and practical way to check instead of assumptions, also to tune the Vtec.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 23rd May 2008, 10:08   #855 (permalink)
viper's Avatar
Jitu,
Thanks for the suggestion. Problem is it can only be implemented on the new(black)ECU as only that has the Vtec control on it. Whenever KS finds the time to install that ECU shall try out your suggestion and post both graphs as suggested also..
Viper
__________________
Thread Tools
Wanted Urgently- Engine harness for B16A2 viper Shifting gears 3 6th January 2008 20:56
Palio 1.6 Turbo Charged BUSA Modifications & Accessories 120 6th December 2007 16:38
Tuning turbo charged engines. drpullockaran Technical Stuff 8 7th May 2007 04:35
Turbo charged INDIA Vulken Auto Modifications & Accessories 24 19th May 2006 11:00
Turbo Charged City!! iomega Modifications & Accessories 13 17th March 2005 15:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440
